Possible crank to lower sprocket issue. #908355
01/18/11 10:50 PM
01/18/11 10:50 PM
Rancho Cucamonga, Calif.
P
PUNK Offline OP
PUNK  Offline OP
P
Has anyone ever seen a crank that had the shoulder of the snout in which the lower crank sprocket backs up against be machined too much? In other words, I have an engine over here that has a crank that seems to be allowing the lower crank sprocket to slide on too far which is causing the timing chain to not be in perfect alignment. I tried another timing gear set and found it to be the same result. I guess I could shim the lower sprocket out some to fix this condition. Has anyone else seen this issue? This is a first for me. Also a first with this particular brand crankshaft also.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM.
CP Pistons, PC Carbs.
Re: Possible crank to lower sprocket issue. [Re: PUNK] #908356
01/22/11 07:29 PM
01/22/11 07:29 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
My guess is you left out the oil slinger and that's the difference !!
Re: Possible crank to lower sprocket issue. [Re: Stanton] #908357
01/22/11 08:19 PM
01/22/11 08:19 PM
owt west
Thread Ender1 Offline
owt west
Wrong!!!! tht goes after the gear is installed 10-4
Re: Possible crank to lower sprocket issue. [Re: Thread Ender1] #908358
01/22/11 09:46 PM
01/22/11 09:46 PM
UK
602heavy Offline
602heavy  Offline
UK
You could of said "if i recall the slinger goes on after the gear' , now would'nt that be a better way making you're point?
All friends here i hope. ...........................................anyhow , i usually 'sling' the slinger in the corner of workshop & forget about it , so i don't remmember which way it goes on.
Re: Possible crank to lower sprocket issue. [Re: 602heavy] #908359
01/22/11 10:12 PM
01/22/11 10:12 PM
owt west
owt west
What are you type "babbling" about? I don't need to state i recall anything about oil slingers. I know how they install unlike you, right? So pay attention before you type nonscense. Ok friend
Re: Possible crank to lower sprocket issue. [Re: Thread Ender1] #908360
01/22/11 10:26 PM
01/22/11 10:26 PM
UK
602heavy Offline
602heavy  Offline
UK
Ok point taken. ..................'never confuse politeness as a sign of weakness'
Re: Possible crank to lower sprocket issue. [Re: 602heavy] #908361
01/22/11 10:32 PM
01/22/11 10:32 PM
owt west
owt west
Mmm ok.....what an absolute tosser you are? carry on.
Re: Possible crank to lower sprocket issue. [Re: Thread Ender1] #908362
01/22/11 10:34 PM
01/22/11 10:34 PM
UK
602heavy Offline
602heavy  Offline
UK
Sounds like you just had one.
Tosser............
Re: Possible crank to lower sprocket issue. [Re: 602heavy] #908363
01/22/11 10:35 PM
01/22/11 10:35 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
The crank gear may float some on the key and crank snout some in some cases (stock stuff) It will follow the cam. Were talking a movement of very little hear, but will move. How does the alignment look as far as the cam gear and crank gear is concerned? It usually wont go much farther back than the cam gear is, and most flat tappet cams will walk a hair, but mostly the spinning of the tappet will push the cam towards the back of the block, and the face of the block and back of the cam gear crown will provide the thrust and wear.
Is this a stock crank or after market? I guess a aftermarket crank could be machined wrong. Has this crank been used prior?
Re: Possible crank to lower sprocket issue. [Re: Bob_Coomer] #908364
01/22/11 10:50 PM
01/22/11 10:50 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Sorry Bob but the balancer seats hard up to the sprocket and slinger if used, if it didn't the balancer would not work. I haven't heard of your problem but if you have tried a couple of sprockets and they are in to far then it's the crank.
Re: Possible crank to lower sprocket issue. [Re: Bob_Coomer] #908365
01/22/11 10:52 PM
01/22/11 10:52 PM
Alabama
Mopar-Al Offline
Mopar-Al  Offline
Alabama
Did you spin the tc set up with the dist drive installed? Is it possible you pushed the rear cam plug to far in? Never saw that problem before. tight cam bearing not letting cam go back all the way? these are things I would check if you haven't already.
Re: Possible crank to lower sprocket issue. [Re: rowin4] #908366
01/22/11 10:56 PM
01/22/11 10:56 PM
UK
602heavy Offline
602heavy  Offline
UK
Have you checked crank end float?
Re: Possible crank to lower sprocket issue. [Re: Mopar-Al] #908367
01/22/11 11:02 PM
01/22/11 11:02 PM
rowin4 Offline
rowin4  Offline
This could be possible ,Have you tried a different upper gear? or is the upper gear seated to the block?
Re: Possible crank to lower sprocket issue. [Re: rowin4] #908368
01/23/11 04:54 PM
01/23/11 04:54 PM
owt west
owt west
Here is my opinion on the matter, if its a Chinese crank chances could very well be that crank snout is machined up to the main flange more than mornal.
I really don't see any problems with the crank sprocket fully seating rearward as the engine is rotating the chain will keep it in line and not walking but...the simplest and most cost effective repair would be to take the extra sprocket and have it milled(machined)to be used as a spacer.
Re: Possible crank to lower sprocket issue. [Re: PUNK] #908369
01/23/11 05:48 PM
01/23/11 05:48 PM
Delray beach, Florida
P
Performance Only Offline
P
any chance you could tell us what size engine your working on and what brands of parts your using?
machine shop owner and engine builder
Re: Possible crank to lower sprocket issue. [Re: Performance Only] #908370
01/23/11 06:13 PM
01/23/11 06:13 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
Normally the crank gear should fit snug on the crank,it's shouldn't float as it should be bottomed out on the crank by the dampner.If the issue is at the crank you may have to make a spacer,I would hazzard to guess the problem is cam location.As mentioned make sure the cam plug or anything else has the cam pushed forward.Make sure the timing set is a complete and matched set.Make sure the cam gear is seated and there is nothing between it and the cam face.Some times when rotating an engine the cam walks forward,make sure you push the cam in when checking the alignment.Also check for anything between the cam and plug and make sure that none of the cam bearing are holding the cam forward because of fit.Some of what I mentioned are extreme but warrant checking.
Re: Possible crank to lower sprocket issue. [Re: PUNK] #908371
01/23/11 06:46 PM
01/23/11 06:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
You must be talking BB stuff... if the cam is in the
right location and the crank sprocket is in too far
I would really think the snout is machined wrong...
but a spacer could be machined.... you might need to
measure another crank to make sure
Re: Possible crank to lower sprocket issue. [Re: PUNK] #908372
01/23/11 08:50 PM
01/23/11 08:50 PM
Central Coast
P
Plumcrazyracing Offline
P
Central Coast
I had this very same problem on my Mopar Performance 8 bolt 4.15 stroke crank for my 493 build. The problem ended up being the machining on the snout. the snout was not machined 'back' far enough. The crank gear lined up perfectly fine with the cam gear but there was about 3/32 to an 1/8 of 'shoulder' showing on the snout. I ended up machining the hub on my balancer to fit over the shoulder and rest against the crank gear. Worked very well for me. Next option would have been to pull the crank and have the snout machined correctly.
Re: Possible crank to lower sprocket issue. [Re: Plumcrazyracing] #908373
01/23/11 08:59 PM
01/23/11 08:59 PM
Central Coast
P
P
Central Coast
Here is a pic!
