Has anyone ever seen a crank that had the shoulder of the snout in which the lower crank sprocket backs up against be machined too much? In other words, I have an engine over here that has a crank that seems to be allowing the lower crank sprocket to slide on too far which is causing the timing chain to not be in perfect alignment. I tried another timing gear set and found it to be the same result. I guess I could shim the lower sprocket out some to fix this condition. Has anyone else seen this issue? This is a first for me. Also a first with this particular brand crankshaft also.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
