Possible crank to lower sprocket issue.
#908355
01/18/11 10:50 PM
01/18/11 10:50 PM
Posts: 1,717 Rancho Cucamonga, Calif.
PUNK
Has anyone ever seen a crank that had the shoulder of the snout in which the lower crank sprocket backs up against be machined too much? In other words, I have an engine over here that has a crank that seems to be allowing the lower crank sprocket to slide on too far which is causing the timing chain to not be in perfect alignment. I tried another timing gear set and found it to be the same result. I guess I could shim the lower sprocket out some to fix this condition. Has anyone else seen this issue? This is a first for me. Also a first with this particular brand crankshaft also.
10.53 @ 125mph. 1.37 60 foot. Caltracs and Monoleafs, AFCO shocks.
Heads by INDIO MOTOR MACHINE; IMM. CP Pistons, PC Carbs.
Re: Possible crank to lower sprocket issue.
[Re: Stanton]
#908357
01/22/11 08:19 PM
01/22/11 08:19 PM
Posts: 2,679 owt west
Thread Ender1
owt west
My guess is you left out the oil slinger and that's the difference !!
Wrong!!!! tht goes after the gear is installed 10-4
[Re: Thread Ender1]
#908358
01/22/11 09:46 PM
01/22/11 09:46 PM
Posts: 1,200 UK
602heavy
UK
You could of said "if i recall the slinger goes on after the gear' , now would'nt that be a better way making you're point?
All friends here i hope. ...........................................anyhow , i usually 'sling' the slinger in the corner of workshop & forget about it , so i don't remmember which way it goes on. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: 602heavy]
#908359
01/22/11 10:12 PM
01/22/11 10:12 PM
Thread Ender1
owt west
What are you type "babbling" about? I don't need to state i recall anything about oil slingers. I know how they install unlike you, right? So pay attention before you type nonscense. Ok friend ![](/ubbthreads/images/graemlins/eyes.gif)
[Re: Thread Ender1]
#908360
01/22/11 10:26 PM
01/22/11 10:26 PM
Posts: 1,200 UK
602heavy
UK
Ok point taken. ..................'never confuse politeness as a sign of weakness'
[Re: 602heavy]
#908361
01/22/11 10:32 PM
01/22/11 10:32 PM
Thread Ender1
owt west
Mmm ok.....what an absolute tosser you are? carry on. ![](/ubbthreads/images/graemlins/pity.gif)
[Re: 602heavy]
#908363
01/22/11 10:35 PM
01/22/11 10:35 PM
Posts: 6,293 Rock Springs
Bob_Coomer
Rock Springs
The crank gear may float some on the key and crank snout some in some cases (stock stuff) It will follow the cam. Were talking a movement of very little hear, but will move. How does the alignment look as far as the cam gear and crank gear is concerned? It usually wont go much farther back than the cam gear is, and most flat tappet cams will walk a hair, but mostly the spinning of the tappet will push the cam towards the back of the block, and the face of the block and back of the cam gear crown will provide the thrust and wear. Is this a stock crank or after market? I guess a aftermarket crank could be machined wrong. Has this crank been used prior?
[color:"red"]65 Hemi Belvedere coming soon [/color] [color:"#00FF00"]557" Indy engine 1.07 60ft 144mph in the 8th 2100 lbs package [/color]
[Re: rowin4]
#908368
01/23/11 04:54 PM
01/23/11 04:54 PM
Thread Ender1
owt west
Did you spin the tc set up with the dist drive installed? Is it possible you pushed the rear cam plug to far in? Never saw that problem before. tight cam bearing not letting cam go back all the way? these are things I would check if you haven't already.
This could be possible ,Have you tried a different upper gear? or is the upper gear seated to the block?
Here is my opinion on the matter, if its a Chinese crank chances could very well be that crank snout is machined up to the main flange more than mornal.
I really don't see any problems with the crank sprocket fully seating rearward as the engine is rotating the chain will keep it in line and not walking but...the simplest and most cost effective repair would be to take the extra sprocket and have it milled(machined)to be used as a spacer. ![](/ubbthreads/images/graemlins/Twocents.gif)
[Re: PUNK]
#908371
01/23/11 06:46 PM
01/23/11 06:46 PM
Posts: 52,972 Romeo MI
MR_P_BODY
You must be talking BB stuff... if the cam is in the right location and the crank sprocket is in too far I would really think the snout is machined wrong... but a spacer could be machined.... you might need to measure another crank to make sure ![](/ubbthreads/images/graemlins/wave.gif)
