priming oil pump #906598
01/16/11 05:31 PM
01/16/11 05:31 PM
louisiana
mopar70charger Offline OP
louisiana
i am as of now trying to prime the oil pump with a oil pump priming tool with a drill , the oil filter was off until i noticed it starting to pour oil which it did, then i placed a oil filter back on the motor with oil in filter... but then i tried to get oil else where by priming it and i don't seem to see any especially around timing chain and or the top of the heads. i am using a 3/8 drill.. can someone tell me what am i doing wrong or what i should do..this is on a rebuilt motor ..i also oiled all cylinders with marvel mystery oil..to try and lube the cylinders..
Re: priming oil pump [Re: mopar70charger] #906599
01/16/11 05:36 PM
01/16/11 05:36 PM
5th and plum
redmist Offline
redmist  Offline
5th and plum
You need to rotate the crank by hand to get the oil passeges to line up??
Re: priming oil pump [Re: redmist] #906600
01/16/11 05:39 PM
01/16/11 05:39 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
AND.......make sure you are rotating the pump correctly
BB/ RB engines go "to the left" CCW
SB engines go "to the right" CW
Re: priming oil pump [Re: redmist] #906601
01/16/11 05:41 PM
01/16/11 05:41 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
yes..you need to rotate the engine by hand while turning the oil pump...
Tony
70 AARCuda Vitamin C
Re: priming oil pump [Re: 70AARcuda] #906602
01/16/11 05:43 PM
01/16/11 05:43 PM
louisiana
louisiana
are you saying rotate the crank with drill and the oil pump with drill at same time , bit confused
Re: priming oil pump [Re: mopar70charger] #906603
01/16/11 06:11 PM
01/16/11 06:11 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
rotate the crank by hand wrench or rachet on balancer bolt and oil pump with the drill
Re: priming oil pump [Re: mopar70charger] #906604
01/16/11 06:29 PM
01/16/11 06:29 PM
UK
602heavy Offline
602heavy  Offline
UK
Is this a big block? if so.....................#8 exhaust valve full lift puts oil to pas side head............#7 ex valve full lift puts oil to drivers side head............just makes life a bit easier when you have a drill in one hand & trying to rotate the engine with the other.
Re: priming oil pump [Re: 602heavy] #906605
01/16/11 06:35 PM
01/16/11 06:35 PM
Florida STAYcation
BeEtLeJuIcE ! Online penguin-006
The village idiot's idiot
BeEtLeJuIcE !  Online Penguin-006
Florida STAYcation
Have the GF or wife hold the drill ...and you go under and bar thew motor over slowly.
Re: priming oil pump [Re: 602heavy] #906606
01/16/11 07:07 PM
01/16/11 07:07 PM
Is this a big block? if so #8 exhaust valve full lift puts oil to pas side head.#7 ex valve full lift puts oil to drivers side head.
Been waiting for that for months! plus #8 is on the pass side so it will be easy to remem . Here's a good read (5 min) I would checkout "ring breakin" at www.mototuneusa.com b 4 you fire it
Re: priming oil pump [Re: RapidRobert] #906607
01/16/11 07:35 PM
01/16/11 07:35 PM
UK
602heavy Offline
602heavy  Offline
UK
You only had to ask...........got so p... off one day when trying to send oil to heads i just thought there's gotta be an easier way on a stock oiling system......
Re: priming oil pump [Re: 602heavy] #906608
01/16/11 08:03 PM
01/16/11 08:03 PM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
Dumb ? but won't turning the crank wipe the break in lube off the cam? I was always told to try not to turn the cam at all until initial fire up. Is this wrong? Thanks
Re: priming oil pump [Re: 440forPOWER] #906609
01/16/11 08:07 PM
01/16/11 08:07 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Turning it over a few times by hand while priming the oil system won't hurt the lube on the cam and lifters.
Re: priming oil pump [Re: Challenger 1] #906610
01/16/11 08:53 PM
01/16/11 08:53 PM
Correct; a (very) few times wont wipe enough of the goop off but I like to preoil/adj valves (if solids) then take off the valvetrain/goop the lobes/bottoms/replace valvetrain. The adj will not change more than an insignificant amt (if that) from a R&R but excessive turning will cause a prob from excessive wiping. Also have the batt up/several squirts in the carb/ign timing @10 BTDC & be sure the box is firing
