priming oil pump #906598
01/16/11 05:31 PM
01/16/11 05:31 PM
louisiana
mopar70charger Offline OP
louisiana
i am as of now trying to prime the oil pump with a oil pump priming tool with a drill , the oil filter was off until i noticed it starting to pour oil which it did, then i placed a oil filter back on the motor with oil in filter... but then i tried to get oil else where by priming it and i don't seem to see any especially around timing chain and or the top of the heads. i am using a 3/8 drill.. can someone tell me what am i doing wrong or what i should do..this is on a rebuilt motor ..i also oiled all cylinders with marvel mystery oil..to try and lube the cylinders..
Re: priming oil pump [Re: mopar70charger] #906599
01/16/11 05:36 PM
01/16/11 05:36 PM
5th and plum
redmist Offline
redmist  Offline
5th and plum
You need to rotate the crank by hand to get the oil passeges to line up??
Re: priming oil pump [Re: redmist] #906600
01/16/11 05:39 PM
01/16/11 05:39 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
AND.......make sure you are rotating the pump correctly
BB/ RB engines go "to the left" CCW
SB engines go "to the right" CW
Re: priming oil pump [Re: redmist] #906601
01/16/11 05:41 PM
01/16/11 05:41 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
yes..you need to rotate the engine by hand while turning the oil pump...
Tony
70 AARCuda Vitamin C
Re: priming oil pump [Re: 70AARcuda] #906602
01/16/11 05:43 PM
01/16/11 05:43 PM
louisiana
louisiana
are you saying rotate the crank with drill and the oil pump with drill at same time , bit confused
Re: priming oil pump [Re: mopar70charger] #906603
01/16/11 06:11 PM
01/16/11 06:11 PM
michigan
sturmenater Offline
sturmenater  Offline
michigan
rotate the crank by hand wrench or rachet on balancer bolt and oil pump with the drill
Re: priming oil pump [Re: mopar70charger] #906604
01/16/11 06:29 PM
01/16/11 06:29 PM
UK
602heavy Offline
602heavy  Offline
UK
Is this a big block? if so.....................#8 exhaust valve full lift puts oil to pas side head............#7 ex valve full lift puts oil to drivers side head............just makes life a bit easier when you have a drill in one hand & trying to rotate the engine with the other.
Re: priming oil pump [Re: 602heavy] #906605
01/16/11 06:35 PM
01/16/11 06:35 PM
Florida STAYcation
dOOc Offline
The village idiot's idiot
dOOc  Offline
Florida STAYcation
Have the GF or wife hold the drill ...and you go under and bar thew motor over slowly.
Re: priming oil pump [Re: 602heavy] #906606
01/16/11 07:07 PM
01/16/11 07:07 PM
Is this a big block? if so #8 exhaust valve full lift puts oil to pas side head.#7 ex valve full lift puts oil to drivers side head.
Been waiting for that for months! plus #8 is on the pass side so it will be easy to remem . Here's a good read (5 min) I would checkout "ring breakin" at www.mototuneusa.com b 4 you fire it
Re: priming oil pump [Re: RapidRobert] #906607
01/16/11 07:35 PM
01/16/11 07:35 PM
UK
602heavy Offline
602heavy  Offline
UK
You only had to ask...........got so p... off one day when trying to send oil to heads i just thought there's gotta be an easier way on a stock oiling system......
Re: priming oil pump [Re: 602heavy] #906608
01/16/11 08:03 PM
01/16/11 08:03 PM
Lincoln NE
440forPOWER Offline
super gas
440forPOWER  Offline
super gas
Lincoln NE
Dumb ? but won't turning the crank wipe the break in lube off the cam? I was always told to try not to turn the cam at all until initial fire up. Is this wrong? Thanks
Re: priming oil pump [Re: 440forPOWER] #906609
01/16/11 08:07 PM
01/16/11 08:07 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Turning it over a few times by hand while priming the oil system won't hurt the lube on the cam and lifters.
Re: priming oil pump [Re: Challenger 1] #906610
01/16/11 08:53 PM
01/16/11 08:53 PM
Correct; a (very) few times wont wipe enough of the goop off but I like to preoil/adj valves (if solids) then take off the valvetrain/goop the lobes/bottoms/replace valvetrain. The adj will not change more than an insignificant amt (if that) from a R&R but excessive turning will cause a prob from excessive wiping. Also have the batt up/several squirts in the carb/ign timing @10 BTDC & be sure the box is firing
