Re: Flywheel starter ring?
[Re: Pacnorthcuda]
#905231
01/15/11 03:55 PM
01/15/11 03:55 PM
Posts: 2,489 Pacifica, CA
Devilbrad
Pacifica, CA
Have you thought about removing the one thats on it and flipping it over?
I don't have one to begin with. I'm doing an experiment.
[Re: Cab_Burge]
#905233
01/15/11 04:37 PM
01/15/11 04:37 PM
Devilbrad
Pacifica, CA
I forgot to mention that the people I know who have change a ring gear put the flywheel or converter in a freezer overnight and put the ring gear in a oven just before installing it and warm the ring gear up to or over 300 F for twenty minutes or so, then they drop the ring gear on the flywheel or converter I have seen other guys them on also with no other prep than taking them out of the box and beating away Good luck
Yeah, I know its a interference fit, just need to find the specs. Let me tell you what I'm doing, LOL I'm gonna take a 143 tooth Magnum EFI flywheel with the crank sensor notches, knock its starter ring off, have the flywheel OD turned down, and install the 130 tooth LA ring so I can use aftermarket LA SFI approved (though with a hole cut in it for the crank sensor, it may not be legal anymore) bellhousings to swap to a TKO 600 or Tremec 3550 tranny. Wish me luck!
