Flywheel starter ring? #905228
01/15/11 03:50 PM
01/15/11 03:50 PM
Pacifica, CA
Devilbrad Offline OP
Pacifica, CA
Where can I buy just a starter ring for say a small block flywheel? Anyone know what the press fit specs are for these rings?
Re: Flywheel starter ring? [Re: Devilbrad] #905229
01/15/11 03:51 PM
01/15/11 03:51 PM
Try your local NAPA store or maybe your local Dodge dealership
Re: Flywheel starter ring? [Re: Devilbrad] #905230
01/15/11 03:53 PM
01/15/11 03:53 PM
Kirkland, Washington
Pacnorthcuda Offline
Have you thought about removing the one thats on it and flipping it over?
Re: Flywheel starter ring? [Re: Pacnorthcuda] #905231
01/15/11 03:55 PM
01/15/11 03:55 PM
Pacifica, CA
Pacifica, CA
I don't have one to begin with. I'm doing an experiment.
Re: Flywheel starter ring? [Re: Devilbrad] #905232
01/15/11 04:25 PM
01/15/11 04:25 PM
I forgot to mention that the people I know who have change a ring gear put the flywheel or converter in a freezer overnight and put the ring gear in a oven just before installing it and warm the ring gear up to or over 300 F for twenty minutes or so, then they drop the ring gear on the flywheel or converter I have seen other guys them on also with no other prep than taking them out of the box and beating away Good luck
Re: Flywheel starter ring? [Re: Cab_Burge] #905233
01/15/11 04:37 PM
01/15/11 04:37 PM
Pacifica, CA
Pacifica, CA
Yeah, I know its a interference fit, just need to find the specs. Let me tell you what I'm doing, LOL I'm gonna take a 143 tooth Magnum EFI flywheel with the crank sensor notches, knock its starter ring off, have the flywheel OD turned down, and install the 130 tooth LA ring so I can use aftermarket LA SFI approved (though with a hole cut in it for the crank sensor, it may not be legal anymore) bellhousings to swap to a TKO 600 or Tremec 3550 tranny. Wish me luck!
