blowing brake and dome light fuse in a 1970 Satellite #901094
01/10/11 01:25 PM
01/10/11 01:25 PM
Northeast Texas
W
wingedwarrior Offline OP
W
Northeast Texas
I recently bought a 1970 Satellite that is in very good original condition. It looks to not have ever been modified or messed with. However It will not take a fuse in the Stop lamp/dome light holder in the fuse box. It pops it as soon as you try to put it in. I checked all of the taillights and made sure the bulbs were in correctly. I also checked the dome light area to make sure there was no bare wires anywhere. Dome light bulb is missing. Any common problem that this might be? Thanks in advance.
Re: blowing brake and dome light fuse in a 1970 Satellite [Re: wingedwarrior] #901095
01/10/11 01:29 PM
01/10/11 01:29 PM
Under My Car
Mopar_Country Offline
Under My Car
Check your grounds by the tail lights. If it's popping as soon as you put it in I would think something is grounding that shouldn't be.
Re: blowing brake and dome light fuse in a 1970 Satellite [Re: wingedwarrior] #901096
01/10/11 01:32 PM
01/10/11 01:32 PM
Southern by Choice
Shoozy Offline
I have a foot fetish
Shoozy  Offline
Southern by Choice
Pull your dome light down and check for a dead short grounding out.
Old, tired, and sometimes broke down. Me, not my car...
Re: blowing brake and dome light fuse in a 1970 Satellite [Re: Shoozy] #901097
01/10/11 01:56 PM
01/10/11 01:56 PM
N.E Indiana
repad Offline
super street
repad  Offline
super street
N.E Indiana
You have a short somewhere in that circut, get yourself a wiring diagram and follow the wires in that circut with a tester until you find it.
Re: blowing brake and dome light fuse in a 1970 Satellite [Re: repad] #901098
01/10/11 02:08 PM
01/10/11 02:08 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
To test for a brake light short unplug the turn signal switch.
Re: blowing brake and dome light fuse in a 1970 Satellite [Re: stumpy] #901099
01/10/11 02:32 PM
01/10/11 02:32 PM
Montana
Y
Yancy Derringer Offline
Y
Montana
THIS
You need to separate the wiring into major areas. The other handy plug you can disconnect is the harness plug in the left kick panel, right before the rear harness goes under the doorsill.
Another "quickie" is to disconnect the brake light switch right at the switch.
As someone else said, you need to get a good diagram. There are all kinds of tricks in this circuit, like feeding the ign switch key buzzer, if you have a map light or console, some of the dome light stuff goes there.
"Check your grounds." No, sorry, NOT a ground problem. This is a short somewhere.
Re: blowing brake and dome light fuse in a 1970 Satellite [Re: Yancy Derringer] #901100
01/10/11 04:03 PM
01/10/11 04:03 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
I will agree with Yancy. If you pull the driver side kick panel, there are connections for the harness to the dome light. Disconnecting this harness will help you determine where the short is that you are trying to find.
Re: blowing brake and dome light fuse in a 1970 Satellite [Re: Yancy Derringer] #901101
01/10/11 04:30 PM
01/10/11 04:30 PM
Under My Car
Under My Car
I always suggest checking grounds with electrical issues. I went on to say "If it's popping as soon as you put it in I would think something is grounding that shouldn't be" meaning a dead short.
Re: blowing brake and dome light fuse in a 1970 Satellite [Re: Mopar_Country] #901102
01/10/11 05:07 PM
01/10/11 05:07 PM
Northeast Texas
W
W
Northeast Texas
Have been working on the problem today. I disconnected the rear harness..no help. Disconnected the stop light switch..no help. I then took the fuse panel out. I removed the terminal tree that held all of the extra lights ie; trunk light, dome light(pink wires) etc... did not help. I am now down to the black wire and the large red wire that supplies power. I am assuming the short might be in the black wire but it does not light up with tester. I have not disconnected the turn signal switch wiring harness yet. I am going to drop the column a little and do this next. I appreciate all of the help thus far.
Re: blowing brake and dome light fuse in a 1970 Satellite [Re: wingedwarrior] #901103
01/10/11 05:26 PM
01/10/11 05:26 PM
Montana
Y
Y
Montana
........... I am now down to the black wire and the large red wire that supplies power. I am assuming the short might be in the black wire but it does not light up with tester.
If this is the very large black and red wires going to the fuse box, you are on the wrong track. The red is "hot" feeding anything that is live / key off. the black is the feed coming from ign in accessory/ run, such as wipers, heater, etc.
The dome light wiring goes a LOT of places, depending on options, as I mentioned.
Have you disconnected the lighter? Should be able to get to it, maybe, by pulling out the ashtray. Been a few years for me.
If this turns into a nightmare, there is a couple more tricks. You used to be able to buy a "short tracer." This is essentially just like a turn signal blinker, and I guess a limiting resistor. You clipped it across the fuse, and the "blinker" turned the circuit on/ off. Then you can use a "detector" like a compass which reacts to heavy magnetic fields--which will be surrounding the shorted wire.
http://www.amazon.com/Tool-Aid-SGT25100-Short-Finder/dp/B002XMUGZC
Re: blowing brake and dome light fuse in a 1970 Satellite [Re: Yancy Derringer] #901104
01/10/11 05:50 PM
01/10/11 05:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You could save yourself a lot of time a wasted work if you used a wiring diagram to trace your problem because you are already way beyond where you should be looking. Here is a link to some diagrams. http://www.mymopar.com/index.php?pid=18
Re: blowing brake and dome light fuse in a 1970 Satellite [Re: wingedwarrior] #901105
01/10/11 06:16 PM
01/10/11 06:16 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Check the bulb in the dome light to be sure somebody hasn't installed a single contact bulb.
Re: blowing brake and dome light fuse in a 1970 Satellite [Re: John_Kunkel] #901106
01/10/11 07:10 PM
01/10/11 07:10 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
You should have read his first post. No dome light bulb.
Re: blowing brake and dome light fuse in a 1970 Satellite [Re: stumpy] #901107
01/10/11 09:28 PM
01/10/11 09:28 PM
Under My Car
Under My Car
Good catch Stumpy, maybe the contacts are grounding within the socket without the bulb in there if they slipped out of the little plate in there.
Re: blowing brake and dome light fuse in a 1970 Satelli [Re: Mopar_Country] #901108
01/17/11 03:48 AM
01/17/11 03:48 AM
Verdigris, Ok
sooner440 Offline
sooner440  Offline
Verdigris, Ok
I am having the SAME exact problem with my '69 Satellite. Have you found anything yet? Kinda can't drive it without brake lights .
69 2dr Satellite, 70 Charger, 69 GTX
Re: blowing brake and dome light fuse in a 1970 Satelli [Re: sooner440] #901109
01/19/11 12:04 AM
01/19/11 12:04 AM
Verdigris, Ok
sooner440 Offline
sooner440  Offline
Verdigris, Ok
TTT
Re: blowing brake and dome light fuse in a 1970 Satelli [Re: sooner440] #901110
01/19/11 12:29 AM
01/19/11 12:29 AM
Scituate, RI
SkynyrdTim Offline
SkynyrdTim  Offline
Scituate, RI
Any holes in your headliner? I had a dome light problem once and it was caused by a bare wire leading to the dome light. Some rotten mouse had chewed a hole in my headliner and munched on the dome light wire casing. On my 72 RR, I think the pink wire powers the dome light, glove box light and cigarette lighter. I would start at the dome light wire and work back to the cigarette lighter.
Re: blowing brake and dome light fuse in a 1970 Satelli [Re: SkynyrdTim] #901111
01/19/11 02:16 AM
01/19/11 02:16 AM
Verdigris, Ok
sooner440 Offline
sooner440  Offline
Verdigris, Ok
Ok, there is a hole in the headliner and there was a dead mouse in the car when I bought it. I'll start with removing the dome light bulb and see what the fuse does when I put it in. According to the factory wiring diagram this fuse also goes to the hazard flashers, glove box light, map light, clock, and trunk light. Guess I can narrow this down to which one is the problem one at a time by removing the bulb or unplugging the plug to each one and see what the fuse does. Can it be this simple?
Re: blowing brake and dome light fuse in a 1970 Satelli [Re: sooner440] #901112
01/19/11 03:04 PM
01/19/11 03:04 PM
Scituate, RI
SkynyrdTim Offline
SkynyrdTim  Offline
Scituate, RI
I'm sticking with the dome light wire. The pink wire is probably bare somewhere between the dome light and the glove box. It's shorting out because it's touching metal or the other wire that leads to the dome light. The yellow wire might have been chewed as well.
I solved this problem by ripping out the old headliner. I fixed the damaged wire and put in a new headliner. I'm sure you don't want to do that, but it may be hard to find the bare spot on the wire without taking the old headliner down. You could cut the wires going to the dome light and see if that works. Not recommended, but it might work and not having a dome light isn't the end of the world. Good luck.
Re: blowing brake and dome light fuse in a 1970 Satelli [Re: SkynyrdTim] #901113
01/19/11 03:35 PM
01/19/11 03:35 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
You can eliminate the dome lamp wires by unplugging the 2 pin connector over the left wheel house accessed through the trunk.... White connector, yellow & pink wires...
