Gear Drive VS Belt Drive #900277
01/09/11 03:24 PM
01/09/11 03:24 PM
Alexandria, LA
Blucuda413 Offline OP
Alexandria, LA
Building a 528 14-71 blown hemi. Which is best to use in this situation a gear or belt drive?? I've had very good service out of gear drives in my swmallblocks. Hemi will not be a street engine but will not be max'd out either.
Re: Gear Drive VS Belt Drive [Re: Blucuda413] #900278
01/09/11 03:28 PM
01/09/11 03:28 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
Sounds suspiciously like a TA/D arrangement.
What do they like ?
I am no authority , but think the gear makes more sense based the layout.
Chucking the big belt could make things worse with an open belt drive and I am not aware of a closed one for a Hemi.
Re: Gear Drive VS Belt Drive [Re: Blucuda413] #900279
01/09/11 03:38 PM
01/09/11 03:38 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
A gear drive will transmit harmonics UP TO the valve train ....a belt will not.
If $$$ are not an issue ..I would go with a belt.
Re: Gear Drive VS Belt Drive [Re: BeEtLeJuIcE !] #900280
01/09/11 04:07 PM
01/09/11 04:07 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Belts break/stretch.... gears don`t .
Rock ....Paper ....Scissors .......................
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: Gear Drive VS Belt Drive [Re: chryco] #900281
01/09/11 04:30 PM
01/09/11 04:30 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
When i put my blower on i took the cam belt drive off for safety. Blower belts can rip frey or whatever.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Gear Drive VS Belt Drive [Re: Blucuda413] #900282
01/09/11 08:21 PM
01/09/11 08:21 PM
I have not heard a 14:71 driven on the street with mufflers so I'm not sure how much noise they will make, probally depends if you underdrive or overdrive it My point is that the gear drives make noise, the blowers make noise and some people, especially the street car people are impress by both visual and audible inputs I have built several blown 426 Street Hemi, ran them on the engine dyno but not in the cars, one was a Motech EFI with a Littlefield stage 3 10:71 499 C.I. all alulmium KB block and the other was another stage 3 Littefield with a set of 1050 CFM Carb Shop blower domiator carbs,484 C.I. new iron mopar 426 block, both surged around 600 RPM hgh to low at idle at first until I tuned the surge out of them I had to tune the surging back into both motors for the owners after the dyno testing
Re: Gear Drive VS Belt Drive [Re: Cab_Burge] #900283
01/09/11 08:24 PM
01/09/11 08:24 PM
Alexandria, LA
Alexandria, LA
Cab, it is "NOT" going to be a street engine.
Re: Gear Drive VS Belt Drive [Re: Blucuda413] #900284
01/09/11 08:27 PM
01/09/11 08:27 PM
Oops In that case go with the belt drive I have a Jesel on my 527 bracket motor, it wouldn't be hard to make a thin cover to keep debris out of the belt
Re: Gear Drive VS Belt Drive [Re: Blucuda413] #900285
01/09/11 08:59 PM
01/09/11 08:59 PM
Florida STAYcation
Florida STAYcation
On a milder blower motor ... I would not worry about shredding belts and having that trash get-into a cam belt-drive.
Re: Gear Drive VS Belt Drive [Re: BeEtLeJuIcE !] #900286
01/09/11 10:11 PM
01/09/11 10:11 PM
Left Coast
BobR Offline
BobR  Offline
Left Coast
Our new BAE motor came with a gear drive so I assume that's what they recommend. I have it in my bedroom. Looks real expensive.
Re: Gear Drive VS Belt Drive [Re: BobR] #900287
01/09/11 10:44 PM
01/09/11 10:44 PM
nc
moeflo Offline
moeflo  Offline
nc
I've got an old Engine Masters mag around here somewhere. They tested the chains vs. belts, vs. gear drives. The gear drives were equal, or slightly better on the dyno. With magazine politics, I wouldn't bet the farm. But gear drives seem to be the standard on blown hemis. One less thing to worry about...
Re: Gear Drive VS Belt Drive [Re: BobR] #900288
01/09/11 10:52 PM
01/09/11 10:52 PM
Florida STAYcation
Florida STAYcation
Since I don't have a BAE motor ...and have no plans on it ... I ... to your knowledge of the situation ..
Re: Gear Drive VS Belt Drive [Re: BobR] #900289
01/10/11 01:33 AM
01/10/11 01:33 AM
Be careful of what you do with that thing in your bedroom I'll tell Doug
