Re: Gear Drive VS Belt Drive
[Re: BeEtLeJuIcE !]
#900280
01/09/11 04:07 PM
01/09/11 04:07 PM
Posts: 866 Winnipeg ,Mb. CA.
chryco
Winnipeg ,Mb. CA.
Belts break/stretch.... gears don`t .
Rock ....Paper ....Scissors .......................
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
[Re: chryco]
#900281
01/09/11 04:30 PM
01/09/11 04:30 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
When i put my blower on i took the cam belt drive off for safety. Blower belts can rip frey or whatever.
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: Blucuda413]
#900282
01/09/11 08:21 PM
01/09/11 08:21 PM
Posts: 43,205 Bend,OR USA
Cab_Burge
Building a 528 14-71 blown hemi. Which is best to use in this situation a gear or belt drive?? I've had very good service out of gear drives in my swmallblocks. Hemi will not be a street engine but will not be max'd out either.
I have not heard a 14:71 driven on the street with mufflers so I'm not sure how much noise they will make, probally depends if you underdrive or overdrive it My point is that the gear drives make noise, the blowers make noise and some people, especially the street car people are impress by both visual and audible inputs I have built several blown 426 Street Hemi, ran them on the engine dyno but not in the cars, one was a Motech EFI with a Littlefield stage 3 10:71 499 C.I. all alulmium KB block and the other was another stage 3 Littefield with a set of 1050 CFM Carb Shop blower domiator carbs,484 C.I. new iron mopar 426 block, both surged around 600 RPM hgh to low at idle at first until I tuned the surge out of them I had to tune the surging back into both motors for the owners after the dyno testing
[Re: Blucuda413]
#900285
01/09/11 08:59 PM
01/09/11 08:59 PM
Posts: 30,431 Florida STAYcation
BeEtLeJuIcE !
The village idiot's idiot
Florida STAYcation
On a milder blower motor ... I would not worry about shredding belts and having that trash get-into a cam belt-drive.
[Re: BeEtLeJuIcE !]
#900286
01/09/11 10:11 PM
01/09/11 10:11 PM
Posts: 8,165 Left Coast
BobR
Left Coast
Our new BAE motor came with a gear drive so I assume that's what they recommend. I have it in my bedroom. Looks real expensive.
[Re: BobR]
#900288
01/09/11 10:52 PM
01/09/11 10:52 PM
BeEtLeJuIcE !
Florida STAYcation
Since I don't have a BAE motor ...and have no plans on it ... I ... to your knowledge of the situation ..
