6 lobes off a camshaft?!? #898501
01/07/11 12:03 PM
01/07/11 12:03 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
What would cause 6 lobes on the camshaft to get rounded off? (590 lift purple flat tappet) We used proper breakin procedure(25 min @ 3000)valve lash was never too tight. We were wondering if it could be defective camshaft? Any opinions would be appreciated!
Re: 6 lobes off a camshaft?!? [Re: Jonnyj00] #898502
01/07/11 12:13 PM
01/07/11 12:13 PM
Eighty Four, PA
B G Racing Offline
B G Racing  Offline
Eighty Four, PA
2 things come to mind,something wasn't right and 25 minutes at 3000 rpm.Seriously,for six lobes to wear off,I would look at proper oiling and ajustments.What did you lube the cam and lifters with?Did you prime the oil system before starting?Are the spring pressures,and assemble heights and clearences correct?
Re: 6 lobes off a camshaft?!? [Re: B G Racing] #898503
01/07/11 12:20 PM
01/07/11 12:20 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
We installed the camshaft and lifters all with break-in oil and checked the valves several times with the specs out of mopar performance book! As far is a i know all neccesarry steps were taken.
Re: 6 lobes off a camshaft?!? [Re: Jonnyj00] #898504
01/07/11 01:02 PM
01/07/11 01:02 PM
MI, Lapeer
maximus Offline
maximus  Offline
MI, Lapeer
Check your valve spring height. Could be coil-binding.
Re: 6 lobes off a camshaft?!? [Re: maximus] #898505
01/07/11 01:04 PM
01/07/11 01:04 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
What was your spring PSI, did you remove the inner spring? did you use break in oil or a zink additive?
Re: 6 lobes off a camshaft?!? [Re: maximus] #898506
01/07/11 01:06 PM
01/07/11 01:06 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
Im quite sure the valve set up was good Dave @ mid american race engines worked on the heads and set them all up so im sure all that was good
Re: 6 lobes off a camshaft?!? [Re: ademon] #898507
01/07/11 01:10 PM
01/07/11 01:10 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
we used break in oil that they recomended with the cam.
Re: 6 lobes off a camshaft?!? [Re: Jonnyj00] #898508
01/07/11 01:13 PM
01/07/11 01:13 PM
Erda, UT
67Charger Offline
67Charger  Offline
Erda, UT
Did you remove the inner springs for break in? Anything over about 250 open is asking for trouble. A lesson I learned the hard way too.
11.33 @ 118.46 on motor
10.75 @ 125.35 w/ a little spray
Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race
Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
Re: 6 lobes off a camshaft?!? [Re: Jonnyj00] #898509
01/07/11 01:14 PM
01/07/11 01:14 PM
Get-X Offline
Get-X  Offline
How old was the cam? Was it sitting around on a shelf for a while? MP had soft core problems through out the '90's. Not sure if it ever got corrected as I've been gone from there since 2000.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: 6 lobes off a camshaft?!? [Re: 67Charger] #898510
01/07/11 01:15 PM
01/07/11 01:15 PM
Get-X Offline
Get-X  Offline
Good point, lots of cams wiped from this as well.
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: 6 lobes off a camshaft?!? [Re: Get-X] #898511
01/07/11 01:43 PM
01/07/11 01:43 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
The cam was new from summit. As far as i know we did not remove inner springs so that very well could be it...
Re: 6 lobes off a camshaft?!? [Re: Jonnyj00] #898512
01/07/11 01:59 PM
01/07/11 01:59 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
did this happen during breakin or after some miles were put on it?
Re: 6 lobes off a camshaft?!? [Re: 67Charger] #898513
01/07/11 02:13 PM
01/07/11 02:13 PM
NW of Indy
Thackdaddy Offline
Thackdaddy  Offline
NW of Indy
'71 Duster
Re: 6 lobes off a camshaft?!? [Re: sixpackgut] #898514
01/07/11 02:14 PM
01/07/11 02:14 PM
hooziewhatsit Offline
When you put the lifters in, did they go in smoothly, or take a little work? If they don't spin when the engine is running, the cam will wipe in no time
(when you took them out, how much force did it take?)
Re: 6 lobes off a camshaft?!? [Re: hooziewhatsit] #898515
01/07/11 02:25 PM
01/07/11 02:25 PM
SE Iowa
Jonnyj00 Offline OP
Jonnyj00  Offline OP
SE Iowa
we made one half pass on the motor is all we went. The block was all machined up and good went in very smooth. when we took it apart the bottom of some of the lifters looked about like the cam lobes all busted up.
Re: 6 lobes off a camshaft?!? [Re: 67Charger] #898516
01/07/11 02:36 PM
01/07/11 02:36 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Same thing happened to me years back and after re-honeing,new bearings,rings oil pump etc, we broke in the next cam w/a lighter spring and that motor lasted me 5+ years street/strip.
Re: 6 lobes off a camshaft?!? [Re: Thumperdart] #898517
01/07/11 04:04 PM
01/07/11 04:04 PM
Central Valley, CA.
Quicksilver440 Offline
Central Valley, CA.
The best thing to do after assembly is to turn the motor over by hand and make sure all the lifters are rotating before startup.
I've had some barely rotate and I just swap the lifters around until I get good rotation on all of them.
Re: 6 lobes off a camshaft?!? [Re: Quicksilver440] #898518
01/07/11 05:25 PM
01/07/11 05:25 PM
nc
E
emarine01 Offline
emarine01  Offline
E
nc
God bless roller cams...
Re: 6 lobes off a camshaft?!? [Re: emarine01] #898519
01/07/11 05:47 PM
01/07/11 05:47 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
Roller lifters come apart too, albeit not at break-in.
Solids take a bad rap from improper break-in/installation. This is just another case of improper break-in (likely too much spring pressure over the nose).
I'd add EDM lifters (in addition to pulling the inner spring) to the rebuild next time (assuming it gets rebuilt).
Re: 6 lobes off a camshaft?!? [Re: Jonnyj00] #898520
01/07/11 10:07 PM
01/07/11 10:07 PM
fresno ca
mikeysmopars Offline
fresno ca
Buddy of mine just put that same came in a 440 and called Mopar Performance and talked to one of the tech guys and walked him through the whole break in at 3000 for 30 minutes with all the zink and break in oils and still had one go flat. They actually warrantied the cam package!!!
Founder and CEO of the Central Valley Mopar Drag Pack
