Re: 6 lobes off a camshaft?!?
[Re: Jonnyj00]
#898502
01/07/11 12:13 PM
01/07/11 12:13 PM
Posts: 9,910 Eighty Four, PA
B G Racing
Eighty Four, PA
What would cause 6 lobes on the camshaft to get rounded off? (590 lift purple flat tappet) We used proper breakin procedure(25 min @ 3000)valve lash was never too tight. We were wondering if it could be defective camshaft? Any opinions would be appreciated!
2 things come to mind,something wasn't right and 25 minutes at 3000 rpm.Seriously,for six lobes to wear off,I would look at proper oiling and ajustments.What did you lube the cam and lifters with?Did you prime the oil system before starting?Are the spring pressures,and assemble heights and clearences correct?
[Re: Jonnyj00]
#898508
01/07/11 01:13 PM
01/07/11 01:13 PM
Posts: 3,031 Erda, UT
67Charger
Erda, UT
Did you remove the inner springs for break in? Anything over about 250 open is asking for trouble. A lesson I learned the hard way too.
11.33 @ 118.46 on motor 10.75 @ 125.35 w/ a little spray Now, high Speed Open Road Racing - Silver State Classic Challenge, Nevada Open Road Challenge, Big Bend Open Road Race Rocky Mountain Race Week 2020, 2022 2.0, Sick Week 2023
[Re: Jonnyj00]
#898509
01/07/11 01:14 PM
01/07/11 01:14 PM
Posts: 614 Michigan
Get-X
How old was the cam? Was it sitting around on a shelf for a while? MP had soft core problems through out the '90's. Not sure if it ever got corrected as I've been gone from there since 2000.
'65 Belvedere '68 GTX '57 Dodge pickup
[Re: Jonnyj00]
#898512
01/07/11 01:59 PM
01/07/11 01:59 PM
Posts: 9,225 Charleston
sixpackgut
Drag Week Mod Champion
Charleston
did this happen during breakin or after some miles were put on it?
Gen 3 power 6.22@110, 9.85@135 Follow @g3hemiswap on instagram
[Re: sixpackgut]
#898514
01/07/11 02:14 PM
01/07/11 02:14 PM
Posts: 3,884 Oregon
hooziewhatsit
When you put the lifters in, did they go in smoothly, or take a little work? If they don't spin when the engine is running, the cam will wipe in no time (when you took them out, how much force did it take?)
[Re: emarine01]
#898519
01/07/11 05:47 PM
01/07/11 05:47 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
Roller lifters come apart too, albeit not at break-in. Solids take a bad rap from improper break-in/installation. This is just another case of improper break-in (likely too much spring pressure over the nose). I'd add EDM lifters (in addition to pulling the inner spring) to the rebuild next time (assuming it gets rebuilt).
