What are our options? #896065
01/04/11 01:38 PM
01/04/11 01:38 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
I have been in the market for a new K frame for quite some time. After visiting several forums getting in debates about whats right and whats wrong who's is best etc..These are a few competitors on the block. If you where in market for a K frame which of these two would you prefer and why?
Here are a few that are our options:
http://www.yellowbullet.com/forum/showthread.php?t=238442
https://board.moparts.org/ubbthreads/show...e=0#Post6377969
http://www.magnumforceracing.com/store/d...arch=&Page=
Jason
Re: What are our options? [Re: W9 Dart] #896066
01/04/11 01:44 PM
01/04/11 01:44 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What's the intended use of the car ? a street only car , a street/track car and a track only car will net you different responses .
Re: What are our options? [Re: JohnRR] #896067
01/04/11 01:49 PM
01/04/11 01:49 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
I will use it for Street/ Strip 30/70.... nothing long distance.
Re: What are our options? [Re: W9 Dart] #896068
01/04/11 03:38 PM
01/04/11 03:38 PM
What year and make car, A,B,E or C body ? I have a aftermarket tubular stock replacement K member for a early(pre 1967) A body that weighs one pound lighter than the stock K member . I'm going to send it back to have it modified to a front rack and remove the stock steering box mounts and stock engine mounts,( I'm using a front motor plate for a BB) remove the torsion bars and so on. I'm hoping those changes will lighten it up some
Re: What are our options? [Re: Cab_Burge] #896069
01/04/11 04:00 PM
01/04/11 04:00 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
It's for my 68 Dart.
Re: What are our options? [Re: W9 Dart] #896070
01/04/11 05:49 PM
01/04/11 05:49 PM
Look at CAP or RMS, or contact Bondo Bob for your car I'm switching my 1965 dart to coil overs with front rack and pinion steering for header clearnaces for the BB, not the weight savings. I do have a Strange Engineering front disc brake conversion kit for the car using the stock nine inch spindles so some weight will come of of the brakes, not sure how much I bought the Strange kit for the stopping power
Re: What are our options? [Re: Cab_Burge] #896071
01/04/11 06:19 PM
01/04/11 06:19 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
I have talked to them already... but I want to know more about the products I posted in the 1st post. What are your thoughts on them?
Jason
Re: What are our options? [Re: W9 Dart] #896072
01/04/11 06:33 PM
01/04/11 06:33 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Jason
I would stay away from the magnum force stuff. The Overkill race cars stuff looks awesome. I would not hesitate to order by the looks of it. If I had the cash one from overkill would be headed my way.
One day I will have something cool here.
Re: What are our options? [Re: W9 Dart] #896073
01/04/11 06:46 PM
01/04/11 06:46 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
look at the youtube vid on my sig,that's how my RMS performed at the 1st test/tune..did no adjustments other then follow the directions BILL GIVES u in the package..only thing that was done was a wheel aligh from my friend BIG DRE!
Re: What are our options? [Re: W9 Dart] #896074
01/04/11 06:54 PM
01/04/11 06:54 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
What happened????
I thought you and Tory were buddies?? It seemed like you were dead set on buying his setup and it was gods gift to K frames
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: What are our options? [Re: sdaurity] #896075
01/04/11 07:43 PM
01/04/11 07:43 PM
WI.
Scotts71chall Offline
WI.
Why stay away from magnum force?
Re: What are our options? [Re: DemonDust] #896076
01/04/11 07:46 PM
01/04/11 07:46 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I have a extra alterkation, 2500.00 and your stock one.
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: What are our options? [Re: Scotts71chall] #896077
01/04/11 08:15 PM
01/04/11 08:15 PM
North Cackilacky
sdaurity Offline
sdaurity  Offline
North Cackilacky
Its just junk, is cracked, drives bad, just not very nice. I'm sure others will respond about them too.
Re: What are our options? [Re: bigtimeauto] #896078
01/04/11 09:33 PM
01/04/11 09:33 PM
St. Paul , Mn.
tubtar Offline
tubtar  Offline
St. Paul , Mn.
If this has all the candy , it is a screaming deal.
I spoke with Bill when I got mine and we " negotiated " a decent discount and it was more than this.
I liked the RMS piece because it came with everything , and had options available re; sway bar , motor mounts , shocks , brakes so you could tailor it to any potential use.
Everything I read was positive and once I got it , I knew it was the good stuff.
Re: What are our options? [Re: DemonDust] #896079
01/04/11 09:37 PM
01/04/11 09:37 PM
United States
W
W9 Dart Offline OP
W9 Dart  Offline OP
W
United States
What happened????
I still am "buddies" with Tory. I also would like to know what your opinions are on the listed K frames. It just seems there are so many options out there it's hard to decide on one. I know a lot about Tory's K frame but don't know much about the other two. They all look pretty identical to me. You guys had quite a bit of knowledge on K frames so I was just asking.
Jason
Re: What are our options? [Re: fishy340] #896080
01/04/11 09:59 PM
01/04/11 09:59 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Awbdart, that vid was great!! That RMS performed perfect. The vid of the steering wheel on the run says alot!
W9/Jason of the 3 K Frames you listed, Id say None of the above.
The first one, has never been tested or seen any track or road time yet. As stated by the builder.
The second one, with the builders lack of response in his thread, before the sale. Scratch that one.
The third one, Ive heard nothing but bad stories about. Like breaking by just doing burnouts in a Burger King parking lot.
As far as some other proven options, RMS, Altercation, Bobs ProFab, Or just lighten and refab the stock one. mike
Re: What are our options? [Re: W9 Dart] #896081
01/04/11 10:06 PM
01/04/11 10:06 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I haven't heard a good thing about the Magnum force kits, but they were the first of their kind and many others have made their own kits. The other two look to be well built kits as far as fabrication goes, although I don't like the look of the steering arms and ball joints in the overkill product. It's something that will change no doubt as he is in the early stages of development. Bob's front end seems to be a proven product, whereas the Overkill and Tory's product are new kids on the block so to speak. That's not a bad thing if you're prepared to work with either guy to help make any improvements if necessary.
Aesthetics do play a big part for most of us, some may prefer a completely tubular K-Frame (myself included), some may just want a product that works.
Either way, hats off to all of those who produce these front end kits as they would consume a bunch of time for what can be at times, very little reward.
Alan Jones
Re: What are our options? [Re: Sport440] #896082
01/04/11 10:12 PM
01/04/11 10:12 PM
LONG ISLAND
fishy340 Offline
fishy340  Offline
LONG ISLAND
why thankyou mr440,i have nothing to gain by touting the rms,i just like to give props where it is do,and also support local mopar dudes!
Re: What are our options? [Re: LA360] #896083
01/04/11 10:22 PM
01/04/11 10:22 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Allan, I was going to mention the steering arms too on the Overkill K frame. No doubt they will most likely be changed out as you state. Everything looked great until I saw those. Mike
Re: What are our options? [Re: fishy340] #896084
01/04/11 10:39 PM
01/04/11 10:39 PM
Sask, Can.
72demon416 Offline
72demon416  Offline
Sask, Can.
Andy, is your steering column loose in that vid?
