1970 440 motor with rpm @ idle that wont remain same #890887
12/28/10 10:52 PM
12/28/10 10:52 PM
north palm florida united stat...
mopar0723 Offline OP
I have a 440 that has a set of six pack carbs and if you set idle @ say 850 then rev it at the carb a few times then let go it will not go back to 850 usually 1000 to 1100 and the spring is bringing the linkage back to the stop.sometimes comes back to the 900's or so.
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: mopar0723] #890888
12/29/10 12:02 AM
12/29/10 12:02 AM
Is it possible that the throttle blades are hanging up just a very slight bit, not enough to be visually seen at the throttle stop position but enough to make the change in speed you are seeing? I'd measure the EXACT distance between a point on the throttle linkage and a fixed point on the carb body to confirm/elim. Your positive nothing is hanging up the throttle (choke/fast idle etc) are all off/not interfering in any way
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: RapidRobert] #890889
12/29/10 12:06 AM
12/29/10 12:06 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Are you running a MP electronic ignition??
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: RapidRobert] #890890
12/29/10 12:14 AM
12/29/10 12:14 AM
I will check all of those out soon thanks,I thought when I mounted carbs on intake I looked in there to make shure not hanging up at gasket.
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: 1_WILD_RT] #890891
12/29/10 12:15 AM
12/29/10 12:15 AM
yes it is
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: mopar0723] #890892
12/29/10 12:18 AM
12/29/10 12:18 AM
It might be hanging up on the bore. Holler when you find something and welcome to Moparts
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: mopar0723] #890893
12/29/10 12:26 AM
12/29/10 12:26 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
yes it is
If this answer was directed to my question "Are you running a MP electronic ignition?? " then whats going on is the MP distributor has springs that allow the timing to start advancing at such a low RPM that you can't get a consistent idle... The engine idles at 750-800 rpm then a slight rpm increase causes the timing to advance.. More timing means the idle increases.. Higher idle brings in more timing... You need a slightly heavier light spring so timing doesn't start coming in till 11-1200 rpm.. To confirm this hook up a timing light & watch the timing as the car does it's goofy idle thing... BTW another common issue is you set the idle then when you drop thew car in gear it stalls because when the rpms dropped slightly the timing falls out which causes the rpms to fall even further...
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: 1_WILD_RT] #890894
12/29/10 12:37 AM
12/29/10 12:37 AM
ok thanks I will hook up lite and make note of what happens and when and will be back to you,also just so you know I did have intake off and distributor out when we freshened up motor but not shure if it was doing this before or not car was sitting a long time, but this does not sem like a vacum leak issue to you ?
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: mopar0723] #890895
12/29/10 12:41 AM
12/29/10 12:41 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Vacuum leak could cause it but before getting to involved in looking for that throw a timing light at it....
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: mopar0723] #890896
12/29/10 12:42 AM
12/29/10 12:42 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Is the vacuum advance connected??
If yes, you may want to try disconnecting/plugging and see what happens...
Just my $0.02..
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: Sinitro] #890897
12/29/10 12:45 AM
12/29/10 12:45 AM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
Front or rear carb opening slightly, throttle cable too tight, vac leak, distributor advance hanging up.......
The first thing I'd do is pull the throttle cable off and see if it is better. If that doesn't change it, I'd pull the linkage on the front and rear carbs (vacuum off, too - that is if I remember correctly how the vacuum secondaries work).
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: Sinitro] #890898
12/29/10 12:48 AM
12/29/10 12:48 AM
yes at one point I think I did that disconnected hose and plugged it but the rpm at idle did not change,also was told at one point to know if I have a vacum leak was to disconnect pcv line and see if I feel suction and if there is I have a vacum leak , i did it and did not feel any suction. when I hooked vacum gauge up had about 13 lbs @ idle but was bouncing around a bit say 12 3/4 to about 13 1/2 I do not know if that is normal.needle was not steady.
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: Jim_Lusk] #890899
12/29/10 12:53 AM
12/29/10 12:53 AM
I will check that to thanks alot.
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: mopar0723] #890900
12/29/10 02:38 PM
12/29/10 02:38 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Every sixpack I have tuned leaves my house running better than when it arrived. I would try adjusting the front & rear carbs. There are adjustment screws in the front of the base plates. May have to pull out the lead plugs if original. I made a long thin screw driver type tool out of a piece of coat hanger & flatened the end like a screwdriver so I don't have to remove any of the three carbs to tune. This was the cure for mine.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: 1_WILD_RT] #890901
12/29/10 03:55 PM
12/29/10 03:55 PM
hooziewhatsit Online content
hooziewhatsit  Online Content
Look at the timing. My 318 did the same thing and drove me nuts. Finally installed a slightly heavier spring, and it's been fine since.
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: hooziewhatsit] #890902
01/01/11 10:23 PM
01/01/11 10:23 PM
Here is what I found after doing some checks. First I did disconnect throttle cable, when I set motor at about 780 rpm ( to low ) and hit the throttle it will come back to about that (bounces around about 20 revs either way. Then if I set rpm to 850 where I want it then hit throttle she will not come back to that stays about 1150 - 1250 rpm then I have to loosen idle screw to get it back down or when I unplug the vac line @ the distributor and plug with my finger then the car idles down. so in short with the vacum line plugged I can set idle @ 850 then rev it and it will return but still searches around give or take 20 rpm or so. some notes on what i am working with=
craftsman top of the line digital timing lite with the tach option.
at 800 rpm I have timing at about 10.5 car seems to start easy and run strong here. checking the vacum I am plugging in at rear of intake where brake boost hose goes.
at 800 rpm I have between 7-8 on the vacum,( bounces between the two ) do not know if this is sufficient or if the bouncing is normal ?
also noticed when i advance throttle slowly vacum will dip low to about 2 or so then takes off, went to 2200rpm and vacum went to 21 + also not shure if this is normal. any thoughts/ advice would be much appriciated,
Hope you guys all have a happy new year
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: mopar0723] #890903
01/02/11 02:50 AM
01/02/11 02:50 AM
plug the vac adv & set the idle sp at ~750 & check how much initial you have and raise the idle speed slowly to ~950 & see if it advances to see if it is into the mech curve at your desired 850 rpm
Re: 1970 440 motor with rpm @ idle that wont remain same [Re: RapidRobert] #890904
01/02/11 10:32 AM
01/02/11 10:32 AM
Indiana
mt162 Offline
mt162  Offline
Indiana
Is your vacuum advance hooked up to manifold vacuum? It needs to be hooked up to a ported vacuum source.
