Front or rear carb opening slightly, throttle cable too tight, vac leak, distributor advance hanging up.......
The first thing I'd do is pull the throttle cable off and see if it is better. If that doesn't change it, I'd pull the linkage on the front and rear carbs (vacuum off, too - that is if I remember correctly how the vacuum secondaries work).
