This might make ya laugh #890251
12/28/10 02:35 PM
12/28/10 02:35 PM
Finally a HUSKER again
Moparnut426 Offline OP
I know Mickey Thompson did this, but I spoke with an engine builder, who is know for major failures, he was in my shop getting parts. Well, I was showing him my Demon build, hes a chevy guy, and didnt really care, but I was telling him I have to clearance a little bit on the push rod holes. Indybrocks have an offset rocker, and they are too close for comfort on the bottoms of the heads. Get this, He accually told me to stick the pushrods in a press and bend them just a touck to clear the heads. I said these are custom manton pushrods, and I dont want to shorten them, and I thought he was NUTS for blurting out that. He said they wont get shorter, At this time thank god the phone rang for service.
I couldnt believe what I heard outa his mouth.
Just goes to show ya that you have to reserch everything you have done anymore. If I took this guys shop a slug of race parts to build me an engine, and I heard this outa his mouth, Id load it up, and drive off QUICKLY!!!
Just thought you guys would find this funny.
KAsey
Re: This might make ya laugh [Re: Moparnut426] #890252
12/28/10 02:39 PM
12/28/10 02:39 PM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Pre bent push rods I like it!
Re: This might make ya laugh [Re: Moparnut426] #890253
12/28/10 02:51 PM
12/28/10 02:51 PM
Backwater, PA
bwdst6 Offline
Bob George Racing #1 Fan
bwdst6  Offline
Backwater, PA
Sounds like another job for the venerable BFH!
This post is available in double vision where drunk.
Re: This might make ya laugh [Re: bwdst6] #890254
12/28/10 03:01 PM
12/28/10 03:01 PM
Well this is the same guy who told one of my customers to straighten his bent pushrod in his 360 mopar. He said mopars have a better pushrod geometry and are easier on them so if one is straightened its should be fine. He honestly is a kill to listen too.
He is one of those guys who doesnt have much of a variation in his talk and ya dont ever know if he is serious or not, but when he starts talkin about his sbc stuff he gets really amped.
Very funny, I should record his someday, that would be a little illegal i think, but funny as hell on here.
Kasey
Re: This might make ya laugh [Re: Moparnut426] #890255
12/28/10 03:09 PM
12/28/10 03:09 PM
Cab_Burge Online work
Cab_Burge  Online Work
Kasey
What works on a SB Chevy definitely doesn't work on a Ford or Mopar not for long at least if you follow his suggestions He must not be a farmer, they have a lot of common sense
Re: This might make ya laugh [Re: Cab_Burge] #890256
12/28/10 03:20 PM
12/28/10 03:20 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Well if you bend it besure you gusset the back side of it to reduce flex LOL.
68 Barracuda Formula S 340
Re: This might make ya laugh [Re: Moparnut426] #890257
12/28/10 03:31 PM
12/28/10 03:31 PM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
Actually, I'm will to bet he was just pulling your chain to see what kind of reaction he's get.
Kinda like when I told an old-timer know-it-all I had a of Metric tube cutter tool. He was pizzed I had a tool he didn't have....
Re: This might make ya laugh [Re: Commando1] #890258
12/28/10 03:41 PM
12/28/10 03:41 PM
Backwater, PA
bwdst6 Offline
bwdst6  Offline
Backwater, PA
Actually, knowing Indy they probably intended this modification!
Re: This might make ya laugh [Re: Commando1] #890259
12/28/10 03:42 PM
12/28/10 03:42 PM
Well I would have origionally thought the same thing but when my customer came to him with his bent pushrod outa his 360, this guy told him he would straighten it for him and he could stick it back inn when he got back.
He came to my shop with it in his hand, still bent, but shocked.
Kasey
Re: This might make ya laugh [Re: Moparnut426] #890260
12/28/10 04:27 PM
12/28/10 04:27 PM
Ms.
Dartwizer Offline
Dartwizer  Offline
Ms.
That's what makes them Chevy's soooooooooooo fast.Ya gota tweak um alitte.An old Smokey trick
Re: This might make ya laugh [Re: Dartwizer] #890261
12/28/10 04:43 PM
12/28/10 04:43 PM
UK
602heavy Offline
602heavy  Offline
UK
.......done the exact same thing in a 400/512 running 3/8th pushrods , bent a couple of ex push rods , no time to get another set so hammered the rods straight & ran it. , done the same with pinched piston out the 440 , hammered the land straight & stuck it back together , ran a high 10 that weekend (4400lb) .......gonna start building some chevys.
Re: This might make ya laugh [Re: 602heavy] #890262
12/28/10 04:50 PM
12/28/10 04:50 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
i dig people that think outside the box. i would have never thought of that
Re: This might make ya laugh [Re: sixpackgut] #890263
12/28/10 05:35 PM
12/28/10 05:35 PM
Finland
mafo Offline
mafo  Offline
Finland
maybe we need to come up with "flexible" pushrods, just bend to fit
-65 Valiant,420", all motor,2700#, dot tires, 8,42 @ 160,2
Re: This might make ya laugh [Re: Moparnut426] #890264
12/28/10 05:56 PM
12/28/10 05:56 PM
Az
Crizila Offline
Crizila  Offline
Az
It's the kinda guy you want in your shop buying parts though. You know he will be back often
Fastest 300
Re: This might make ya laugh [Re: Crizila] #890265
12/28/10 06:56 PM
12/28/10 06:56 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
I smell an opportunity -- SBC/BBC roller pushrod guides.
Re: This might make ya laugh [Re: 64Post] #890266
12/28/10 07:34 PM
12/28/10 07:34 PM
hooziewhatsit Offline
I guess that's one way to set the lash
