Re: Thread on Piston to Valve clearance
[Re: Moparnut426]
#889592
12/27/10 05:36 PM
12/27/10 05:36 PM
Posts: 52,972 Romeo MI
MR_P_BODY
The book shows it as .100 intake and .120 exhaust but it also says you can go to .090... I have gone closer than .070 with a auto trans
[Re: Moparnut426]
#889593
12/27/10 07:31 PM
12/27/10 07:31 PM
Posts: 2,177 ill
dennismopar73
ill
im running wo gasket 69 / 90 i have a ton leaving some hp on the table this is just a shack down motor anyway put big one in make it lot closer prob be 60, 80 with gasket
ooo i wasnt kidding on those ss guys , they use all the chamber they leave almost nothing most hit on the big end they call it tap out i call it oooo my
[Re: Moparnut426]
#889594
12/27/10 07:34 PM
12/27/10 07:34 PM
Posts: 3,544 Syracuse,NY
CompWedgeEngines
Syracuse,NY
.080 / .100 is the " industry standard".
RIP Monte Smith
