Thread on Piston to Valve clearance #889588
12/27/10 12:38 PM
12/27/10 12:38 PM
Finally a HUSKER again
Moparnut426 Offline OP
There was a nice thread on here once that had a good bit of info on Piston to valve clearance. Im just trying to find it.
Kasey
Re: Thread on Piston to Valve clearance [Re: Moparnut426] #889589
12/27/10 03:06 PM
12/27/10 03:06 PM
A person wants a min of .080" correct
Kasey
Re: Thread on Piston to Valve clearance [Re: Moparnut426] #889590
12/27/10 04:11 PM
12/27/10 04:11 PM
ill
dennismopar73 Offline
ill
super stock guys prob run somewhere close to ,,0 to 50 hahah
Re: Thread on Piston to Valve clearance [Re: dennismopar73] #889591
12/27/10 05:18 PM
12/27/10 05:18 PM
Thats no help
Re: Thread on Piston to Valve clearance [Re: Moparnut426] #889592
12/27/10 05:36 PM
12/27/10 05:36 PM
MR_P_BODY Offline
MR_P_BODY  Offline
The book shows it as .100 intake and .120 exhaust but
it also says you can go to .090... I have gone closer
than .070 with a auto trans
Re: Thread on Piston to Valve clearance [Re: Moparnut426] #889593
12/27/10 07:31 PM
12/27/10 07:31 PM
ill
ill
im running wo gasket 69 / 90
i have a ton
leaving some hp on the table
this is just a shack down motor anyway
put big one in make it lot closer
prob be 60, 80 with gasket
ooo i wasnt kidding on those ss guys , they use all the chamber they leave almost nothing most hit on the big end they call it tap out
i call it oooo my
Re: Thread on Piston to Valve clearance [Re: Moparnut426] #889594
12/27/10 07:34 PM
12/27/10 07:34 PM
Syracuse,NY
CompWedgeEngines Offline
Syracuse,NY
.080 / .100 is the " industry standard".
RIP Monte Smith
Re: Thread on Piston to Valve clearance [Re: CompWedgeEngines] #889595
12/27/10 07:39 PM
12/27/10 07:39 PM
ill
ill
80 / 100 that is the 'standard'
Re: Thread on Piston to Valve clearance [Re: CompWedgeEngines] #889596
12/27/10 07:40 PM
12/27/10 07:40 PM
.080 intake .100 exhaust because the exhaust grows mor correct???
Kasey
Re: Thread on Piston to Valve clearance [Re: Moparnut426] #889597
12/27/10 07:42 PM
12/27/10 07:42 PM
ill
ill
yes but valve chasing piston thing
exhaust always closer it changes the more advance you get on cam
Re: Thread on Piston to Valve clearance [Re: Moparnut426] #889598
12/27/10 11:36 PM
12/27/10 11:36 PM
Cab_Burge Online work
Cab_Burge  Online Work
I use .050 as the minimum on the intakes and .060 on the exhaust
