Page 4 of 10 1 2 3 4 5 6 9 10
Re: K MEMBER [Re: W9 Dart] #888266
12/30/10 07:26 PM
12/30/10 07:26 PM
Get-X Offline
Get-X  Offline
Looks good Nice to hear it's been tested a bit. What does it cost?
'65 Belvedere
'68 GTX
'57 Dodge pickup
Re: K MEMBER [Re: W9 Dart] #888267
12/30/10 11:40 PM
12/30/10 11:40 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Tory, TShell, Stated, K Member, Check it out!!! He also stated he appreciates All the comments good or bad. Remember He said K Member Check it out!!
Well, as requested after checking it out the best I can through pics only.
Id say it looks pretty beefy. I like all the extra angles of reinforcement. In fact it may be more heavy duty then needed. This K Member actually looks more complicated to build then some of the others out there.
On the Whole K frame from the pics, the only thing that jumps out at me is the steering arm/balljoint combo.
It may be fine, but I cant tell how the steering arm is attached to the Ball joint portion of the tube. Is it welded to the End or does it run the Whole length??
This piece in particular has had strength problems in othe K frames here in the past. While the K frame itself looks plenty beefy, Im not to sure about this piece. "Let Vic Bloomer/SST340 show you some pics" Broken, from another unit.
I think its fine to be inquisitive of a new product. Especially of a product as important as a K Frame that does so much with front steering geometry and control.
Please excuse those who have experienced Nitemares and failures in the past with aftermarket K frames.
Dont expect people too Swoon over a New piece, Allow them to be inquisitive and cautious.
As I stated earlier, I appreciate All new products that someone is willing to take the time and expense to bring to the Mopar crowd.
Bring it on! And Tory, Thanks for asking, Check it out!! mike
Re: K MEMBER [Re: Sport440] #888268
12/31/10 12:12 AM
12/31/10 12:12 AM
LEBANON;PA
daron Offline
daron  Offline
LEBANON;PA
cant wait to get mine [ hint hint hint] tshell lol
Re: K MEMBER [Re: daron] #888269
12/31/10 12:22 AM
12/31/10 12:22 AM
United States
W
W9 Dart Offline
W9 Dart  Offline
W
United States
Right after me! lol
Re: K MEMBER [Re: W9 Dart] #888270
12/31/10 04:11 PM
12/31/10 04:11 PM
LEBANON;PA
daron Offline
daron  Offline
LEBANON;PA
naw i am special lol
Re: K MEMBER [Re: daron] #888271
12/31/10 07:05 PM
12/31/10 07:05 PM
md
W
wicked Offline
wicked  Offline
W
md
Have to agree on the ackerman issue, and to me just looks like alot of the welding is undercut. Ie: the plates welded to the control arms, the reinforcing tubes welded to the main crossmember
Re: K MEMBER [Re: wicked] #888272
12/31/10 07:12 PM
12/31/10 07:12 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I wouldn't say undercut... Looks like not enough fill or should put in a smaller weld that doesn't burn the edge. At least from what I can see on the blurry pics...
Otherwise looks decent to me..
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: K MEMBER [Re: DemonDust] #888273
12/31/10 07:25 PM
12/31/10 07:25 PM
md
W
wicked Offline
wicked  Offline
W
md
Yes, more fill, appears he only has half the thickness of the material welded
Re: K MEMBER [Re: wicked] #888274
01/01/11 01:22 AM
01/01/11 01:22 AM
K
Kiddart Offline
Kiddart  Offline
K
COST????? anyone or website to go look at it better
Thank you
Kiddart
Re: K MEMBER [Re: W9 Dart] #888275
01/01/11 07:27 AM
01/01/11 07:27 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
W9/Jason, after further study, of pics 3,4,and 5., they show some serious weld weakness issues, IMO
Focus on pic #5
This K Frame does have potential though.
But not as shown, IF the pics are correct. mike
Re: K MEMBER [Re: Sport440] #888276
01/01/11 07:38 AM
01/01/11 07:38 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
does anyone have a link(video) that you guys talk about to bobs k member in action?
Mopar Performance
Re: K MEMBER [Re: moparniac] #888277
01/01/11 10:59 AM
01/01/11 10:59 AM
GO BUCKS !!!!!!!
3
340RICK Offline
340RICK  Offline
GO BUCKS !!!!!!!
Is this the same " Tory " that did front end work on Brett Millers 65 dart
Re: K MEMBER [Re: 340RICK] #888278
01/01/11 11:21 AM
01/01/11 11:21 AM
Pennsylvania
TShell Offline OP
TShell  Offline OP
Pennsylvania
Yep, same Tory! I was working on his 65, had same shake issues as Bob when he started. Kept working at it, made alot of changes/progress with it. Went through all the same problems, ackerman, backup, wheels would tow in and shake
at 100 mph. The new piece I had at 140 mph, no shake, 3.5 caster, handles well. Still working to improve everything.
Re: K MEMBER [Re: Sport440] #888279
01/01/11 11:29 AM
01/01/11 11:29 AM
mass
K
kotacars Offline
kotacars  Offline
K
mass
you could say the same thing about bobs stuff makes a good product but the welding sucks
Re: K MEMBER [Re: kotacars] #888280
01/01/11 11:50 AM
01/01/11 11:50 AM
U.S.
moparniac Offline
moparniac  Offline
U.S.
bobs kit has crap weld jobs?
Mopar Performance
Re: K MEMBER [Re: kotacars] #888281
01/01/11 11:57 AM
01/01/11 11:57 AM
ellenwood,georgia
K
kdhull Offline
kdhull  Offline
K
ellenwood,georgia
I will have to respectfully disagree with that statement.I have 2 here and they are top quality.
Re: K MEMBER [Re: moparniac] #888282
01/01/11 12:54 PM
01/01/11 12:54 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I'd like to see this, I can't believe that statement is true.....
SDG Motorsports
Re: K MEMBER [Re: DemonDust] #888283
01/01/11 01:28 PM
01/01/11 01:28 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It isnt... I've seen Bobs welds
Re: K MEMBER [Re: MR_P_BODY] #888284
01/01/11 01:52 PM
01/01/11 01:52 PM
Winnipeg ,Mb. CA.
chryco Offline
chryco  Offline
Winnipeg ,Mb. CA.
Older (1st gen.) Mag Force front end in mine . Had a little trouble at first, but they made it right.
I pedaled the car to a 9.75 @134 MPH and change.
She ran straight and true , not a whimper.
Chryco
http://www.youtube.com/watch?v=YsmLj-Z44mo
Gas is fer washin' parts ....Alky`s fer drinkin' ...Nitro`s fer Racin'!
Re: K MEMBER [Re: wicked] #888285
01/01/11 03:45 PM
01/01/11 03:45 PM
Thigh-Gap Junction
@#$%&*! Offline
New user name, Same old jerk!
@#$%&*!  Offline
Thigh-Gap Junction
To be honest, that's the first thing I noticed from the close-up pictures but I didn't say anything. This is very common, I've seen it in aftermarket control arms, k-frames, and roll bars and cages. For structural components such as these the welds need to be engineered in material and geometry just like anything else. This simply means that the weld material and thickness need to be chosen to handle the loads and stresses they are, or might be, exposed to.
In these days of the internet you have to provide good (and pretty) pictures of your product to gain market acceptance. This need for prettiness hasn't necessarily been good for quality. I strongly encourage anyone thinking of making this kind of product to pick up a basic Mechanical Engineering text with a section on weld design and read that section until you understand it. I know, that's not gonna happen.
