Quiet full length 3" exhaust system (Dynomax mufflers).
#887698
12/24/10 10:41 PM
12/24/10 10:41 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
For an upcoming project car of mine, I'm trying to build a pretty quiet 3" diameter full exhaust system. I'll be using a Summit 3" headerback system (SUM-680141-NM), accompanied by an X-pipe, a pair of Dynomax 23" (Edit: 27") long Super Turbo mufflers (17769) and a pair of Dynomax 3" Race bullets (24215) acting as resonators in the back next to the fuel tank.
Is anyone running such a similar exhaust system perhaps and what are your findings/ideas?
Re: Quiet full length 3" exhaust system (Dynomax mufflers).
[Re: BigBlockMopar]
#887699
12/24/10 11:13 PM
12/24/10 11:13 PM
RapidRobert
Pretty much what I am going to run and a poster (on here) said to add a horizontle standpipe section to each bend as it goes over the axle ~ 1.5 ft or so capped at the end & this dead end addition reportedly accoustically cancells enough sound waves to make a substantial difference. If it's still too loud I am going to use some quiet mufflers and some 3" cutouts (Might be for the better as by the time they hear the open pipes the money will be in the hands of a neutral party )
[Re: ProSport]
#887701
12/25/10 12:39 AM
12/25/10 12:39 AM
RapidRobert
the capped standpipe setup sounds hokey (must cause some of the sound waves to cancel as they bounce back) but the guy said it works and I have a buddy that is a skilled welder (& works cheap) and a 3" system is not going to be quiet (unless the muffs are VERY restricted) and I dont want restricted muffs and anything that will help quiet things is worth a try & I will post pics/results (good or bad).
[Re: BigBlockMopar]
#887705
12/25/10 11:09 AM
12/25/10 11:09 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
572 hemi in a 72 b body i have 4" collectors on my headers. i narrow that down to 3 1/2" before the X pipe. have cut outs to open the exhaust before the X pipe inlet. after the X pipe i have 3" to the mufflers, hooker aero chambers 3" inlet and exhaust. then 2 1/2" tail pipes. the car is very quiet. almost to quiet even for the old man behind the wheel. i had 3" tail pipes and it was to loud for me so i installed the 2 1/2 tail pipes. i have cheap access to a chassis dyno so i did comparison tests on the same day of the change. i lost 4hp going to the 2 1/2 pipes. not much loss for peace and quiet on long drives.
perception is 90% of reality
[Re: stumpy]
#887706
12/25/10 12:23 PM
12/25/10 12:23 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
Somehow I just can't believe 3" and quiet.
3" with Super Turbo's and "not" quiet.
[Re: bp27]
#887709
12/25/10 02:47 PM
12/25/10 02:47 PM
Posts: 184 Vernon Ct.
bp27
Vernon Ct.
[Re: BigBlockMopar]
#887711
12/25/10 03:28 PM
12/25/10 03:28 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
My Suburban is getting the small 3 inch dynomax bullet mufflers. I like people to know i'm coming from blocks away.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: BigBlockMopar]
#887716
12/25/10 07:43 PM
12/25/10 07:43 PM
Posts: 36,840 South San Francisco, Californi...
MidPenMopar
Looking for fun? Keep looking
Do you have the long or short Dynomax mufflers?
Hummmnn??? I beleive they are the short "turbo" type Dynomax. I got it as a complete kit from TTI
So did you like the sound??
Stu
