Page 1 of 3 1 2 3
Quiet full length 3" exhaust system (Dynomax mufflers). #887698
12/24/10 10:41 PM
12/24/10 10:41 PM
The Netherlands
BigBlockMopar Offline OP
The Netherlands
For an upcoming project car of mine, I'm trying to build a pretty quiet 3" diameter full exhaust system.
I'll be using a Summit 3" headerback system (SUM-680141-NM), accompanied by an X-pipe, a pair of Dynomax 23" (Edit: 27") long Super Turbo mufflers (17769) and a pair of Dynomax 3" Race bullets (24215) acting as resonators in the back next to the fuel tank.
Is anyone running such a similar exhaust system perhaps and what are your findings/ideas?
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: BigBlockMopar] #887699
12/24/10 11:13 PM
12/24/10 11:13 PM
Pretty much what I am going to run and a poster (on here) said to add a horizontle standpipe section to each bend as it goes over the axle ~ 1.5 ft or so capped at the end & this dead end addition reportedly accoustically cancells enough sound waves to make a substantial difference. If it's still too loud I am going to use some quiet mufflers and some 3" cutouts (Might be for the better as by the time they hear the open pipes the money will be in the hands of a neutral party )
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: RapidRobert] #887700
12/25/10 12:26 AM
12/25/10 12:26 AM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
Huh?
An X-pipe system with straight through mufflers such as Magnaflows, with tailpipes and bullets near the back bumper for resonators will be quiet and not slow the car down, you won't even need cutouts.
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: ProSport] #887701
12/25/10 12:39 AM
12/25/10 12:39 AM
the capped standpipe setup sounds hokey (must cause some of the sound waves to cancel as they bounce back) but the guy said it works and I have a buddy that is a skilled welder (& works cheap) and a 3" system is not going to be quiet (unless the muffs are VERY restricted) and I dont want restricted muffs and anything that will help quiet things is worth a try & I will post pics/results (good or bad).
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: RapidRobert] #887702
12/25/10 01:05 AM
12/25/10 01:05 AM
jersey
Spaceman Spiff Offline
jersey
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: Spaceman Spiff] #887703
12/25/10 01:09 AM
12/25/10 01:09 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Somehow I just can't believe 3" and quiet.
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: Spaceman Spiff] #887704
12/25/10 10:52 AM
12/25/10 10:52 AM
The Netherlands
The Netherlands
Thanks for posting that article Eric.
Very good info!
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: BigBlockMopar] #887705
12/25/10 11:09 AM
12/25/10 11:09 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
572 hemi in a 72 b body
i have 4" collectors on my headers.
i narrow that down to 3 1/2" before the X pipe. have cut outs to open the exhaust before the X pipe inlet.
after the X pipe i have 3" to the mufflers, hooker aero chambers 3" inlet and exhaust.
then 2 1/2" tail pipes.
the car is very quiet. almost to quiet even for the old man behind the wheel.
i had 3" tail pipes and it was to loud for me so i installed the 2 1/2 tail pipes.
i have cheap access to a chassis dyno so i did comparison tests on the same day of the change. i lost 4hp going to the 2 1/2 pipes. not much loss for peace and quiet on long drives.
perception is 90% of reality
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: stumpy] #887706
12/25/10 12:23 PM
12/25/10 12:23 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
3" with Super Turbo's and "not" quiet.
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: 62maxwgn] #887707
12/25/10 12:24 PM
12/25/10 12:24 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
The rest of it.
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: 62maxwgn] #887708
12/25/10 02:45 PM
12/25/10 02:45 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
I have 3" Dynomax Super Turbo mufflers and its not quiet
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: bp27] #887709
12/25/10 02:47 PM
12/25/10 02:47 PM
Vernon Ct.
bp27 Offline
bp27  Offline
Vernon Ct.
And the back
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: bp27] #887710
12/25/10 03:05 PM
12/25/10 03:05 PM
The Netherlands
The Netherlands
I've currently got a pair of Dynomax mufflers under my '60 Chrysler.
They were a tad too loud for my taste aswell at low rpm so I installed a pair of resonators. The sound is pretty decent now, even without a balance-pipe.
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: BigBlockMopar] #887711
12/25/10 03:28 PM
12/25/10 03:28 PM
jersey
jersey
My Suburban is getting the small 3 inch dynomax bullet mufflers.
I like people to know i'm coming from blocks away.
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: Spaceman Spiff] #887712
12/25/10 06:05 PM
12/25/10 06:05 PM
Wendy, I'm home.
dstryr Offline
dstryr  Offline
Wendy, I'm home.
Are those 23" dynomax super turbos quiet until you get on it or not quiet all the time? I already have the mufflers and 3" tips for a complete 3" system, just wondering what to expect.
dstryr, since 1986.
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: dstryr] #887713
12/25/10 07:10 PM
12/25/10 07:10 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Frank,I consider mine loud all the time.I don't know if the Max Wedge manifolds contribute to it or not.I know I would sure like a little less noise.I have the same Super Turbo muffler on my Superbird only in 2 1/4".Totally different,sounds like the old Street Hemi muffler.
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: BigBlockMopar] #887714
12/25/10 07:32 PM
12/25/10 07:32 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
I have a TTI full legnth headers with 3 inch pipes and Dynomax mufflers in my roadrunner.
Here's what it sounds like:
http://www.youtube.com/watch?v=IrvhuBVRqQk
Stu
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: MidPenMopar] #887715
12/25/10 07:40 PM
12/25/10 07:40 PM
The Netherlands
The Netherlands
Do you have the long or short Dynomax mufflers?
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: BigBlockMopar] #887716
12/25/10 07:43 PM
12/25/10 07:43 PM
MidPenMopar Offline
MidPenMopar  Offline
Hummmnn??? I beleive they are the short "turbo" type Dynomax. I got it as a complete kit from TTI
So did you like the sound??
Stu
Re: Quiet full length 3" exhaust system (Dynomax mufflers). [Re: MidPenMopar] #887717
12/25/10 07:53 PM
12/25/10 07:53 PM
The Netherlands
The Netherlands
Sounds good enough for a musclecar-Mopar to me!
No H or X pipe in the exhaust?
I still hope my Chrysler will be quieter though.
Page 1 of 3 1 2 3
