which slicks
#880108
12/14/10 07:15 PM
12/14/10 07:15 PM
Posts: 2,442 LOWELL IN
QWK_ENUF
LOWELL IN
hoosier 29 x 12
goodyear 29 x 12
m & h 29 x 12.2
what are your thoughts, thanks
3200 lbs
WAXER
Re: which slicks
[Re: QWK_ENUF]
#880109
12/14/10 07:45 PM
12/14/10 07:45 PM
hoosiers work killer in that size range not much burnout needed--side walls stay good--and they last! If your Hoosier letters are turning brown you are burning them too long--I used to hate the MT's--they would work great for 12 hooks then the sidewalls go limp and then they were done--Hoosiers were always my best bet--I think in larger sizes like 14x32 and up GoodYears are hard to beat but smaller--Go Hoosier I burned enough slicks to make my own fishing reef off shore ![](/ubbthreads/images/graemlins/laugh2.gif)
Re: which slicks
[Re: QWK_ENUF]
#880110
12/14/10 08:59 PM
12/14/10 08:59 PM
Posts: 167 DANBURY CT
fury62
DANBURY CT
hoosier 29 x 12
goodyear 29 x 12
m & h 29 x 12.2
3200 lbs
I'm using phoenix 10.5/29.5-15 3250# b-body.the car was 60'ing 1.35 with a little cord showing. the side walls look good.I got my use out of them,and more!! just ordered a new set. ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: which slicks
[Re: ]
#880113
12/14/10 09:29 PM
12/14/10 09:29 PM
Posts: 3,410 Belpre,Ohio
CHAPPER
Belpre,Ohio
"..turning brown, you are burning them too long..." Interesting,,my thoughts exactly. I started running the Hoosiers for the first time this year. I noticed my first pass was the best 60' I would get all day. Noticed the white letters getting brown,,cut down on burn out time, seemed to help some. I am also not sure what air pressure they like the best. I have been increasing the air pressure little by little and seeing improvements in 60'. Track closed before I could get any more data. I was at 12# on 29.5X10.5WX15 and gaining. Will start out next season at 13# and go up till I see a change in the wrong direction.
If you like drag racing, support your local track.
Re: which slicks
[Re: QWK_ENUF]
#880116
12/14/10 10:07 PM
12/14/10 10:07 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
We used M&H with great results,but we like Phoenix.Their 11.5x29 is a great tire.
Re: which slicks
[Re: 540dust]
#880118
12/14/10 10:16 PM
12/14/10 10:16 PM
CHAPPER
Belpre,Ohio
Always ran Firestone before,,Phoneix is supposed to be the EXACT same thing. I will run the Hoosiers in the Spring and see how they do. If I am not happy after some runs in the early Spring, I will go to the Phoneix.
Re: which slicks
[Re: Quicktree]
#880122
12/14/10 10:32 PM
12/14/10 10:32 PM
I have used them all, hard to beat goodyears imo.
yeah, I could tell by your killer 60 foots. ![](/ubbthreads/images/graemlins/laugh2.gif)
Re: which slicks
[Re: 65dragnet]
#880123
12/14/10 10:33 PM
12/14/10 10:33 PM
QWK_ENUF
LOWELL IN
MY home made front suspension limits my travel so unless the track is killer i unload the tires
with 29.5/15w MT's on 10 in wheel was way better with 12 in wheels now i want to go to 12 in tread from 11 in tread
MT's are 93 circ and the hoosers are 92 circ
WAXER
Re: which slicks
#880124
12/14/10 10:33 PM
12/14/10 10:33 PM
Quicktree
oh yea what are they?
Re: which slicks
[Re: Quicktree]
#880126
12/14/10 10:36 PM
12/14/10 10:36 PM
Was there any air under those front runners? ![](/ubbthreads/images/graemlins/thumbs.gif)
Re: which slicks
#880127
12/14/10 10:39 PM
12/14/10 10:39 PM
Quicktree
your on this like a chinaman on a eggroll!
and your on BS like stink on poop
