which slicks #880108
12/14/10 07:15 PM
12/14/10 07:15 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
hoosier 29 x 12
goodyear 29 x 12
m & h 29 x 12.2
what are your thoughts, thanks
3200 lbs
WAXER
Re: which slicks [Re: QWK_ENUF] #880109
12/14/10 07:45 PM
12/14/10 07:45 PM
hoosiers work killer in that size range
not much burnout needed--side walls stay good--and they last! If your Hoosier letters are turning brown you are burning them too long--I used to hate the MT's--they would work great for 12 hooks then the sidewalls go limp and then they were done--Hoosiers were always my best bet--I think in larger sizes like 14x32 and up GoodYears are hard to beat but smaller--Go Hoosier I burned enough slicks to make my own fishing reef off shore
Re: which slicks [Re: QWK_ENUF] #880110
12/14/10 08:59 PM
12/14/10 08:59 PM
DANBURY CT
fury62 Offline
fury62  Offline
DANBURY CT
hoosier 29 x 12
goodyear 29 x 12
m & h 29 x 12.2
3200 lbs
I'm using phoenix 10.5/29.5-15 3250# b-body.the car was 60'ing 1.35 with a little cord showing. the side walls look good.I got my use out of them,and more!! just ordered a new set.
Re: which slicks [Re: QWK_ENUF] #880111
12/14/10 09:19 PM
12/14/10 09:19 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I like the Hoosiers best over all but the Phoenix
worked well also
Re: which slicks [Re: QWK_ENUF] #880112
12/14/10 09:27 PM
12/14/10 09:27 PM
Q
Quicktree Offline
Quicktree  Offline
Q
I have used them all, hard to beat goodyears imo.
Re: which slicks [Re: ] #880113
12/14/10 09:29 PM
12/14/10 09:29 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
"..turning brown, you are burning them too long..." Interesting,,my thoughts exactly. I started running the Hoosiers for the first time this year. I noticed my first pass was the best 60' I would get all day. Noticed the white letters getting brown,,cut down on burn out time, seemed to help some. I am also not sure what air pressure they like the best. I have been increasing the air pressure little by little and seeing improvements in 60'. Track closed before I could get any more data. I was at 12# on 29.5X10.5WX15 and gaining. Will start out next season at 13# and go up till I see a change in the wrong direction.
If you like drag racing, support your local track.
Re: which slicks [Re: CHAPPER] #880114
12/14/10 09:32 PM
12/14/10 09:32 PM
408Dust Offline
408Dust  Offline
Hooiser
Re: which slicks [Re: 408Dust] #880115
12/14/10 10:07 PM
12/14/10 10:07 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
Hooiser
ARE THEY 29 X 12
WAXER
Re: which slicks [Re: QWK_ENUF] #880116
12/14/10 10:07 PM
12/14/10 10:07 PM
Jacksonville, FL
Chris2581 Offline
Chris2581  Offline
Jacksonville, FL
We used M&H with great results,but we like Phoenix.Their 11.5x29 is a great tire.
Nautilus Racing-
Re: which slicks [Re: QWK_ENUF] #880117
12/14/10 10:08 PM
12/14/10 10:08 PM
Kokomo, IN
540dust Offline
540dust  Offline
Kokomo, IN
Phoenix
Re: which slicks [Re: 540dust] #880118
12/14/10 10:16 PM
12/14/10 10:16 PM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Always ran Firestone before,,Phoneix is supposed to be the EXACT same thing. I will run the Hoosiers in the Spring and see how they do. If I am not happy after some runs in the early Spring, I will go to the Phoneix.
Re: which slicks [Re: QWK_ENUF] #880119
12/14/10 10:18 PM
12/14/10 10:18 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
When comparing the same Advertised diameter slick of different manufacturers. Id want to know each of thier true diameters or circumference as that can vary by about 3/4".
If your shooting for max ET a 12" slick may be a little over kill, but for bracket racing, its fine. I love the MT,s myself. But the other brands listed are fine too. mike
Re: which slicks [Re: QWK_ENUF] #880120
12/14/10 10:23 PM
12/14/10 10:23 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
Hoosier
Re: which slicks [Re: CHAPPER] #880121
12/14/10 10:23 PM
12/14/10 10:23 PM
Indiana
65dragnet Offline
65dragnet  Offline
Indiana
Phoenix they will absolutely bite clear down to the cord and then some. Medium burnout = 150 passes
E. Williams 65 Coronet 500 3400lbs w/d, 446, Indy EZ'S, A&A transbrake,Comp 650 lift cam, 6.50 @ 105 mph 1/8th 10.25 @ 130mph 1/4
Re: which slicks [Re: Quicktree] #880122
12/14/10 10:32 PM
12/14/10 10:32 PM
yeah, I could tell by your killer 60 foots.
Re: which slicks [Re: 65dragnet] #880123
12/14/10 10:33 PM
12/14/10 10:33 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
MY home made front suspension limits my travel so unless the track is killer i unload the tires
with 29.5/15w MT's on 10 in wheel
was way better with 12 in wheels
now i want to go to 12 in tread from 11 in tread
MT's are 93 circ and the hoosers are 92 circ
WAXER
Re: which slicks #880124
12/14/10 10:33 PM
12/14/10 10:33 PM
Q
Quicktree Offline
Quicktree  Offline
Q
oh yea what are they?
Re: which slicks [Re: QWK_ENUF] #880125
12/14/10 10:35 PM
12/14/10 10:35 PM
LOWELL IN
Q
QWK_ENUF Offline OP
QWK_ENUF  Offline OP
Q
LOWELL IN
WAXER
Re: which slicks [Re: Quicktree] #880126
12/14/10 10:36 PM
12/14/10 10:36 PM
Was there any air under those front runners?
Re: which slicks #880127
12/14/10 10:39 PM
12/14/10 10:39 PM
Q
Quicktree Offline
Quicktree  Offline
Q
your on this like a chinaman on a eggroll!
and your on BS like stink on poop
