scored a Dana 60 for my dart but have some ?????
#879614
12/14/10 01:13 AM
12/14/10 01:13 AM
Posts: 3,838 Central Missouri Fort Leonard...
mopar65
Well i got a compleat Dana 60 out of a 1970 dodge 3/4 ton 2 wheel drive truck that was a factory big block 4 speed. ok this dana has 4.10 gears in it and a suregrip in it. i am trying to build this one a budget. i know i know race car and budget dont go to geather.lol ok my question is (1) what spline count is the factory sure grip. i mean are they 35 spline? (2) how strong are the factory gears in these and sure grip? the reasion i am asking these questions is if it will save me from having to buy gears and spool right now that would save me some money. but i will buy after market gears and spool if i have to.i am going to send this to doctor diff after tax day if i can ever get a hold of him. oh yea this is going in my 73 big block dart that i broke the 8-3/4.so far my car is running what is in my sig and i hope to go no faster than 10.00 but you never know.this is a street/strip car. so what do you think? or should i just bite the bullet and get the after market gears and spool? thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727
10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come...
( SGT Miller) Proudly served 12 years in the US ARMY RESERVES
support our troops
Re: scored a Dana 60 for my dart but have some ?????
[Re: mopar65]
#879617
12/14/10 04:25 AM
12/14/10 04:25 AM
Posts: 43,315 Bend,OR USA
Cab_Burge
I bought a junkyard Dana 60 out of a 1970 GMC or Chevy 3/4 ton truck(don't remember exactly which one), it had 30 spline axles in it identical to the stock Mopar 30 spline 8 3/4 axles that we ended up using in it I do have two Dana clutch type posi units for 4:56 zand higher ratio, also have one or two sets of new Dana Corp. side gears for the 35 spline axles to convert a early posi to the 35 spline axles. I'll have to look at both posi to see if they have the early or late spline side gears in them, I think there both 35 splines but I will check to see I bought a new 35 spline spool from Dr. Diff for my car when I swapped the Dana 60 into it do to it having 4.10 gears in it
[Re: mopar65]
#879619
12/14/10 12:04 PM
12/14/10 12:04 PM
Posts: 2,734 Charlotte, NC
446acuda
Charlotte, NC
Well i got a compleat Dana 60 out of a 1970 dodge 3/4 ton 2 wheel drive truck (1) what spline count is the factory sure grip. i mean are they 35 spline?
It will have 30 spline axles. The only Dana 60's that used 23 or 35 spline side gear are Mopar car Dana 60's. Trucks/vans are either 16 spline(Ford) or 30 spline (Ford,GM and Dodge). Early Dana 70's are 23 spline and late are 35 spline. These Dana 70 power lok internal parts fit a 60 power lock and that is what Dana/mopar did, put 70 side gears in the 60 for Dana 60 equipped cars.
[Re: 446acuda]
#879620
12/14/10 12:35 PM
12/14/10 12:35 PM
Posts: 694 Michigan
Super Scamp
I started on a small budget as well Look where it got me Watch out for the heavy duty Dana 60 with real thick webbing around the housing, not good for the build.
Just One Man's Opinion
Mopar Mafia Racing
[Re: Super Scamp]
#879621
12/14/10 12:44 PM
12/14/10 12:44 PM
Posts: 1,295 Tucson AZ,
MadMopars
Tucson AZ,
I have a 1969 Dana 60 removed from a Dodge truck as well as one from a 75 Dodge truck. The 69 housing has extra webbing on the case that the 75 does not. This extra webbing is also found on my "Original Dana 60 from a 71 B body". Why is this webbing a disadvantage? I ask because I too am getting ready to narrow one of the truck diffs for my 69 Dart. I would have imagined the extra webbing would be better?
[Re: theclutcher]
#879624
12/14/10 10:40 PM
12/14/10 10:40 PM
MadMopars
Tucson AZ,
Nothing wrong with the HD housings. 8 lbs. wont break the et bank. Much more rigid and prefered for 4 gear usage.
So it's a weight thing, got ya. Does the added strength justify the weigth differences? Anyone have problems with the non-gusseted housing?
[Re: Super Scamp]
#879629
12/15/10 12:07 PM
12/15/10 12:07 PM
Posts: 694 Michigan
Super Scamp
Another Pic of a normal Dana 60 Truck Type.
Mopar Mafia Racing
[Re: Super Scamp]
#879631
12/15/10 01:09 PM
12/15/10 01:09 PM
Posts: 2,172 Ohio
theclutcher
Ohio
Never saw a 60 HD with over 3.125 tubes. Thickest wall thickness of tubes is about 1/2 inch. here's a pic of the HD vs std Dana. These are spares for my cuda, std 60 is in forefront.
[Re: theclutcher]
#879632
12/15/10 01:18 PM
12/15/10 01:18 PM
Posts: 2,172 Ohio
theclutcher
Ohio
[Re: theclutcher]
#879633
12/15/10 04:57 PM
12/15/10 04:57 PM
Posts: 694 Michigan
Super Scamp
Nice Dana's I could of measured wrong, in the yard, I got 1 under the work bench but to much crap in the way to dig out. Good luck with the project
Mopar Mafia Racing
