scored a Dana 60 for my dart but have some ????? #879614
12/14/10 01:13 AM
12/14/10 01:13 AM
Central Missouri Fort Leonard...
mopar65 Offline OP
mopar65  Offline OP
Well i got a compleat Dana 60 out of a 1970 dodge 3/4 ton 2 wheel drive truck that was a factory big block 4 speed. ok this dana has 4.10 gears in it and a suregrip in it. i am trying to build this one a budget. i know i know race car and budget dont go to geather.lol ok my question is
(1) what spline count is the factory sure grip. i mean are they 35 spline?
(2) how strong are the factory gears in these and sure grip?
the reasion i am asking these questions is if it will save me from having to buy gears and spool right now that would save me some money. but i will buy after market gears and spool if i have to.i am going to send this to doctor diff after tax day if i can ever get a hold of him. oh yea this is going in my 73 big block dart that i broke the 8-3/4.so far my car is running what is in my sig and i hope to go no faster than 10.00 but you never know.this is a street/strip car. so what do you think? or should i just bite the bullet and get the after market gears and spool? thanks Mopar65
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: scored a Dana 60 for my dart but have some ????? [Re: mopar65] #879615
12/14/10 01:16 AM
12/14/10 01:16 AM
Finally a HUSKER again
Moparnut426 Offline
Moparnut426  Offline
More than likely a 32 spline sure grip???
Shouldnt be too hard to build. Just need some housing flanges, and a set of axles. Depending on the HP you have, Yukon makes a KILLER axle for a budjet built. They make a long spline, cut to fit axle I think.
Kasey
Re: scored a Dana 60 for my dart but have some ????? [Re: Moparnut426] #879616
12/14/10 01:27 AM
12/14/10 01:27 AM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
23 spline is likely.
Buy new side gears for the sure grip.
New axles and housing ends and you're ready to go.
Re: scored a Dana 60 for my dart but have some ????? [Re: mopar65] #879617
12/14/10 04:25 AM
12/14/10 04:25 AM
I bought a junkyard Dana 60 out of a 1970 GMC or Chevy 3/4 ton truck(don't remember exactly which one), it had 30 spline axles in it identical to the stock Mopar 30 spline 8 3/4 axles that we ended up using in it I do have two Dana clutch type posi units for 4:56 zand higher ratio, also have one or two sets of new Dana Corp. side gears for the 35 spline axles to convert a early posi to the 35 spline axles. I'll have to look at both posi to see if they have the early or late spline side gears in them, I think there both 35 splines but I will check to see I bought a new 35 spline spool from Dr. Diff for my car when I swapped the Dana 60 into it do to it having 4.10 gears in it
Re: scored a Dana 60 for my dart but have some ????? [Re: Cab_Burge] #879618
12/14/10 11:56 AM
12/14/10 11:56 AM
mopar65 Offline OP
mopar65  Offline OP
thanks for the info guys. yes i am trying to do this ona budget.lol but i will save up to buy the good parts if i have to.cab let me know if you find the side gears and how much you want for them. i am wanting to start off with the 35 spline axles now. so if the suregrip gives out on me i can just put a 35 spline spool in it and be done with it.I am going to try and get everything from doctor diff and have him cut down the axle etc also. that is if i can get ahold of him.lol thanks Mopar65
Re: scored a Dana 60 for my dart but have some ????? [Re: mopar65] #879619
12/14/10 12:04 PM
12/14/10 12:04 PM
Charlotte, NC
446acuda Offline
446acuda  Offline
Charlotte, NC
It will have 30 spline axles. The only Dana 60's that used 23 or 35 spline side gear are Mopar car Dana 60's. Trucks/vans are either 16 spline(Ford) or 30 spline (Ford,GM and Dodge). Early Dana 70's are 23 spline and late are 35 spline. These Dana 70 power lok internal parts fit a 60 power lock and that is what Dana/mopar did, put 70 side gears in the 60 for Dana 60 equipped cars.
Re: scored a Dana 60 for my dart but have some ????? [Re: 446acuda] #879620
12/14/10 12:35 PM
12/14/10 12:35 PM
Super Scamp Offline
Super Scamp  Offline
I started on a small budget as well Look where it got me
Watch out for the heavy duty Dana 60 with real thick webbing around the housing, not good for the build.
Just One Man's Opinion Mopar Mafia Racing
Re: scored a Dana 60 for my dart but have some ????? [Re: Super Scamp] #879621
12/14/10 12:44 PM
12/14/10 12:44 PM
Tucson AZ,
MadMopars Online content
MadMopars  Online Content
Tucson AZ,
I have a 1969 Dana 60 removed from a Dodge truck as well as one from a 75 Dodge truck. The 69 housing has extra webbing on the case that the 75 does not. This extra webbing is also found on my "Original Dana 60 from a 71 B body". Why is this webbing a disadvantage? I ask because I too am getting ready to narrow one of the truck diffs for my 69 Dart. I would have imagined the extra webbing would be better?
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: scored a Dana 60 for my dart but have some ????? [Re: mopar65] #879622
12/14/10 03:14 PM
12/14/10 03:14 PM
Dr Diff. sells the side gears, it is probally better to buy all new internal gears for your posi instead of mixing new ones with old ones I'll look at my posi's later this afternoon and see what I need, if I don't need both sets of the side gears I will sell one set of them to you,I'll PM you with the results
Re: scored a Dana 60 for my dart but have some ????? [Re: Cab_Burge] #879623
12/14/10 05:01 PM
12/14/10 05:01 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Nothing wrong with the HD housings.
8 lbs. wont break the et bank.
Much more rigid and prefered for 4 gear usage.
Re: scored a Dana 60 for my dart but have some ????? [Re: theclutcher] #879624
12/14/10 10:40 PM
12/14/10 10:40 PM
Tucson AZ,
Tucson AZ,
So it's a weight thing, got ya. Does the added strength justify the weigth differences? Anyone have problems with the non-gusseted housing?
Re: scored a Dana 60 for my dart but have some ????? [Re: MadMopars] #879625
12/14/10 10:53 PM
12/14/10 10:53 PM
Super Scamp Offline
Super Scamp  Offline
No the weight is not the issue here it's the tubes and just the Dana is strong enough with out the added gussets, I think the tubes where 3.50 inches OD. all you need for the new ends is 3.25 or 3.0 also wall thickness on the HD model is quite thicker than the reg dana 60. It's under the work bench I will dig it out and measure it to see.
Re: scored a Dana 60 for my dart but have some ????? [Re: Super Scamp] #879626
12/14/10 11:56 PM
12/14/10 11:56 PM
Tucson AZ,
Tucson AZ,
Is the one pictured the HD? What will the axle tube diameter be for each? Can anyone post a picture of both cause now I am starting to wonder what I have.
Re: scored a Dana 60 for my dart but have some ????? [Re: MadMopars] #879627
12/15/10 01:08 AM
12/15/10 01:08 AM
Eastern WA
P
ProStock1320 Offline
P
Eastern WA
I'd be interested to know if you have a Trac-Lok or a Powr-lok. IIRC, the side gears are different between the two.
Re: scored a Dana 60 for my dart but have some ????? [Re: MadMopars] #879628
12/15/10 12:05 PM
12/15/10 12:05 PM
Super Scamp Offline
Super Scamp  Offline
The one in the photo is a Normal Dana upside down. I will post a pick of this same one look. Yes a truck Dana 3/4 ton not 1 ton marked is marked with a HD on the inside of the housing
Re: scored a Dana 60 for my dart but have some ????? [Re: Super Scamp] #879629
12/15/10 12:07 PM
12/15/10 12:07 PM
Super Scamp Offline
Super Scamp  Offline
Another Pic of a normal Dana 60 Truck Type.
Re: scored a Dana 60 for my dart but have some ????? [Re: MadMopars] #879630
12/15/10 12:14 PM
12/15/10 12:14 PM
Super Scamp Offline
Super Scamp  Offline
I have junk yarded a few Dana's and between the Ford and Mopar dana they where mostly the same. 3 1/4" OD and some where 3" or 3 1/8" around there.
I did run across a HD Dana with 3 1/2 OD It's was a beast with all the extra webbing.
Take a photo of both of your Dana's so we can see ..
Re: scored a Dana 60 for my dart but have some ????? [Re: Super Scamp] #879631
12/15/10 01:09 PM
12/15/10 01:09 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
Never saw a 60 HD with over 3.125 tubes.
Thickest wall thickness of tubes is about 1/2 inch.
here's a pic of the HD vs std Dana.
These are spares for my cuda, std 60 is in forefront.
Re: scored a Dana 60 for my dart but have some ????? [Re: theclutcher] #879632
12/15/10 01:18 PM
12/15/10 01:18 PM
Ohio
theclutcher Offline
theclutcher  Offline
Ohio
60 HD
Re: scored a Dana 60 for my dart but have some ????? [Re: theclutcher] #879633
12/15/10 04:57 PM
12/15/10 04:57 PM
Super Scamp Offline
Super Scamp  Offline
Nice Dana's I could of measured wrong, in the yard, I got 1 under the work bench but to much crap in the way to dig out.
Good luck with the project
