90 dodge 318
#877398
12/11/10 11:58 AM
12/11/10 11:58 AM
Posts: 472 Downey, IA
Gt383
Downey, IA
Gotta 90 dodge conversion van 318 auto. Recently has a starting problem. In the AM cold start it tends to flood itself. After i do get it running throughout the day it just wants to crank alot then will start. Runs good at town n highways speeds but cutsout....backfires....burps stumbles boggs etc if u go past half throttle. Has recent tune up and fuelpump replaced 2 yrs ago...is this a sensor like crank position or maybe fuel pressure regulator..?????
If I hafta come in and getchya.......I'm gonna getchya!
Re: 90 dodge 318
[Re: Gt383]
#877399
12/11/10 12:26 PM
12/11/10 12:26 PM
Posts: 905 SD
zrxkawboy
SD
I would guess it's fuel-related. Start by checking fuel pressure.
It's Swifty! Swifty, you toad sucker!
Re: 90 dodge 318
[Re: Gt383]
#877400
12/11/10 12:32 PM
12/11/10 12:32 PM
Posts: 415 Indiana
Pentastar440
Indiana
Check the throttle position sensor .
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: 90 dodge 318
[Re: zrxkawboy]
#877401
12/11/10 12:57 PM
12/11/10 12:57 PM
Gt383
Downey, IA
what is the fuel pressure supposed to b on tbi?
Re: 90 dodge 318
[Re: Gt383]
#877402
12/11/10 04:30 PM
12/11/10 04:30 PM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
FIRST !!!!! check for codes !!!!!! sounds like the pickup unit in the dist needs changed.... fuel pressure is 14/15. the pump only energises for 3 seconds at startup.. but what do I know.... I only have 1 TBI equiped rig.... ![](/ubbthreads/images/graemlins/drive.gif)
I am truckless..
Re: 90 dodge 318
[Re: 340SHORTY]
#877405
12/13/10 11:55 AM
12/13/10 11:55 AM
Gt383
Downey, IA
update...changed throttle position sensor, and map sensor. Still wants to start hard it is -3 degrees this AM. started but was flooded for few sec. then cleaned out. When engine is still below full warm up wide open throttle produces full smooth power. Once its fully warmed up wants to cut out and bog at W O T.
Re: 90 dodge 318
[Re: buildanother]
#877407
12/14/10 11:10 AM
12/14/10 11:10 AM
Gt383
Downey, IA
Yes the iac resets itself every cycle... changes O2 sensor as well...started again this AM at -1 degress, flooded some then cleared out...clueless in IA also there are no codes ![](/ubbthreads/images/graemlins/hammer.gif)
Re: 90 dodge 318
[Re: SixDRacing]
#877409
12/15/10 12:14 PM
12/15/10 12:14 PM
Gt383
Downey, IA
Thats my next thought....after it is to full temp it is becoming tuffer to start.. No consistancy at all one time itl hit on the first crank, the next time it might take several long cranking attempts. Always starts but can be a real bear even warm.
Re: 90 dodge 318
[Re: Gt383]
#877410
12/21/10 08:02 PM
12/21/10 08:02 PM
Gt383
Downey, IA
Turns out that the tank vent was plugged at the charcoal cannister causing way high fuel pressure, tank was growing and causing high fuel pressure
Re: 90 dodge 318
[Re: Gt383]
#877412
12/22/10 09:26 AM
12/22/10 09:26 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
that doesn't make any sense...if the tank vent was plugged, wouldn't the tent go into a negative pressure as you drive?
it's so cold outside, I don't see how there's enough gas evaporating out to cause the tank to build up a positive charge, but I may be wrong!
either way, I'm sure the plugged vent was causing some serious issues. sounds like you cleared the vent, and all is well now?
**Photobucket sucks**
Re: 90 dodge 318
[Re: 70Cuda383]
#877413
12/22/10 09:40 AM
12/22/10 09:40 AM
Posts: 15,487 Florida
scratchnfotraction
first 318 magnum was 92-93 later for 360 magnum premag 318 engines went roller cam(long nose) with carb in 85(non oil thru lifters/solid PRs) premag 318 roller cam(short nose) with tbi,came later 89 for premagnum 360 roller cam(short nose) with tbi in trucks 1990 premag 318/360 had oil thru roller lifters/hollow PRs and oiled both thru the heads to rockers and thru lifters/PRs early 92-93 magnums had the block drilled for thru head to rocker oiling..but was blocked at the head gasket by magnum heads( cam has no oil holes for LA style oiling later on magnums did not get the block drilled for thru head oiling ![](/ubbthreads/images/graemlins/popcrn.gif)
Re: 90 dodge 318
[Re: 70Cuda383]
#877414
12/22/10 10:35 AM
12/22/10 10:35 AM
Posts: 11,543 chicagoland,usa
buildanother
chicagoland,usa
90 is non magnum
you sure about that? (Yes, I am)
I thought the 5.2L magnum started in 1988, and the 5.9L magnum started in 1989...
(You are reffering to the carb to tbi switch.)
