90 dodge 318 #877398
12/11/10 11:58 AM
12/11/10 11:58 AM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
Gotta 90 dodge conversion van 318 auto. Recently has a starting problem. In the AM cold start it tends to flood itself. After i do get it running throughout the day it just wants to crank alot then will start. Runs good at town n highways speeds but cutsout....backfires....burps stumbles boggs etc if u go past half throttle. Has recent tune up and fuelpump replaced 2 yrs ago...is this a sensor like crank position or maybe fuel pressure regulator..?????
If I hafta come in and getchya.......I'm gonna getchya!
Re: 90 dodge 318 [Re: Gt383] #877399
12/11/10 12:26 PM
12/11/10 12:26 PM
SD
Z
zrxkawboy Offline
zrxkawboy  Offline
Z
SD
I would guess it's fuel-related. Start by checking fuel pressure.
It's Swifty! Swifty, you toad sucker!
Re: 90 dodge 318 [Re: Gt383] #877400
12/11/10 12:32 PM
12/11/10 12:32 PM
Indiana
P
Pentastar440 Offline
P
Indiana
Check the throttle position sensor .
'65 Belvedere II - 446-Indy,727 transbrake,Dana 4.56
'38 Plymouth 4Dr - 408SixPack, A518, Dana60 4:10
Re: 90 dodge 318 [Re: zrxkawboy] #877401
12/11/10 12:57 PM
12/11/10 12:57 PM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
what is the fuel pressure supposed to b on tbi?
Re: 90 dodge 318 [Re: Gt383] #877402
12/11/10 04:30 PM
12/11/10 04:30 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
FIRST !!!!! check for codes !!!!!!
sounds like the pickup unit in the dist needs changed....
fuel pressure is 14/15. the pump only energises for 3 seconds at startup..
but what do I know.... I only have 1 TBI equiped rig....
I am truckless..
Re: 90 dodge 318 [Re: Gt383] #877403
12/11/10 08:19 PM
12/11/10 08:19 PM
missouri, USA
moparmojo Offline
moparmojo  Offline
missouri, USA
5.2 were notorious for having vacumm problems from the plenum gasket under the intake. On cold mornings the computer is in a differnt loop mode, the vacumm leak confuses the computer and it tells the injectors to dump more fuel. Thus, flooding the engine. On mine, I could only get it to restart (immediately after) if I put my foot all the way to the floor. I was told by putting the accelerator all the way to the floor that it cuts off the fuel. Anyway, the gasket is like $20 at the local autoparts place and it resolved my truck problem. There is a bunch of stuff to remove to get to the gasket but that cost is not too bad if you are willing to do the work.
Also if you are worried about the problem coming back Hughes Engines has a problem solver plenum gasket for the 5.2. As far as I know, they are the only one out there. Kind of pricey though.
Re: 90 dodge 318 [Re: moparmojo] #877404
12/11/10 10:11 PM
12/11/10 10:11 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
90 is non magnum
Re: 90 dodge 318 [Re: 340SHORTY] #877405
12/13/10 11:55 AM
12/13/10 11:55 AM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
update...changed throttle position sensor, and map sensor. Still wants to start hard it is -3 degrees this AM. started but was flooded for few sec. then cleaned out. When engine is still below full warm up wide open throttle produces full smooth power. Once its fully warmed up wants to cut out and bog at W O T.
Re: 90 dodge 318 [Re: Gt383] #877406
12/13/10 05:01 PM
12/13/10 05:01 PM
chicagoland,usa
chicagoland,usa
Is the idle speed motor opening the throttle for startup? When the idle motor is working correctly, it closes throttle when you shut eng off, then once engine is off, it automatically opens throttle back up for next startup. If the motor is not working right, it won't open throttle for next startup, and will flood unless you use your foot on accelerator tp open throttle. The wide open bog will be an additional problem though.
Re: 90 dodge 318 [Re: buildanother] #877407
12/14/10 11:10 AM
12/14/10 11:10 AM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
Yes the iac resets itself every cycle... changes O2 sensor as well...started again this AM at -1 degress, flooded some then cleared out...clueless in IA also there are no codes
Re: 90 dodge 318 [Re: Gt383] #877408
12/14/10 08:42 PM
12/14/10 08:42 PM
hobbs, new mexico
SixDRacing Offline
SixDRacing  Offline
hobbs, new mexico
test the ect sensor. its the engine coolent temp sensor for the ecm not the gague.
Re: 90 dodge 318 [Re: SixDRacing] #877409
12/15/10 12:14 PM
12/15/10 12:14 PM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
Thats my next thought....after it is to full temp it is becoming tuffer to start.. No consistancy at all one time itl hit on the first crank, the next time it might take several long cranking attempts. Always starts but can be a real bear even warm.
Re: 90 dodge 318 [Re: Gt383] #877410
12/21/10 08:02 PM
12/21/10 08:02 PM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
Turns out that the tank vent was plugged at the charcoal cannister causing way high fuel pressure, tank was growing and causing high fuel pressure
Re: 90 dodge 318 [Re: buildanother] #877411
12/22/10 09:25 AM
12/22/10 09:25 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
90 is non magnum
you sure about that?
I thought the 5.2L magnum started in 1988, and the 5.9L magnum started in 1989...
**Photobucket sucks**
Re: 90 dodge 318 [Re: Gt383] #877412
12/22/10 09:26 AM
12/22/10 09:26 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
that doesn't make any sense...if the tank vent was plugged, wouldn't the tent go into a negative pressure as you drive?
it's so cold outside, I don't see how there's enough gas evaporating out to cause the tank to build up a positive charge, but I may be wrong!
either way, I'm sure the plugged vent was causing some serious issues. sounds like you cleared the vent, and all is well now?
Re: 90 dodge 318 [Re: 70Cuda383] #877413
12/22/10 09:40 AM
12/22/10 09:40 AM
scratchnfotraction Offline
first 318 magnum was 92-93 later for 360 magnum
premag 318 engines went roller cam(long nose) with carb in 85(non oil thru lifters/solid PRs)
premag 318 roller cam(short nose) with tbi,came later
89 for premagnum 360 roller cam(short nose) with tbi in trucks
1990 premag 318/360 had oil thru roller lifters/hollow PRs and oiled both thru the heads to rockers and thru lifters/PRs
early 92-93 magnums had the block drilled for thru head to rocker oiling..but was blocked at the head gasket by magnum heads( cam has no oil holes for LA style oiling
later on magnums did not get the block drilled for thru head oiling
Re: 90 dodge 318 [Re: 70Cuda383] #877414
12/22/10 10:35 AM
12/22/10 10:35 AM
chicagoland,usa
chicagoland,usa
90 is non magnum
(Yes, I am)
(You are reffering to the carb to tbi switch.)
Re: 90 dodge 318 [Re: 70Cuda383] #877415
12/22/10 12:09 PM
12/22/10 12:09 PM
Downey, IA
Gt383 Offline OP
Gt383  Offline OP
Downey, IA
I believe that the return fuel flow causes pressre and it seems that my cap is unvented, after running the tank grows and fuel pressure rises causing my flooding problem. boy its a whole different animal now purrs, and starts great YES
