Re: duster guys how and what
[Re: joshking440]
#872742
12/06/10 12:58 PM
12/06/10 12:58 PM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
Call Bondobob at Bobs pro fab and get one of his front end kits!!!!
X2
[Re: joshking440]
#872743
12/06/10 12:59 PM
12/06/10 12:59 PM
Posts: 19,375 Las Vegas
Al_Alguire
Las Vegas
Well after heater box, sound dedener, carpet, wipers, fiberglass, lexan, light brakes start removing anything you can from anywhere you can. Cut off excess bolts that extend past the fastener etc...
[Re: earthmover]
#872744
12/06/10 12:59 PM
12/06/10 12:59 PM
Posts: 12,339 somwhere
smokinwoody
somwhere
here are some pics in my album on the Duster that I have for sale.. http://smg.photobucket.com/albums/v506/smokinwoody/DUSTER/#!cpZZ1QQtppZZ12look thru them.. has Lexan glass aluminum firewall fiberglass doors, hood, rear deck, front and rear bumpers trunk floor cut out and replaced with light sheet steel and square tube bars brackets made out of aluminum and so on... I see most guys are including their weight, of the cars...mine was just under 2700 with my wife as the driver..so its 2500 and some odd lbs..
[Re: cgall]
#872746
12/06/10 05:56 PM
12/06/10 05:56 PM
Posts: 4,436 SO CAL
BB70DUSTER
SO CAL
Mine was 2930, all steel, all stock interior, but with race seats, cromoly roll bar, mini tubbed,4 wheel wilwood disc brakes, dana 60, 496 RB engine, aluminum heads, 727, all steel except hood, all stock working glass/windows... I just added a tubular K member, cant wait to re-weight it... Only weight I removed was carpet pad/sound deadner, heater box, wipers, radio delet plate, cut bracing from the deck lid, removed splash gaurds...
[Re: earthmover]
#872748
12/06/10 09:10 PM
12/06/10 09:10 PM
Guitar Jones
Well an aluminum headed small block and 904 are quite a bit lighter than that RB and 727.
[Re: earthmover]
#872752
12/07/10 12:09 PM
12/07/10 12:09 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Its much easier to find 100 things at 1 lbs than it is to find 1 item at a 100 lbs so look at everything plus make brackets that do 2 or more things instead of 1 bracket for a single job
