duster guys how and what #872740
12/06/10 12:49 PM
12/06/10 12:49 PM
nc
E
earthmover Offline OP
E
nc
ok duster guys i have a 70 duster that i will be putting the new big block in and looking for ways and how to lose weight in them from those that has done it.i see alot of light cars posted os lets hear it how doid you lose it and where did you get it....
Re: duster guys how and what [Re: earthmover] #872741
12/06/10 12:50 PM
12/06/10 12:50 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
Call Bondobob at Bobs pro fab and get one of his front end kits!!!!
Re: duster guys how and what [Re: joshking440] #872742
12/06/10 12:58 PM
12/06/10 12:58 PM
BX, CT, FL.
B1KILLER Offline
B1KILLER  Offline
BX, CT, FL.
X2
Re: duster guys how and what [Re: joshking440] #872743
12/06/10 12:59 PM
12/06/10 12:59 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Well after heater box, sound dedener, carpet, wipers, fiberglass, lexan, light brakes start removing anything you can from anywhere you can. Cut off excess bolts that extend past the fastener etc...
Re: duster guys how and what [Re: earthmover] #872744
12/06/10 12:59 PM
12/06/10 12:59 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
here are some pics in my album on the Duster that I have for sale..
http://smg.photobucket.com/albums/v506/smokinwoody/DUSTER/#!cpZZ1QQtppZZ12
look thru them..
has Lexan glass
aluminum firewall
fiberglass doors, hood, rear deck, front and rear bumpers
trunk floor cut out and replaced with light sheet steel and square tube bars
brackets made out of aluminum and so on...
I see most guys are including their weight, of the cars...mine was just under 2700 with my wife as the driver..so its 2500 and some odd lbs..
Re: duster guys how and what [Re: smokinwoody] #872745
12/06/10 02:52 PM
12/06/10 02:52 PM
SW Ohio
cgall Offline
cgall  Offline
SW Ohio
Mine is 2700 with iron-head RB engine. It has steel fenders, doors, and trunk lid, but the inner door is cut out and the trunk lid inner sheet metal is cut out. I have 'glass bumpers and homemade aluminum brackets. All lexan windows with no regulators. Ladder bar/coil springs. Stock floor and dash, steel mini-tubs.
Re: duster guys how and what [Re: cgall] #872746
12/06/10 05:56 PM
12/06/10 05:56 PM
SO CAL
BB70DUSTER Offline
BB70DUSTER  Offline
SO CAL
Mine was 2930, all steel, all stock interior, but with race seats, cromoly roll bar, mini tubbed,4 wheel wilwood disc brakes, dana 60, 496 RB engine, aluminum heads, 727, all steel except hood, all stock working glass/windows... I just added a tubular K member, cant wait to re-weight it...
Only weight I removed was carpet pad/sound deadner, heater box, wipers, radio delet plate, cut bracing from the deck lid, removed splash gaurds...
Re: duster guys how and what [Re: BB70DUSTER] #872747
12/06/10 09:03 PM
12/06/10 09:03 PM
nc
E
E
nc
thats good stuff right there guys.. i have some ideas of what i wont when money is better but right now im just not able to buy a front end set up and get a motor build so gonna have to wing it if you know what i mean.. thanks mike
Re: duster guys how and what [Re: earthmover] #872748
12/06/10 09:10 PM
12/06/10 09:10 PM
Guitar Jones Offline
Well an aluminum headed small block and 904 are quite a bit lighter than that RB and 727.
Re: duster guys how and what [Re: Guitar Jones] #872749
12/06/10 09:40 PM
12/06/10 09:40 PM
pacific northwest
Stroker Scamp Offline
pacific northwest
not sure if 70 has crash bars in the doors, if so cut them out, i even lightened the inner window regulator and bars in the door, remove all under coating along with the above ideas, brakes too
footbrake N/A SB 408 Scamp 10.10 @ 132 street/strip
73 Duster 340 street strip 12.79 @ 105
Re: duster guys how and what [Re: Stroker Scamp] #872750
12/07/10 05:46 AM
12/07/10 05:46 AM
Hinterland SE Qld Aust
SG duster Offline
SG duster  Offline
2900 with iron headed 440 and 727, factory side glass and regs but lexan front & rear screen, all steel body including bonnet, factory dash is gone along with the rest of that unneeded stuff, its not hard to get a duster to diet
Re: duster guys how and what [Re: cgall] #872751
12/07/10 11:33 AM
12/07/10 11:33 AM
@ the shop
E
E-85 408 DART Offline
E
@ the shop
WOW 2700# is very impressive !!!
"Tappet" lead fabricator for the legendary "Flat & Tappet" race team .
Re: duster guys how and what [Re: earthmover] #872752
12/07/10 12:09 PM
12/07/10 12:09 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Its much easier to find 100 things at 1 lbs than it
is to find 1 item at a 100 lbs so look at everything
plus make brackets that do 2 or more things instead
of 1 bracket for a single job
Re: duster guys how and what [Re: Guitar Jones] #872753
12/07/10 01:21 PM
12/07/10 01:21 PM
Now - Port Orange,Fla. Former...
MIKES_DUSTER Offline
TOTALLY!!!!!
Re: duster guys how and what [Re: MIKES_DUSTER] #872754
12/07/10 02:02 PM
12/07/10 02:02 PM
Jacksonville, NC
RonP Offline
RonP  Offline
Jacksonville, NC
What is the goal here?
I am just shy of 3200# race weight and I have been 6.0's in the 1/8th and 9.50's in the 1/4 with a crappy 6.25 1/8th time. I guess I am just saying that with a good build, you might not need to worry about it.
Re: duster guys how and what [Re: RonP] #872755
12/07/10 02:09 PM
12/07/10 02:09 PM
nc
E
E
nc
thanks guys for all the good info..hay Ronp just looking to lighten things up a little and build some good hp hopefully 750hp with a low deck and some -1s just thought it would be a little easier on parts if i took a little weight of the car..and i know your car hauls seen it first hand...dont know if i remm. your combo so you care to share i try to keep most in my fav. to look over from time to time.. thanks mike
