Lets see your aluminum or sheet metal dashes #872380
12/05/10 09:12 PM
12/05/10 09:12 PM
Raleigh, NC
rockerbob Offline OP
Raleigh, NC
Started on my dash today. I had removed all of the unnecessary stuff which left large gapping holes in it exposing the harness & firewall. Decided to install a sheet metal type. Would like to see how you did the toggles & gauges.
2005 Dakota 4X4 3.7 2004 Rumble Bee 5.7 1978 Diplomat 318 1969 Satellite 318 "bracket racer" 1966 Barracuda (in progress ) 1964 Dodge 330 (future race project) 1962 Belvedere (HUM????)
Re: Lets see your aluminum or sheet metal dashes [Re: rockerbob] #872381
12/05/10 09:20 PM
12/05/10 09:20 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
It's an old pic! Looks better with the rest of the interior installed.
Re: Lets see your aluminum or sheet metal dashes [Re: rockerbob] #872382
12/05/10 09:23 PM
12/05/10 09:23 PM
Illinois, Indiana, Louisiana
ProStDodge Offline
ProStDodge  Offline
Put an aluminum dash in my Cuda 10 years ago. The sun reflecting off it was blinding. Ended up placing a section of black carpet on the top to eliminate glare. A flat-black paint or decal could be used to do the same thing.
Re: Lets see your aluminum or sheet metal dashes [Re: gsmopar] #872383
12/05/10 10:25 PM
12/05/10 10:25 PM
Missouri
galen Online content
galen  Online Content
Missouri
brushed, no glare
Re: Lets see your aluminum or sheet metal dashes [Re: galen] #872384
12/05/10 10:31 PM
12/05/10 10:31 PM
Raleigh, NC
Raleigh, NC
brushed, no glare
Did you sheet metal over the existing dash or section out the lower section?
Re: Lets see your aluminum or sheet metal dashes [Re: rockerbob] #872385
12/05/10 10:42 PM
12/05/10 10:42 PM
Ohio
Todd Offline
Todd  Offline
Ohio
Here's mine.
Re: Lets see your aluminum or sheet metal dashes [Re: rockerbob] #872386
12/05/10 10:52 PM
12/05/10 10:52 PM
Mt. Eden Ky.
Hemi Allstate Online content
Hemi Allstate  Online Content
Mt. Eden Ky.
I cut this one and moved it rearward. It now has a removable gauge panel, to make access to wiring and the rear of the gauges easier. The switches are mounted to the overhead cage bar.
My
mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Lets see your aluminum or sheet metal dashes [Re: Hemi Allstate] #872387
12/05/10 10:59 PM
12/05/10 10:59 PM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Mines the JEGS aluminum dash.
I do get some glare off the top if I'm driving into the sun but I've taken to tossing my gloves up in between the tach and shift light and that takes care of it.
Re: Lets see your aluminum or sheet metal dashes [Re: WILD BILL] #872388
12/05/10 11:51 PM
12/05/10 11:51 PM
Raleigh, NC
Raleigh, NC
Bill, is that a blue shift lite?
Re: Lets see your aluminum or sheet metal dashes [Re: rockerbob] #872389
12/05/10 11:54 PM
12/05/10 11:54 PM
gulfport, ms, west mi
rowin4 Offline
rowin4  Offline
Hey Bill, somebody mounted your tach correctly, what happened to the rest?
Re: Lets see your aluminum or sheet metal dashes [Re: rowin4] #872390
12/06/10 12:03 AM
12/06/10 12:03 AM
BROOK PARK, OH
WILD BILL Offline
WILD BILL  Offline
BROOK PARK, OH
Yes, that is a blue shift light
The main guages are all installed twisted so that when all is GOOD all the needles are flat across. (or close to it). That way I can tell at a glance that all is good or there is a problem and need to take action.
Re: Lets see your aluminum or sheet metal dashes [Re: WILD BILL] #872391
12/06/10 08:37 AM
12/06/10 08:37 AM
Raleigh, NC
Raleigh, NC
You go Bill! Funny thing is my car has a similar color interior. I get teased some. Its a Chrysler color called French racing blue. Some folks call it smurf blue Others say it Tarheel blue due to the colledge sports rivalry here between NC State (red) N. Carolina (lt blue) & Duke (Dk. blue) I have to quickly tell them I'm a Wolfpack man. Who just happens to like lt blue.
Re: Lets see your aluminum or sheet metal dashes [Re: rockerbob] #872392
12/06/10 12:21 PM
12/06/10 12:21 PM
Netherlands
72Challenger Offline
Netherlands
Have installed an alloy L from the window to the front bar of the cage which holds all electronics / fuses / msd etc. Then a kind of stock formed alloy dash hings on 4 studs. In the end I installed a thin dash cover over all of it which can be removed by 4 dzush fasteners.
Complete package still weighs as less as possible while retaining some sort of stock appearence.
Re: Lets see your aluminum or sheet metal dashes [Re: rockerbob] #872393
12/06/10 01:04 PM
12/06/10 01:04 PM
somwhere
smokinwoody Offline
smokinwoody  Offline
somwhere
mines a little of each...stock and aluminum sheet..
Re: Lets see your aluminum or sheet metal dashes [Re: smokinwoody] #872394
12/06/10 05:19 PM
12/06/10 05:19 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
I covered mine with vinyl.
Re: Lets see your aluminum or sheet metal dashes [Re: 70HemiGTX] #872395
12/06/10 07:00 PM
12/06/10 07:00 PM
Livonia Michigan
440dart Offline
440dart  Offline
Livonia Michigan
Heres mine, but the company that made it is out of business
Yes I live in Michigan, so there is still 1 light on
Re: Lets see your aluminum or sheet metal dashes [Re: rockerbob] #872396
12/06/10 07:44 PM
12/06/10 07:44 PM
Raleigh, NC
Raleigh, NC
Nice work fellas I defenately have some ideas to ponder on. I think I am going to leave my upper dash cap & install an insert. Kinda will resemble a stock dash on steriods
Re: Lets see your aluminum or sheet metal dashes [Re: rockerbob] #872397
12/06/10 08:02 PM
12/06/10 08:02 PM
On the south side of Nowhere
S/ST 3040 Offline
S/ST 3040  Offline
Jeff Allison (Hitman340) built mine. jeffallisonms@yahoo.com
Re: Lets see your aluminum or sheet metal dashes [Re: S/ST 3040] #872398
12/06/10 08:09 PM
12/06/10 08:09 PM
S/ST 3040 Offline
S/ST 3040  Offline
.......and then got it wrapped at Reddington Design. renee@reddingtondesign.com
Re: Lets see your aluminum or sheet metal dashes [Re: S/ST 3040] #872399
12/06/10 10:32 PM
12/06/10 10:32 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
My humble attempt.
Diego
