Lets see your aluminum or sheet metal dashes
#872380
12/05/10 09:12 PM
12/05/10 09:12 PM
Posts: 583 Raleigh, NC
rockerbob
Raleigh, NC
Started on my dash today. I had removed all of the unnecessary stuff which left large gapping holes in it exposing the harness & firewall. Decided to install a sheet metal type. Would like to see how you did the toggles & gauges.
2005 Dakota 4X4 3.7
2004 Rumble Bee 5.7
1978 Diplomat 318
1969 Satellite 318 "bracket racer"
1966 Barracuda (in progress )
1964 Dodge 330 (future race project)
1962 Belvedere (HUM????)
Re: Lets see your aluminum or sheet metal dashes
[Re: gsmopar]
#872383
12/05/10 10:25 PM
12/05/10 10:25 PM
Posts: 834 Missouri
galen
Missouri
[Re: rockerbob]
#872385
12/05/10 10:42 PM
12/05/10 10:42 PM
Posts: 1,377 Ohio
Todd
Ohio
[Re: rockerbob]
#872386
12/05/10 10:52 PM
12/05/10 10:52 PM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I cut this one and moved it rearward. It now has a removable gauge panel, to make access to wiring and the rear of the gauges easier. The switches are mounted to the overhead cage bar. My mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#872387
12/05/10 10:59 PM
12/05/10 10:59 PM
Posts: 10,542 BROOK PARK, OH
WILD BILL
BROOK PARK, OH
Mines the JEGS aluminum dash.
I do get some glare off the top if I'm driving into the sun but I've taken to tossing my gloves up in between the tach and shift light and that takes care of it.
[Re: rowin4]
#872390
12/06/10 12:03 AM
12/06/10 12:03 AM
WILD BILL
BROOK PARK, OH
Yes, that is a blue shift light
The main guages are all installed twisted so that when all is GOOD all the needles are flat across. (or close to it). That way I can tell at a glance that all is good or there is a problem and need to take action.
[Re: rockerbob]
#872392
12/06/10 12:21 PM
12/06/10 12:21 PM
Posts: 1,260 Netherlands
72Challenger
Netherlands
Have installed an alloy L from the window to the front bar of the cage which holds all electronics / fuses / msd etc. Then a kind of stock formed alloy dash hings on 4 studs. In the end I installed a thin dash cover over all of it which can be removed by 4 dzush fasteners. Complete package still weighs as less as possible while retaining some sort of stock appearence.
[Re: 70HemiGTX]
#872395
12/06/10 07:00 PM
12/06/10 07:00 PM
Posts: 354 Livonia Michigan
440dart
Livonia Michigan
Heres mine, but the company that made it is out of business
Yes I live in Michigan, so there is still 1 light on
