Re: carburetor recommendation
[Re: BigBlockScamp]
#872176
12/05/10 07:35 PM
12/05/10 07:35 PM
Posts: 96,664 On The Boat, On The Lake, Wa. ...
amxautox
Still Retired. Still Posting on Moparts. A Lot.
Eddy, but not the 750. Almost every 750 they made stumble. I've had GREAT responce out of every Eddy carb I've used.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
[Re: BigBlockScamp]
#872179
12/05/10 08:55 PM
12/05/10 08:55 PM
RapidRobert
I would like maintain a hint of mileage at least.
A small eddy maybe a 1406 (600) but make sure w it that the choke is right, the tension and esp that the "pulloff" opens it a small correct amt when it starts. If you have a spreadbore I'd have Demonsizzler prep you a thermoquad. I had one on a C boat 440 & it ran good and pulled hard considering. EDIT meant to say had a PO installed 600 on the C body
[Re: RapidRobert]
#872186
03/05/11 05:05 PM
03/05/11 05:05 PM
Call AED a sponsor on here and ask for John Dickey--mention you are a Moparts member and see what he says--they are one of the best carb shops if not THE best in the country --they will take good care of you
