carburetor recommendation #872175
12/05/10 07:00 PM
12/05/10 07:00 PM
New Braunfels, TX
BigBlockScamp Offline OP
New Braunfels, TX
What carburetor would you guys recommend for a daily driver 440 truck? It is a mild 440 (9.5:1, maybe 400 hp). I would like maintain a hint of mileage at least.
I'm currently running a 750 cfm vacuum secondary Edelbrock #1407. I'm chasing a stumble and have gone through it several times and am looking to move on and try something different. I'm considering an Edelbrock AVS.
Thanks.
Re: carburetor recommendation [Re: BigBlockScamp] #872176
12/05/10 07:35 PM
12/05/10 07:35 PM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
Eddy, but not the 750. Almost every 750 they made stumble. I've had GREAT responce out of every Eddy carb I've used.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: carburetor recommendation [Re: BigBlockScamp] #872177
12/05/10 07:45 PM
12/05/10 07:45 PM
places
79powerwagon Offline
places
Spread-bore. A well tuned spread-bore on a well tuned engine.
I'm a HUGE fan of the Eddy/Carter AFB's, but if you want fuel economy, you're off to the wrong start with both your vehicle AND carb choice!
FWIW, my 79 PW had a 360 with an Eddy 600 and I got 8mpg on a good day. And I drove this thing daily for a decade,and 8mpg was about it! It was FAST and it was RELIABLE to a fault, but HUNGRY!
Re: carburetor recommendation [Re: 79powerwagon] #872178
12/05/10 07:46 PM
12/05/10 07:46 PM
places
places
And you need to read and understand the manual for the Eddy carbs. They also really like a 4-hole spacer under them.
Re: carburetor recommendation [Re: BigBlockScamp] #872179
12/05/10 08:55 PM
12/05/10 08:55 PM
A small eddy maybe a 1406 (600) but make sure w it that the choke is right, the tension and esp that the "pulloff" opens it a small correct amt when it starts. If you have a spreadbore I'd have Demonsizzler prep you a thermoquad. I had one on a C boat 440 & it ran good and pulled hard considering. EDIT meant to say had a PO installed 600 on the C body
Re: carburetor recommendation [Re: RapidRobert] #872180
12/05/10 09:09 PM
12/05/10 09:09 PM
Clintwood VA
johnedod Offline
johnedod  Offline
Clintwood VA
I've got a thermoquad on my 440 and really like it. I got 16 mpg on a trip last summer in my road runner. Drove like grandpa though!
Johnedod
68 Road Runner
71 Road Runner
78 Power Wagon
Re: carburetor recommendation [Re: BigBlockScamp] #872181
12/06/10 12:35 PM
12/06/10 12:35 PM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
A good TQ core is in the BB section. 73 or 74 440 truck carb. Good price too.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: carburetor recommendation [Re: Rug_Trucker] #872182
12/06/10 03:19 PM
12/06/10 03:19 PM
New Braunfels, TX
New Braunfels, TX
Thanks. Has anyone ran a Road Demon on the street and know anything about mileage? And by the way, I consider "good mileage" to be in the double digits (I set my goals low).
Re: carburetor recommendation [Re: BigBlockScamp] #872183
12/06/10 05:30 PM
12/06/10 05:30 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Your best bet would be a spreadbore style carb, The TQs are good on gas but they can be finicky if not set up right, another carb that will do well is the Holley 6210 650dp spreadbore, it will be easier on gas then a squarebore, but it'll have that kick in the ass feeling when you get on it & open the larger secondaries, i had one on a mild 340 back in the 80s & it was a tire fryin mother.
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: carburetor recommendation [Re: RapidRobert] #872184
03/05/11 01:17 PM
03/05/11 01:17 PM
ny usa
1fastcuda Offline
1fastcuda  Offline
ny usa
Hi
I have a barracuda 340 4 speed I have a holley 750 on it now. Also have a LD340 Intake 1 inch spacer bar. X Heads The motor is very slugggish at take off. I do not race car just for street. Can anyone tell me if this carb is to big not sure. Running 3/8 fuel line. Also its a manual choke which i disabled the choke. dont need it. The car runs great at faster speed Its hard to even smoke the tires. Have a pretronics in my points Dist. Starts right up have about 10inches vaccumm. 35 total timing. Cant figure it out any thought's Thanks Kevin
Re: carburetor recommendation [Re: 1fastcuda] #872185
03/05/11 04:21 PM
03/05/11 04:21 PM
any thought's
What cam/initial/springs/gears/exhaust/ACTUAL cr/cranking compression
Re: carburetor recommendation [Re: RapidRobert] #872186
03/05/11 05:05 PM
03/05/11 05:05 PM
Call AED a sponsor on here and ask for John Dickey--mention you are a Moparts member and see what he says--they are one of the best carb shops if not THE best in the country --they will take good care of you
Re: carburetor recommendation [Re: 1fastcuda] #872187
03/05/11 05:14 PM
03/05/11 05:14 PM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Hi
What gear? Initial timing? Cam? LSA? Compression?
All those things left out affect as a whole. Especially, a short stroke smallblock with a biggish carb. A 650 would help driveability. BUT, I would try dialing in more initial mech. advance and some carb tuning. Are the idle mixture screws responsive when adjusted??
Re: carburetor recommendation [Re: RapidRobert] #872188
03/05/11 06:42 PM
03/05/11 06:42 PM
ny usa
1fastcuda Offline
1fastcuda  Offline
ny usa
Hi
Running a 28/484 108 centerline 50% I have a 3.55 Gears 17 in Tires
Purple cam. Have 2 1/2 dual back to cutouts Have the cherry bombs square ones.
Compression cranking is 140-150
Thanks Kevin
Re: carburetor recommendation [Re: Dean_Kuzluzski] #872189
03/05/11 11:01 PM
03/05/11 11:01 PM
ny usa
1fastcuda Offline
1fastcuda  Offline
ny usa
Hi
Mixture screws seem sluggish
can turn them all the way in runs but not very good. It should stall
out but does run. I had the carb rebuilt a year ago Cant drive it now
live in north East. Thanks Kevin
