Want to see a wild torque converter?? #871663
12/05/10 01:12 AM
12/05/10 01:12 AM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
I wonder if this thing will handle serious power. Sure sounds interesting...
Go to this video http://pirate4x4.com/tv/live14b.php
and move up to the 12 minute 15 second mark for the torque converter info.
I didn't see anything on Percy's website yet.
Re: Want to see a wild torque converter?? [Re: PolyDart] #871664
12/05/10 01:40 AM
12/05/10 01:40 AM
acworth / N. georgia - south e...
cheapstreetdustr Offline
seems pretty engenius..
cheapst.
365" Iron J heads,,3480lbs best 1.39 60ft on SS springs.10.54,124 mph ...6.67 1/8th et.average 60fts 1.46 w/ small cam &.063 no2 pill tagged & insured
[image][/image]
Re: Want to see a wild torque converter?? [Re: cheapstreetdustr] #871665
12/05/10 02:04 AM
12/05/10 02:04 AM
alabama
mopars rule Offline
mopar addict
mopars rule  Offline
mopar addict
alabama
That was pretty wild. Wonder what kind of price tag they will hang on it? Bet it will be pretty steep.
Re: Want to see a wild torque converter?? [Re: mopars rule] #871666
12/05/10 02:52 AM
12/05/10 02:52 AM
SOUTH JERSEY
HEMIFRED Offline
HEMIFRED  Offline
SOUTH JERSEY
First question what is maximum power capacity
home of the
Sox and Martin Hemi Duster
Re: Want to see a wild torque converter?? [Re: HEMIFRED] #871667
12/05/10 05:30 PM
12/05/10 05:30 PM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
That's the big question, and of course, how reliable will it be? Can't wait to see how they perform on the track.
Re: Want to see a wild torque converter?? [Re: PolyDart] #871668
12/05/10 07:51 PM
12/05/10 07:51 PM
La Vernia, Texas
Pat7272 Offline
Pat7272  Offline
La Vernia, Texas
Thats pretty interesting, hopefully they work well in practice.
Re: Want to see a wild torque converter?? [Re: Pat7272] #871669
12/05/10 08:11 PM
12/05/10 08:11 PM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
Here's a screen shot I grabbed out of the video:
Re: Want to see a wild torque converter?? [Re: Pat7272] #871670
12/05/10 08:26 PM
12/05/10 08:26 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
That is pretty interesting.....I wonder how the unit stays cool without fluid going through it from the trans?.......That's where ALL the heat comes from in an auto.....If that thing is slipping out of the hole, it's got to be building heat.......
If you can't handle the truth, you're living a lie.......
Re: Want to see a wild torque converter?? [Re: Big Squeeze] #871671
12/05/10 08:29 PM
12/05/10 08:29 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
the difference with the heat is it is a whole different design he said it has a set of gears running fluid through them instead of a fins like a regular converter
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: Want to see a wild torque converter?? [Re: dusturbd340W5] #871672
12/05/10 08:49 PM
12/05/10 08:49 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Its hard to imagine that thing spinning 7000rpm in your bellhousing. It looks like its got a 727 snout on it?
68 Barracuda Formula S 340
Re: Want to see a wild torque converter?? [Re: dusturbd340W5] #871673
12/05/10 09:01 PM
12/05/10 09:01 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Hmmm..... .......It's gear driven, so, what's keeping it from moving at idle?.......It has to be slipping somewhere???? and when you get it to go to 5K at the hit, it's going to be slipping even more........
Re: Want to see a wild torque converter?? [Re: Bad340fish] #871674
12/05/10 09:30 PM
12/05/10 09:30 PM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
I don't think the unit spins. I think the only thing that spins are the gears that are inside the unit.
Re: Want to see a wild torque converter?? [Re: Big Squeeze] #871675
12/05/10 09:33 PM
12/05/10 09:33 PM
Arizona
PolyDart Offline OP
PolyDart  Offline OP
Arizona
In the video you can see that the case has two through holes for locating bolts. At least I think that' what they're for... I believe the unit is held solidly mounted and only the gears inside turn.
In the video he says that at a certain RPM, the unit has a check valve which locks the unit up, eliminating slippage. He's talking only 1-2% parasitic loss
Re: Want to see a wild torque converter?? [Re: PolyDart] #871676
12/05/10 09:37 PM
12/05/10 09:37 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I am not sure there would be any torque multiplication…
Re: Want to see a wild torque converter?? [Re: PolyDart] #871677
12/05/10 09:42 PM
12/05/10 09:42 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
The unit has to spin while attached to the flywheel...... it has to turn the pump gears so the trans will work, that's why it has a converter snout.....you can see one of the three converter bolt holes that bolt up to the flywheel in the lower left hand corner of that pic and his hand is covering one.......and there must be one coming into the unit at the top......it's obviously for a 350 or 400 Turbo trans.......
Apparantly, it does it through the gears inside....
Re: Want to see a wild torque converter?? [Re: Big Squeeze] #871678
12/05/10 10:39 PM
12/05/10 10:39 PM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Apparently?? Im not sure, I watched it several times and he never once mentioned Torque multiplication.
Thats what I was searching for. Because if that vert doesnt provide it. It wont come close to competing with the current verts.
The closest he came to addressing it was when he stated it acts like a Hydraulic pump.
I cant figure out if it can multiply the torque or not on the launch. To me This would be a important factor, along with the Torque ratings and reliabity of the unit.
If it cant multiply the torque, its a Street vert.
If it could multiply the torque, you would think that they would include that multiplication factor as a selling point. On a new product, I know I would.
Instead they advertize Adjustible Stall speed and 2% lock up efficiency. mike
Re: Want to see a wild torque converter?? [Re: Sport440] #871679
12/05/10 10:49 PM
12/05/10 10:49 PM
Oologah, Oklahoma
Big Squeeze Offline
Big Squeeze  Offline
Oologah, Oklahoma
Since it has different sized gears, I don't see how it couldn't multiply torque???
Re: Want to see a wild torque converter?? [Re: Big Squeeze] #871680
12/06/10 01:15 AM
12/06/10 01:15 AM
Canton, Ohio
Sport440 Offline
Sport440  Offline
Canton, Ohio
Squeeze, He didnt say it has different size gears.
But , before i add any more input. Let me state that from his promotional description, theres not really enough info to come to any "real conclusions"
So I will further Speculate.
Heres my take, He states it has two big gears. the crank gear being like a Idler gear pumping fluid to the lower tranny pump gear.
With low rpm or centrifical force the fluid slips around lower pump gear at lower pressure until the RPM/centrifical force rises enough to close a barrel valve and that other weighted spring assisted arm valve.
Thereby allowing full hydraulic pressure into the pump system allowing almost full lock up of the hydraulic pump type Vert vs slipping for lack of fluid pressure.
Same Two gears though.
The drive difference being hydraulic slip at below stall RPM vs 2% hydraulic near lock up with all pressure release valves closed.
If this is the case, it is still concievable that there could be a hydraulic pressure spike as the centrifical valves close to cause some initial torque multiplication on the launch.
By your implication of two different size gears that later nearly lock up by 2% as a 1 to 1 gear, I see your point. But that in itself would/could be a stateable gear multiplication that I would indicate in its selling point.
But like I stated earlier, with the limited info given in the promo, its just my speculation. mike
Re: Want to see a wild torque converter?? [Re: Sport440] #871681
12/06/10 01:49 AM
12/06/10 01:49 AM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
I bet it is a simple hydraulic pump feeding a hydraulic motor, at idle the barrel valve lets all the fluid flow through a bypass circuit, as RPM goes up the weight on the barrel valve forces it to turn against a spring and block the bypass forcing the hydraulic motor to turn.
I think the gears he was refering to are just the pump gears and by changing the pump VS motor gear sizes you can change the TQ output.
If that is how it operates(I bet that is exactly it)then I would call it a hydraulic clutch or gear box but not a tq converter. The whole thing does have to rotate otherwise he would not have made the statement about it looking ugly but being balanced.
