Re: 400 rod bearings
[Re: fastfish451]
#868909
12/01/10 07:51 PM
12/01/10 07:51 PM
Posts: 2,091 Delray beach, Florida
Performance Only
yes, the N stands for narrow. it's important to make sure you put the upper half in the upper half of the rod and vice-versa. failure to do that WILL result in engine damage. those bearing are clearly marked. do i think they will be okay? can't say since i'm not the guy doing the assembly but it "should" be.
machine shop owner and engine builder
[Re: fastfish451]
#868913
12/02/10 03:58 PM
12/02/10 03:58 PM
Posts: 1,200 UK
602heavy
UK
yes they do look a bit rough out of the box, is there any prep work apart from clean and assembley lube?,also cant get them round the wrong way as there is a dowel hole in lower for ali rods. so the narrow bearing saves having to chamfer, should be good to go right. thanks again
I just clean em , lube em & stick em in..........i was told by a well known chevy engine builder over here that the reason these bearings look like they do is the heat treatment they get , usually these type bearings are used in race applications due to the extra hardening , so it stands top reason they will be a bit harder on journals , i have'nt looked on clevite site so may be wrong. ![](/ubbthreads/images/graemlins/tongue.gif)
