400 rod bearings #868906
12/01/10 04:22 PM
12/01/10 04:22 PM
England
fastfish451 Offline OP
England
rod bearings in my 400/512 at the moment are clevite CB 743H and have a chamfer on one side. i have just received new clevite CB743HND with no chamfer but they are more narrow so looks like no need to chamfer is this right. TIA
Re: 400 rod bearings [Re: fastfish451] #868907
12/01/10 04:30 PM
12/01/10 04:30 PM
Delray beach, Florida
P
Performance Only Offline
P
look closer, they do still have a very small chamfer on them and there is an upper and lower bearing.
machine shop owner and engine builder
Re: 400 rod bearings [Re: Performance Only] #868908
12/01/10 04:58 PM
12/01/10 04:58 PM
England
England
yes there is a very small chamfer if you look hard do you think they will be ok, i think the n in the p/n is for narrow bearing for aftermarket large fillet cranks
Re: 400 rod bearings [Re: fastfish451] #868909
12/01/10 07:51 PM
12/01/10 07:51 PM
P
P
yes, the N stands for narrow. it's important to make sure you put the upper half in the upper half of the rod and vice-versa. failure to do that WILL result in engine damage.
those bearing are clearly marked.
do i think they will be okay? can't say since i'm not the guy doing the assembly but it "should" be.
Re: 400 rod bearings [Re: Performance Only] #868910
12/01/10 08:02 PM
12/01/10 08:02 PM
UK
602heavy Offline
602heavy  Offline
UK
Those bearings will be fine , used the 'N' series in a megablock spraying 400hp , these don't have the white metal right? , they look pretty rough out the box , like they've been heated with a torch.
Re: 400 rod bearings [Re: 602heavy] #868911
12/01/10 09:16 PM
12/01/10 09:16 PM
NC
440Jim Offline
440Jim  Offline
NC
Right,
The older, regular width is about 0.890" wide and the "N" narrow bearing is about 0.838" wide. And they are marked upper and lower on the back. The "HN" are what Clevite has to offer instead of the older "H"
Re: 400 rod bearings [Re: 440Jim] #868912
12/02/10 03:36 PM
12/02/10 03:36 PM
England
England
yes they do look a bit rough out of the box, is there any prep work apart from clean and assembley lube?,also cant get them round the wrong way as there is a dowel hole in lower for ali rods. so the narrow bearing saves having to chamfer, should be good to go right. thanks again
Re: 400 rod bearings [Re: fastfish451] #868913
12/02/10 03:58 PM
12/02/10 03:58 PM
UK
602heavy Offline
602heavy  Offline
UK
I just clean em , lube em & stick em in..........i was told by a well known chevy engine builder over here that the reason these bearings look like they do is the heat treatment they get , usually these type bearings are used in race applications due to the extra hardening , so it stands top reason they will be a bit harder on journals , i have'nt looked on clevite site so may be wrong.
