Best rust converter type product? #866189
11/29/10 01:22 AM
11/29/10 01:22 AM
My Garage / Museum
idrivevintage Offline OP
Chrysler Plant
Chrysler Plant
My Garage / Museum
What would be the best way to stop rust in a seam. I've discovered a bit of rust on the tailgate of my wifes 2003 Dakota where the outer skin wraps around to the inner panel.(like on a door skin)
I wire wheeled it, coated it with some etching prime with my airbrush, then hit it with some rattle can paint that matched pretty well (silver)
Now just a few weeks later today I noticed a bit of rust stains starting again at the seam. So I guess its coming from the inside out.
There are a few slots that would allow me to pour some sort of rust converter/killer in there just not sure what to use that'll work
Any advice or tips appreciated............thanks
Re: Rust in body seams................ [Re: idrivevintage] #866190
11/29/10 01:55 AM
11/29/10 01:55 AM
MN
astrobuf Offline
astrobuf  Offline
MN
I'm afraid I have bad news. You have moisture and rust somehwere in the tailgate interior, not just the seam where you tried to treat / stop it. I'd say it's doubful you will be able to kill this short of opening up the panel.
You might slow it down though if you can figure out where and how moisture is getting into the tailgate interior? A bad gasket around a lock or latch?
If you can get into the gate interior, hose the inside of the tailgate down with some rust conversion compound, let it dry for a few days and then hose the interior down with light oil. A good freind of mine used to take his drain oil, mix it with kerosene and spray it into the interior of his Chebby pickup truck doors every fall to keep the bottoms from rotting out!
Astrobuf
So, are you really a Rocket Scientist?
Re: Rust in body seams................ [Re: astrobuf] #866191
11/29/10 12:15 PM
11/29/10 12:15 PM
Southaven, MS
BossRide Offline
BossRide  Offline
Southaven, MS
I will also add that rattle can paint is not a catalyst paint and will not properly seal out moisture for very long. You'll need a two-part paint with a hardener.
But if rust is underneath, it will not stop...
The Blue Goose
My instagram: Bossride
Re: Rust in body seams................ [Re: astrobuf] #866192
11/29/10 12:21 PM
11/29/10 12:21 PM
My Garage / Museum
Chrysler Plant
Chrysler Plant
My Garage / Museum
Astrobuf, thanks. I can get inside there a bit via a few small slots along the bottom of the tailgate. I've changed the title of the post now hoping for recommendations on a rust converter.
Afterward pouring oil in there sounds good to me, I'd think that'd slow it down
Kind of dissapointed a 03' is starting to rust like this. just trying to keep it looking good for as long as possible.
BossRide, I hear you on the rattle can paint, it was sort of a quick fix for the time I had. It does look like its coming thru again at the seam sadly. Guess I'll have to hit the paint store and get some real paint for this one too as it looks like I'm going to be fighting a on-going battle here.
Thanks again for the advice
Re: Rust in body seams................ [Re: idrivevintage] #866193
11/29/10 06:55 PM
11/29/10 06:55 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Your nearest PPG dealer should be able to sell you a decent phosphoric acid based rust converter. I would hose some of that stuff in there over the course of a few days, then pour some oil in there.
Re: Rust in body seams................ [Re: DaytonaTurbo] #866194
12/03/10 12:38 AM
12/03/10 12:38 AM
KS
68SportSatvert Offline
KS
Get some Zero Rust from Resto Rick and follow his instructions. I think you thin it 50% and then pour it into the seam from the INSIDE. Problem solved.
Re: Best rust converter type product? [Re: idrivevintage] #866195
12/03/10 02:03 AM
12/03/10 02:03 AM
GMP440 Offline
GMP440  Offline
Best way to kill that rust is to spray spme ospho or get some phosphoric acid and mix it 3:1 with water and spary it into the seams. This will get in there. After a few days of that wash it out, dry it out ; then prime and paint.
Re: Best rust converter type product? [Re: idrivevintage] #866196
12/03/10 09:13 AM
12/03/10 09:13 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
Anyone have past experience with this one?
http://www.krudkutter.com/mustrust.asp
I bought a small 8 0z bottle,
but have not tried it yet
and wondered if there were any tips or advice.
I have long term experience with
Naval Jelly,
is the Krud Kutter product same/better/worse?
For soaks I have tried Evapo-Rust, CLR, Lime-Away and they have all worked after a number of hours.
For rust conversion prior to paint I have tried Extend and Rust Bullet.
For spray on protection of non-rusted metal
"Synthetic EEZOX Premium Gun Care"
has worked well for me on tools in rough service
and I would recommend it for others to try
http://www.eezox.info/index.html
Re: Best rust converter type product? [Re: 360view] #866197
12/03/10 01:03 PM
12/03/10 01:03 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
I've found great results with "Ospho". Available at most hardware or Automotive paint stores.
Re: Best rust converter type product? [Re: StealthWedge67] #866198
12/03/10 02:06 PM
12/03/10 02:06 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Ospho cheap and easy to use.
Re: Best rust converter type product? [Re: stumpy] #866199
12/03/10 02:18 PM
12/03/10 02:18 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
What is this "rust" thing of which you speak?
Re: Best rust converter type product? [Re: idrivevintage] #866200
12/03/10 02:30 PM
12/03/10 02:30 PM
USA
b54406barrel Offline
USA
I have used Rustmort (SEM, I think?) a few times over the last 15 years on surface rust on floorboards & trunks. It seems to work pretty well & converts to a pretty workable surface. I did that on one trunk floor, coated it with por15 & then painted probably 10 years ago & nothing's ever come through.
