Best rust converter type product?
#866189
11/29/10 01:22 AM
11/29/10 01:22 AM
Posts: 1,589 My Garage / Museum
idrivevintage
Chrysler Plant
Chrysler Plant
My Garage / Museum
What would be the best way to stop rust in a seam. I've discovered a bit of rust on the tailgate of my wifes 2003 Dakota where the outer skin wraps around to the inner panel.(like on a door skin) I wire wheeled it, coated it with some etching prime with my airbrush, then hit it with some rattle can paint that matched pretty well (silver) Now just a few weeks later today I noticed a bit of rust stains starting again at the seam. So I guess its coming from the inside out. There are a few slots that would allow me to pour some sort of rust converter/killer in there just not sure what to use that'll work Any advice or tips appreciated............thanks
Re: Rust in body seams................
[Re: idrivevintage]
#866190
11/29/10 01:55 AM
11/29/10 01:55 AM
Posts: 654 MN
astrobuf
MN
I'm afraid I have bad news. You have moisture and rust somehwere in the tailgate interior, not just the seam where you tried to treat / stop it. I'd say it's doubful you will be able to kill this short of opening up the panel.
You might slow it down though if you can figure out where and how moisture is getting into the tailgate interior? A bad gasket around a lock or latch?
If you can get into the gate interior, hose the inside of the tailgate down with some rust conversion compound, let it dry for a few days and then hose the interior down with light oil. A good freind of mine used to take his drain oil, mix it with kerosene and spray it into the interior of his Chebby pickup truck doors every fall to keep the bottoms from rotting out!
Astrobuf
So, are you really a Rocket Scientist?
[Re: astrobuf]
#866191
11/29/10 12:15 PM
11/29/10 12:15 PM
Posts: 1,978 Southaven, MS
BossRide
Southaven, MS
I will also add that rattle can paint is not a catalyst paint and will not properly seal out moisture for very long. You'll need a two-part paint with a hardener.
But if rust is underneath, it will not stop...
The Blue Goose
My instagram: Bossride
Re: Best rust converter type product?
[Re: idrivevintage]
#866196
12/03/10 09:13 AM
12/03/10 09:13 AM
Posts: 8,162 USA
360view
Moparts resident spammer
USA
Anyone have past experience with this one? http://www.krudkutter.com/mustrust.aspI bought a small 8 0z bottle, but have not tried it yet and wondered if there were any tips or advice. I have long term experience with Naval Jelly, is the Krud Kutter product same/better/worse? For soaks I have tried Evapo-Rust, CLR, Lime-Away and they have all worked after a number of hours. For rust conversion prior to paint I have tried Extend and Rust Bullet. For spray on protection of non-rusted metal "Synthetic EEZOX Premium Gun Care" has worked well for me on tools in rough service and I would recommend it for others to try http://www.eezox.info/index.html
