440 ross piston help #859131
11/21/10 02:50 AM
11/21/10 02:50 AM
MOPAR HEADQUARTERS IN ALDEN NY
hemigod426 Offline OP
does any have a listing or remember the dish ccs for the 3.75 stroke 440 ross pistons. 440 source sold them they dont list them any more. emailed them few times for info, no results.need to know for my static comp.
MOPAR OR NO CAR
Re: 440 ross piston help [Re: hemigod426] #859132
11/21/10 03:00 AM
11/21/10 03:00 AM
440 source lists there 500 inch 440 dished ross pistons @ 24.ccs dont think its same for 3.75 crank 440 dished ross pistons cause je/srp/kb are 13-18cc dish for 3.75 and 24-30cc for 4.15 crank
MOPAR OR NO CAR
Re: 440 ross piston help [Re: hemigod426] #859133
11/21/10 12:18 PM
11/21/10 12:18 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I went to rosspistons.com and they don't list a dished one for 3.75 either. But they did have part #s and a chart. You might try contacting them directly, if you can't cc yours.
Re: 440 ross piston help [Re: hemigod426] #859134
11/22/10 02:43 PM
11/22/10 02:43 PM
here is pic of them, i would just cc them but ive got short block done and pan on. with out job#/part# ross is clueless. need info from any machine shop that stocked/used ross pistons for mopars.
MOPAR OR NO CAR
Re: 440 ross piston help [Re: hemigod426] #859135
11/22/10 02:48 PM
11/22/10 02:48 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
How about bringing a piston to TDC & ccing it yourself... not very hard..
Re: 440 ross piston help [Re: 1_WILD_RT] #859136
11/22/10 03:15 PM
11/22/10 03:15 PM
dont want grease bore now to hold cc fluid,(rings wont set) and wont be accuate tdc in block its .015 down from deck.would have to do 1 inch down fill. i could dry cc it with clay mold, but would be easier if some one here used these before or sold them.....any better ideas
MOPAR OR NO CAR
Re: 440 ross piston help [Re: hemigod426] #859137
11/22/10 03:17 PM
11/22/10 03:17 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
Pull the pan, pull one rod and get the job number off of the piston.
I know you dont want to pull the pan, but Im thinkin it would be the easiest way.
If nobody has an old catalog lying around, you may have to.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72. Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
Re: 440 ross piston help [Re: Von] #859138
11/22/10 03:37 PM
11/22/10 03:37 PM
NE Oklahoma
V
Von Offline
Von  Offline
V
NE Oklahoma
I see that Hensley has the pistons you have shown on their website.
http://www.hensleyperformance.com/order_now.php?part=25-32
CC is not listed though.
Give em a call.
Re: 440 ross piston help [Re: Von] #859139
11/22/10 03:45 PM
11/22/10 03:45 PM
Give em a call.
thanks for lead looks like there mopar guys and build motors also
MOPAR OR NO CAR
Re: 440 ross piston help [Re: hemigod426] #859140
11/22/10 04:23 PM
11/22/10 04:23 PM
Give em a call.
no dice they dont even have them they order as needed and dont know anything about them
MOPAR OR NO CAR
Re: 440 ross piston help [Re: topside] #859141
11/22/10 04:29 PM
11/22/10 04:29 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
Steve,phone works everytime.
310.536.0100
310.536.0333
Re: 440 ross piston help [Re: Von] #859142
11/22/10 04:43 PM
11/22/10 04:43 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I'd just do this , or CALL the source ?
Re: 440 ross piston help [Re: JohnRR] #859143
11/22/10 04:54 PM
11/22/10 04:54 PM
brandon is looking for me now, chris at ross says they were custom and has no std dish in his cnc program. i bought them of here from the moparts member hate in Ca guys into nice 440 street/strip dusters, with set of eagle h-beam rods and c/a rings all new. they were built to his order specs. which i never got. emailed him also before. any help from mr hate would be cool
Re: 440 ross piston help [Re: hemigod426] #859144
11/28/10 09:32 PM
11/28/10 09:32 PM
Marilla, New York
RalleyA12 Offline
RalleyA12  Offline
Marilla, New York
It looks to me like you could get a piece of plexiglass cut out round to the same diameter as the piston. Drill a hole in it, put some grease on the top of the piston only so it won't bother your ring seal and cc them.
Re: 440 ross piston help [Re: RalleyA12] #859145
11/29/10 02:18 AM
11/29/10 02:18 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
I am watching this as I will most likely run the same piston in my 493. Ron
Re: 440 ross piston help [Re: RalleyA12] #859146
11/29/10 03:11 AM
11/29/10 03:11 AM
yes made 440 piston ccer out 1/2 plastic lathed it to 4.30 bore to do all 440s 4.32-4.38 selled with vasoline and cced with baby oil
MOPAR OR NO CAR
Re: 440 ross piston help [Re: hemigod426] #859147
11/29/10 03:11 AM
11/29/10 03:11 AM
nutter pic
MOPAR OR NO CAR
Re: 440 ross piston help [Re: hemigod426] #859148
11/29/10 03:13 AM
11/29/10 03:13 AM
these pistons cced at 20 cc
MOPAR OR NO CAR
Re: 440 ross piston help [Re: hemigod426] #859149
12/02/10 08:22 PM
12/02/10 08:22 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
These are the pistons I ordered. 440Source list the dish at 24cc's. Ron
http://store.440source.com/Platinum-Series-Pistons-4350-24-Dished/productinfo/5080/
Re: 440 ross piston help [Re: 383man] #859150
12/02/10 09:50 PM
12/02/10 09:50 PM
Baltimore/Denver
64Post Offline
64Post  Offline
Baltimore/Denver
What effect is that much dish going to have on your CR? I thought you were going to shoot for 11.0:1.
