Re: 440 ross piston help
[Re: hemigod426]
#859135
11/22/10 02:48 PM
11/22/10 02:48 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
How about bringing a piston to TDC & ccing it yourself... not very hard..
[Re: hemigod426]
#859137
11/22/10 03:17 PM
11/22/10 03:17 PM
Posts: 3,698 NE Oklahoma
Von
NE Oklahoma
Pull the pan, pull one rod and get the job number off of the piston. I know you dont want to pull the pan, but Im thinkin it would be the easiest way. If nobody has an old catalog lying around, you may have to.
72 RR, Pump gas 440, 452s, 3800 lbs, Corked, ET Radials,. 11.33@117.72.
Same car, bone stock 346s, 9.5 comp, baby solid. 12.24@110.
[Re: Von]
#859138
11/22/10 03:37 PM
11/22/10 03:37 PM
Von
NE Oklahoma
I see that Hensley has the pistons you have shown on their website. http://www.hensleyperformance.com/order_now.php?part=25-32CC is not listed though. Give em a call.
[Re: topside]
#859141
11/22/10 04:29 PM
11/22/10 04:29 PM
Posts: 9,436 Blair County,PA
62maxwgn
Blair County,PA
I went to rosspistons.com and they don't list a dished one for 3.75 either. But they did have part #s and a chart. You might try contacting them directly, if you can't cc yours.
Steve,phone works everytime.
310.536.0100 310.536.0333
[Re: Von]
#859142
11/22/10 04:43 PM
11/22/10 04:43 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
I'd just do this , or CALL the source ?
[Re: 64Post]
#859151
12/03/10 08:17 PM
12/03/10 08:17 PM
Posts: 27,421 Balt. Md
383man
Balt. Md
These are the pistons I ordered. 440Source list the dish at 24cc's. Ron
http://store.440source.com/Platinum-Series-Pistons-4350-24-Dished/productinfo/5080/
What effect is that much dish going to have on your CR? I thought you were going to shoot for 11.0:1.
I am shooting for around 11.0. When I changed to the Indy EZ heads the comp went up as they have 75cc heads vs the Eddy 84cc so I could not get it lower then 11.8 with quench. I can get it at 10.8 real easy with these pistons so I decided to go with them and 10.8 since it will be a pump gas eng. Ron
