727 opinions needed! #855446
11/16/10 05:58 PM
11/16/10 05:58 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
I need opinions. I have a 528 Hemi with a 727 stock hemi stall converter (2500 to 2800 I believe) and 3:23 rear. The trans drives me nuts because it up shifts super quick under normal driving. It feels like most of my driving is in 3rd gear. Is there a way to adjust this? I have the kickdown set all the way back at full throttle. Any input appreciated!
Re: 727 opinions needed! [Re: PJM] #855447
11/16/10 06:11 PM
11/16/10 06:11 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
I believe the normal shift points with an easy throttle are 18 and 28mph.
Re: 727 opinions needed! [Re: PJM] #855448
11/16/10 07:31 PM
11/16/10 07:31 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Linkage or cable kickdown?
If linkage, does the aftermarket carburetor have the correct Mopar throttle lever extension?
Re: 727 opinions needed! [Re: PJM] #855449
11/16/10 11:19 PM
11/16/10 11:19 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The trans upshifts are controlled by governor pressure over coming throttle pressure. If the kick down is adjusted as far back as you can go,then you will have to modify the governor. A&A sells them and they can be changed in the car. If your cheap like me you can modify your own. Drilling the inner weight with a 3/8" bit 3/8" deep. Take the outer weight reduce the diameter by 1/8". Leave .100" untouched on both ends so it still fits correctly in the bore. This will get you pretty close.
Doug
Re: 727 opinions needed! [Re: dvw] #855450
11/16/10 11:38 PM
11/16/10 11:38 PM
Re: 727 opinions needed! [Re: dvw] #855451
11/17/10 09:10 AM
11/17/10 09:10 AM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Thanks will give it a try
Re: 727 opinions needed! [Re: PJM] #855452
11/17/10 10:57 AM
11/17/10 10:57 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What about this question you failed to answer? What you want to do can still be affected by this.
Re: 727 opinions needed! [Re: JohnRR] #855453
11/17/10 03:46 PM
11/17/10 03:46 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
My bad! Its a lokar cable.
Re: 727 opinions needed! [Re: PJM] #855454
11/17/10 05:28 PM
11/17/10 05:28 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The Lokar only works properly if the travel of the carburetor lever matches the travel of the transmission lever, they are usually not the same.
Redrilling the hole on the transmission lever will most likely allow you to adjust the light throttle shift points without any governor mods.
Re: 727 opinions needed! [Re: John_Kunkel] #855455
11/17/10 05:50 PM
11/17/10 05:50 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Would it not do the same by adjusting some slack in the cable? Right now it moves right when the throttle moves.
Re: 727 opinions needed! [Re: PJM] #855456
11/17/10 05:53 PM
11/17/10 05:53 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No, the Lokar is not setup properly for the application it is sold for.
The cable setup sold by Bouchillon is the better/correct setup to use .
Re: 727 opinions needed! [Re: PJM] #855457
11/17/10 05:58 PM
11/17/10 05:58 PM
Florida STAYcation
dOoC Offline
The village idiot's idiot
dOoC  Offline
Florida STAYcation
I would suggest putting a set of gauges on the trans ... measuring line and gov pressures.
Re: 727 opinions needed! [Re: John_Kunkel] #855458
11/17/10 06:18 PM
11/17/10 06:18 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
If I understand you correctly it would be like choking up on a bat? Do you know the proper measurements for the travel? Thanks,
Re: 727 opinions needed! [Re: PJM] #855459
11/17/10 07:20 PM
11/17/10 07:20 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
By design, the hemi/3.23 was intended to shift into 3rd gear between 13 and 19 mph ('68 service manual). Make sure that your cable has the correct amount of travel and is adjusted to help increase the upshift rpm. But with that you may still want a higher upshift. Reducing the outer governor weight will increase the light throttle upshift.
Re: 727 opinions needed! [Re: BSB67] #855460
11/17/10 07:45 PM
11/17/10 07:45 PM
florida
P
PJM Offline OP
PJM  Offline OP
P
florida
Did measurements and altered the kickdown arm. Perfectly in sync now. Thanks to all
