MW Stealth Heads #850399
11/10/10 11:19 AM
11/10/10 11:19 AM
FT Campbell, KY / Clarksville,...
The Cuda Guy Offline OP
Guys can the Stealths be brought out to MW? I used the search button... and no real answer other than some guy on bbdart.com did it. Anyone got any feedback?
Don
Street/Strip 73 Barracuda
Re: MW Stealth Heads [Re: The Cuda Guy] #850400
11/10/10 12:08 PM
11/10/10 12:08 PM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
That's what you get when you buy the CNC'd version.
Re: MW Stealth Heads [Re: Stanton] #850401
11/10/10 12:45 PM
11/10/10 12:45 PM
Are you sure? I dont see it mentioned anywhere that they are MW ports? I have the CNC version. Thanks.
PS. I stole that pic from this forum. Not my heads.
Don
Re: MW Stealth Heads [Re: The Cuda Guy] #850402
11/10/10 12:51 PM
11/10/10 12:51 PM
Chicago, IL
TonyS451 Offline
TonyS451  Offline
Chicago, IL
I have the CNC stealths and they are not max wedge sized ports. However, I spoke with Jeff at Modern Cyl head (does the cnc work for 440source) and he said they can be opened up to MW if need be. No big flow advantages though, other than being able to run some arguably better intake manifolds.
2 kids and a dog
Re: MW Stealth Heads [Re: TonyS451] #850403
11/10/10 01:14 PM
11/10/10 01:14 PM
Thanks man, this was the feedback I was looking for.
Don
Re: MW Stealth Heads [Re: TonyS451] #850404
11/10/10 01:34 PM
11/10/10 01:34 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
X2 ! Now don if you do that you should prolly run the 2d cause the bigger intakes won't fit under your dual snorkel hood ! Remember I have some engine lower kit to drop ya 1/2" if need be!
Mopar Performance
Re: MW Stealth Heads [Re: The Cuda Guy] #850405
11/10/10 01:38 PM
11/10/10 01:38 PM
U.S.
moparniac Offline
moparniac  Offline
U.S.
Don! Buy my converter! a9sec70cuda will attest to the quality !
Mopar Performance
Re: MW Stealth Heads [Re: moparniac] #850406
11/10/10 02:13 PM
11/10/10 02:13 PM
organ
maximum entropy Offline
organ
x3. the cnc stealths are not mw, and i wouldn't recommend going any bigger than the cnc port job. personally, i won't use the stealths again. i tried them once and they cracked badly within a few runs. shattered, actually. to their credit, they promptly replaced them with a new set, which have been working fine since then, and they make good power, but i am gunshy.
Re: MW Stealth Heads [Re: maximum entropy] #850407
11/10/10 10:20 PM
11/10/10 10:20 PM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello,
Jeff has 2 versions of his cnc program. They flow very close to the same numbers. The near MW version is purely to provide additional volume for the larger ci motors. It helps fill the cylinders better. Id use the near MW version for anything 500ci or larger.
Damon
Re: MW Stealth Heads [Re: mopardamo] #850408
11/10/10 11:00 PM
11/10/10 11:00 PM
Charleston
sixpackgut Offline
Drag Week Mod Champion
sixpackgut  Offline
Charleston
just to avoid the bathtub intake for the rest of your life would be worth it to go MW size with the 337 intake and use regular MW gaskets
