Re: MW Stealth Heads
[Re: The Cuda Guy]
#850402
11/10/10 12:51 PM
11/10/10 12:51 PM
Posts: 4,296 Chicago, IL
TonyS451
Chicago, IL
I have the CNC stealths and they are not max wedge sized ports. However, I spoke with Jeff at Modern Cyl head (does the cnc work for 440source) and he said they can be opened up to MW if need be. No big flow advantages though, other than being able to run some arguably better intake manifolds.
2 kids and a dog
[Re: moparniac]
#850406
11/10/10 02:13 PM
11/10/10 02:13 PM
Posts: 5,080 organ
maximum entropy
organ
x3. the cnc stealths are not mw, and i wouldn't recommend going any bigger than the cnc port job. personally, i won't use the stealths again. i tried them once and they cracked badly within a few runs. shattered, actually. to their credit, they promptly replaced them with a new set, which have been working fine since then, and they make good power, but i am gunshy.
