Cometic Head Gaskets #849271
11/08/10 11:05 PM
11/08/10 11:05 PM
Circleville, Ohio
E
Evil67 Offline OP
Evil67  Offline OP
E
Circleville, Ohio
I am going to use Cometic head gaskets on my 440. I have heard you should put sealer on them but the Cometic website says NOT to.
What do all of you do?
Former Username - 71Cuda
Current Ride: 1967 Dart - 340
Re: Cometic Head Gaskets [Re: Evil67] #849272
11/08/10 11:15 PM
11/08/10 11:15 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
i run them without sealer.BUT i open them up at the ends and put a light smear there just to save any weepage at the ends,with the oil draining and near the intake
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Cometic Head Gaskets [Re: tex013] #849273
11/08/10 11:21 PM
11/08/10 11:21 PM
Indy
joshking440 Offline
Lunch is on me!
joshking440  Offline
Lunch is on me!
Indy
I didnt use any sealer on my motor....no weeping and seal great under 35lbs of boost
Re: Cometic Head Gaskets [Re: Evil67] #849274
11/09/10 12:26 AM
11/09/10 12:26 AM
South Carolina
a408swinger Offline
mopar addict
a408swinger  Offline
mopar addict
South Carolina
I spray mine with a light coat of ultra copper spray on my smallblock. Unless you have a smooth enough deck and head surface you will get some coolant seepage. The ultra copper spray will stop that.
Re: Cometic Head Gaskets [Re: a408swinger] #849275
11/09/10 02:22 AM
11/09/10 02:22 AM
Phoenix, AZ
MoparBilly Offline
MoparBilly  Offline
Phoenix, AZ
I spray mine with ultra copper spray, did it on the BB and the SB...quite heavily, both sides of the gaskets.
"Livin' in a powder keg and givin' off sparks" 4 Street cars, 5 Race engines
Re: Cometic Head Gaskets [Re: MoparBilly] #849276
11/09/10 05:49 AM
11/09/10 05:49 AM
aotearoa
rebel Offline
rebel  Offline
aotearoa
i use a light spray with copper coat on new gaskets & when i'm re-using i get a little heavier with the coatings & do each individual layer.
Re: Cometic Head Gaskets [Re: rebel] #849277
11/09/10 08:26 AM
11/09/10 08:26 AM
ky
headhunter Offline
headhunter  Offline
ky
i would spray both sides with copper coat spray to be on the safe side let me know when you get her running agian
Re: Cometic Head Gaskets [Re: headhunter] #849278
11/09/10 09:42 AM
11/09/10 09:42 AM
an8sec70cuda Offline
I spray mine w/ coppercoat on both sides and in b/t the layers. Same gaskets for the past 4 years w/ no leaks. Re-used them when I freshened it up 2 years ago too.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Cometic Head Gaskets [Re: an8sec70cuda] #849279
11/09/10 09:45 AM
11/09/10 09:45 AM
Belpre,Ohio
CHAPPER Offline
CHAPPER  Offline
Belpre,Ohio
Yes,,,and definitly 'between' the layers!
If you like drag racing, support your local track.
Re: Cometic Head Gaskets [Re: CHAPPER] #849280
11/09/10 12:40 PM
11/09/10 12:40 PM
UK
602heavy Offline
602heavy  Offline
UK
When i've used these i drilled the rivets out & sprayed each layer with coppercoat , jusy be sure to get the orientation right when assembling to heads.
Re: Cometic Head Gaskets [Re: Evil67] #849281
11/09/10 02:45 PM
11/09/10 02:45 PM
closer to Canadian beer!
torkrules Offline
I'm neurotic
torkrules  Offline
I'm neurotic
I sprayed mine but I used Hylomar blue. Took them apart and sprayed each layer. I had to take one head off and all I did was wipe them down with thinner, re-sprayed them and used them again. Zero leaks.
Re: Cometic Head Gaskets [Re: torkrules] #849282
11/09/10 03:48 PM
11/09/10 03:48 PM
sg66mopar Offline
sg66mopar  Offline
Used them with no sealer on my first 572 with Indy heads and had lots of moisture in the oil all that year.
Used the same gaskets this year on the same block but with B1 heads. This time they were copper coated and had NO leaks even though the gaskets were used.
