Cometic Head Gaskets
#849271
11/08/10 11:05 PM
11/08/10 11:05 PM
Posts: 295 Circleville, Ohio
Evil67
Circleville, Ohio
I am going to use Cometic head gaskets on my 440. I have heard you should put sealer on them but the Cometic website says NOT to.
What do all of you do?
Former Username - 71Cuda Current Ride: 1967 Dart - 340
Re: Cometic Head Gaskets
[Re: Evil67]
#849272
11/08/10 11:15 PM
11/08/10 11:15 PM
Posts: 2,464 Sydney,Australia
tex013
Sydney,Australia
i run them without sealer.BUT i open them up at the ends and put a light smear there just to save any weepage at the ends,with the oil draining and near the intake Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: a408swinger]
#849275
11/09/10 02:22 AM
11/09/10 02:22 AM
Posts: 4,448 Phoenix, AZ
MoparBilly
Phoenix, AZ
I spray mine with ultra copper spray, did it on the BB and the SB...quite heavily, both sides of the gaskets.
"Livin' in a powder keg and givin' off sparks"
4 Street cars, 5 Race engines
[Re: headhunter]
#849278
11/09/10 09:42 AM
11/09/10 09:42 AM
Posts: 13,367 Marion, South Carolina [><]
an8sec70cuda
I spray mine w/ coppercoat on both sides and in b/t the layers. Same gaskets for the past 4 years w/ no leaks. Re-used them when I freshened it up 2 years ago too.
[Re: Evil67]
#849281
11/09/10 02:45 PM
11/09/10 02:45 PM
Posts: 2,715 closer to Canadian beer!
torkrules
I'm neurotic
I'm neurotic
I sprayed mine but I used Hylomar blue. Took them apart and sprayed each layer. I had to take one head off and all I did was wipe them down with thinner, re-sprayed them and used them again. Zero leaks.
