Looking for a Holley 750 for my 440 need help #843373
11/01/10 09:18 AM
11/01/10 09:18 AM
Danville, NH
Mopar_Mike Offline OP
Danville, NH
I would like to use a Holley 750 for my mild 440 build. I prefer a single inlet and need the Mopar Kickdown linkage. I can't find one though. Anybody have an idea where I can find one? Thanks.
RS23L7 4-Speed
Re: Looking for a Holley 750 for my 440 need help [Re: Mopar_Mike] #843374
11/01/10 09:24 AM
11/01/10 09:24 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
no such thing as a single line 750 Holley. Summit sells the kick-down attachment you need. However I have drilled out the holley linkage to except the standard Mopar throttle hardware. Takes about 30 seconds.
Coming soon!!!!
Re: Looking for a Holley 750 for my 440 need help [Re: Mr.Yuck] #843375
11/01/10 09:29 AM
11/01/10 09:29 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
I agree.
If you HAVE to have single feed, you'll have to take the bowls and transfer tube from a 600 and swap it over.
Re: Looking for a Holley 750 for my 440 need help [Re: Commando1] #843376
11/01/10 10:01 AM
11/01/10 10:01 AM
Danville, NH
Danville, NH
I agree.
Drilling the out the linkage, is it the welded stopper at the end? Cuz I have other Holleys with Mopar linkage I could use.
Ok, thanks. With the dual inlet, the feeder tube runs back to about an inch of space between it and the distributor..
RS23L7 4-Speed
Re: Looking for a Holley 750 for my 440 need help [Re: Mopar_Mike] #843377
11/01/10 10:16 AM
11/01/10 10:16 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
you can always make your own fuel line or turn the holley one around. I usually turn it backwards...seems to be wasier to work with.
Re: Looking for a Holley 750 for my 440 need help [Re: Mr.Yuck] #843378
11/01/10 10:49 AM
11/01/10 10:49 AM
scratchnfotraction Offline
turn it backwards and run the fuel line/plumbing off the firewall with the regulator on the inner fender
with the mech pump or elect it can be done this way
keeps the feul line away from the dist and from over the top of the exhast/VC area
Re: Looking for a Holley 750 for my 440 need help [Re: scratchnfotraction] #843379
11/01/10 02:09 PM
11/01/10 02:09 PM
Nunya CA
CR8CRSHR Offline
CR8CRSHR  Offline
Nunya CA
I have a brand new Holley 750 dual feed, manual choke, vacum secondary 4410/3310C that I would like to sell. It has never been used...Let me know if interested...Price would be less than advertised
http://www.summitracing.com/parts/HLY-0-3310C/
Re: Looking for a Holley 750 for my 440 need help [Re: CR8CRSHR] #843380
11/01/10 02:29 PM
11/01/10 02:29 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Heres the bracket you need, no sence in drilling holes. I see jegs has one now for 1.00 less then holleys.
http://www.jegs.com/i/Holley/510/20-7/10002/-1
75 Duster, 451 10.87 @ 123.58 NA 97 Z28 6sp., 12.01 @ 115 on a 100 shot 71 Swinger. 360 magnum. 12.58 @ 105 78 cutlass, 469 BBC. 12.70 @ 108 on street tires. http://www.youtube.com/watch?v=Z2kqNmMfheU
Re: Looking for a Holley 750 for my 440 need help [Re: joedust451] #843381
11/01/10 03:13 PM
11/01/10 03:13 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
I don't know what the big deal is. You just have to open this hole up enough so that the factory throttle shaft fits thru. I have even seen guys use a small bolt instead. That bracket you add to the side is bulky moves the linkage slightly over.
Re: Looking for a Holley 750 for my 440 need help [Re: Mr.Yuck] #843382
11/01/10 03:15 PM
11/01/10 03:15 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It has to do with the ratio of travel for the kickdown to work like it was designed.
Re: Looking for a Holley 750 for my 440 need help [Re: stumpy] #843383
11/01/10 04:19 PM
11/01/10 04:19 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Exactly! & it lets the factory throttle cable bolt right up. I've seen people do the way Yuck is talking about, sorry but it looks tacky & it throws the geometry off for the kickdown, they built those brackets for a reason, if you look at any "factory" mopar Carter/TQ/QJ/holley you will see how the linkage is out more to the side & back slightly. Plus theres no sence in drilling on a brand-new carb. Also, if you buy the carb new & jack with it that way, it voids "ALL" warr. if you need to send it back for any reason with-in the warr. Don't be cheap, spend the 8.00 & do it right!!!!!!!
Re: Looking for a Holley 750 for my 440 need help [Re: joedust451] #843384
11/01/10 05:42 PM
11/01/10 05:42 PM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
??? I didn't invent it. And I had zero issues on 2 cars I ran it on. Once the air cleaner is on you can't even see it and as far as tacky? how's that??? it looks stock.
Re: Looking for a Holley 750 for my 440 need help [Re: Mr.Yuck] #843385
11/01/10 10:47 PM
11/01/10 10:47 PM
Branson, Mo.
joedust451 Offline
super gas
joedust451  Offline
super gas
Branson, Mo.
Invent what??
Re: Looking for a Holley 750 for my 440 need help [Re: stumpy] #843386
11/02/10 01:30 AM
11/02/10 01:30 AM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
I agree 100%. get the correct adapter. it's cheap and it works.
Re: Looking for a Holley 750 for my 440 need help [Re: Mr.Yuck] #843387
11/02/10 01:32 AM
11/02/10 01:32 AM
lewiston, ID
cornucopia Offline
cornucopia  Offline
lewiston, ID
show us.let's see your set-up...
Re: Looking for a Holley 750 for my 440 need help [Re: Mr.Yuck] #843388
11/02/10 01:39 AM
11/02/10 01:39 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
And you probably are running a cable kickdown linkage cause the stock parts don't work right.... The hole in the holley isn't the proper distance from the throttle shaft therefore if you set the kickdown at WOT it won't be right under light throttle... Like others have pointed out it has to do with the ratio....
Re: Looking for a Holley 750 for my 440 need help [Re: Mopar_Mike] #843389
11/02/10 08:04 AM
11/02/10 08:04 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I agree.
There are SS lines for about 45.00 that are bent perfectly and have all the fittings you need to run the dual line and go all the way down to the pump. You can bend your own, but the cost of buying the fittings locally might be cost prohibitive, making the 45.00 deal appealing.
I got gouged so bad at the local shops that I should have just ordered one ahead of time. Instead, I had to go to 3 stores just to get parts and spent 21.00 on them, plus the line, plus my time. The only flare tool I think is worth buying is the Bluepoint, it is pretty costly, but you need one anyway if you are going to be working on old cars.
Re: Looking for a Holley 750 for my 440 need help [Re: cornucopia] #843390
11/02/10 08:09 AM
11/02/10 08:09 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
sorry that car is long gone and I run a 6-pack now.
