Looking for a Holley 750 for my 440 need help
#843373
11/01/10 09:18 AM
11/01/10 09:18 AM
Posts: 4,288 Danville, NH
Mopar_Mike
Danville, NH
I would like to use a Holley 750 for my mild 440 build. I prefer a single inlet and need the Mopar Kickdown linkage. I can't find one though. Anybody have an idea where I can find one? Thanks.
RS23L7 4-Speed
Re: Looking for a Holley 750 for my 440 need help
[Re: Mr.Yuck]
#843375
11/01/10 09:29 AM
11/01/10 09:29 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
no such thing as a single line 750 Holley. Summit sells the kick-down attachment you need. However I have drilled out the holley linkage to except the standard Mopar throttle hardware. Takes about 30 seconds.
I agree.
If you HAVE to have single feed, you'll have to take the bowls and transfer tube from a 600 and swap it over.
[Re: joedust451]
#843381
11/01/10 03:13 PM
11/01/10 03:13 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
Heres the bracket you need, no sence in drilling holes. I see jegs has one now for 1.00 less then holleys.
http://www.jegs.com/i/Holley/510/20-7/10002/-1
I don't know what the big deal is. You just have to open this hole up enough so that the factory throttle shaft fits thru. I have even seen guys use a small bolt instead. That bracket you add to the side is bulky moves the linkage slightly over.
[Re: stumpy]
#843383
11/01/10 04:19 PM
11/01/10 04:19 PM
Posts: 5,221 Branson, Mo.
joedust451
super gas
super gas
Branson, Mo.
It has to do with the ratio of travel for the kickdown to work like it was designed.
Exactly! & it lets the factory throttle cable bolt right up. I've seen people do the way Yuck is talking about, sorry but it looks tacky & it throws the geometry off for the kickdown, they built those brackets for a reason, if you look at any "factory" mopar Carter/TQ/QJ/holley you will see how the linkage is out more to the side & back slightly. Plus theres no sence in drilling on a brand-new carb. Also, if you buy the carb new & jack with it that way, it voids "ALL" warr. if you need to send it back for any reason with-in the warr. Don't be cheap, spend the 8.00 & do it right!!!!!!!
[Re: joedust451]
#843384
11/01/10 05:42 PM
11/01/10 05:42 PM
Mr.Yuck
Brookeville, Md
??? I didn't invent it. And I had zero issues on 2 cars I ran it on. Once the air cleaner is on you can't even see it and as far as tacky? how's that??? it looks stock.
[Re: Mr.Yuck]
#843385
11/01/10 10:47 PM
11/01/10 10:47 PM
joedust451
super gas
super gas
Branson, Mo.
Invent what??
[Re: stumpy]
#843386
11/02/10 01:30 AM
11/02/10 01:30 AM
Posts: 4,150 lewiston, ID
cornucopia
lewiston, ID
I agree 100%. get the correct adapter. it's cheap and it works.
[Re: Mr.Yuck]
#843387
11/02/10 01:32 AM
11/02/10 01:32 AM
cornucopia
lewiston, ID
show us.let's see your set-up...
[Re: Mr.Yuck]
#843388
11/02/10 01:39 AM
11/02/10 01:39 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
And you probably are running a cable kickdown linkage cause the stock parts don't work right.... The hole in the holley isn't the proper distance from the throttle shaft therefore if you set the kickdown at WOT it won't be right under light throttle... Like others have pointed out it has to do with the ratio....
[Re: Mopar_Mike]
#843389
11/02/10 08:04 AM
11/02/10 08:04 AM
Posts: 10,214 Someplace you aren't
SomeCarGuy
I agree.
Drilling the out the linkage, is it the welded stopper at the end? Cuz I have other Holleys with Mopar linkage I could use.
Ok, thanks. With the dual inlet, the feeder tube runs back to about an inch of space between it and the distributor..
There are SS lines for about 45.00 that are bent perfectly and have all the fittings you need to run the dual line and go all the way down to the pump. You can bend your own, but the cost of buying the fittings locally might be cost prohibitive, making the 45.00 deal appealing.
I got gouged so bad at the local shops that I should have just ordered one ahead of time. Instead, I had to go to 3 stores just to get parts and spent 21.00 on them, plus the line, plus my time. The only flare tool I think is worth buying is the Bluepoint, it is pretty costly, but you need one anyway if you are going to be working on old cars.
[Re: cornucopia]
#843390
11/02/10 08:09 AM
11/02/10 08:09 AM
Mr.Yuck
Brookeville, Md
sorry that car is long gone and I run a 6-pack now.
