what is this plate on my 727 valve body #842375
10/30/10 10:07 PM
10/30/10 10:07 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
took my valve body off to fix my thottle pressure screw and found this plate. any idea what it is? maybe part of a mod kit. none of my other valve bodies have this.
idea?ss
Re: what is this plate on my 727 valve body [Re: AK_JH27] #842376
10/30/10 10:37 PM
10/30/10 10:37 PM
Bama
Randy.. Offline
Randy..  Offline
Bama
maybe some sort of reinforcement plate, like the old S shaped ones on some of them.
Re: what is this plate on my 727 valve body [Re: Randy..] #842377
10/30/10 11:00 PM
10/30/10 11:00 PM
okla.
sam64 Offline
sam64  Offline
okla.
its had a shift kit installed.i beleive that is part of a mod so it will go to low gear if you desire at any speed.
Re: what is this plate on my 727 valve body [Re: sam64] #842378
10/30/10 11:11 PM
10/30/10 11:11 PM
Kissimmee Fl.
dusturbd340W5 Offline
Kissimmee Fl.
yep part of a trans-go TF2 kit for low gear at any speed.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
Re: what is this plate on my 727 valve body [Re: AK_JH27] #842379
10/31/10 12:16 PM
10/31/10 12:16 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
can i take it off without doing anything else? or will it cause damage?
Re: what is this plate on my 727 valve body [Re: AK_JH27] #842380
10/31/10 12:56 PM
10/31/10 12:56 PM
U.S.S.A.
JohnRR Online rolleyes
JohnRR  Online Rolleyes
U.S.S.A.
leave it , it's not hurting anything .
Re: what is this plate on my 727 valve body [Re: dusturbd340W5] #842381
10/31/10 02:58 PM
10/31/10 02:58 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Nope. It's part of a TF-3 manual shift kit, the groove in the other side of the plate reroutes line pressure to the governor pressure channel. It must remain in place.
Re: what is this plate on my 727 valve body [Re: John_Kunkel] #842382
11/01/10 12:33 PM
11/01/10 12:33 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
crap
I took the plate off, this tanny has the line prssure from the thottle hooked up, would this help. Dont really want to drop the pan again.
Re: what is this plate on my 727 valve body [Re: AK_JH27] #842383
11/01/10 12:57 PM
11/01/10 12:57 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Drop the pan..
Re: what is this plate on my 727 valve body [Re: 1_WILD_RT] #842384
11/01/10 01:29 PM
11/01/10 01:29 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
I'll take the advice, drop the pan and install it.
thanks guys
Re: what is this plate on my 727 valve body [Re: AK_JH27] #842385
11/01/10 01:35 PM
11/01/10 01:35 PM
U.S.S.A.
U.S.S.A.
crap
I don't know if having the linkage is going to make a difference wit ha TF-3 setup for manual mode , but I"ll let someone who knows better chime in .
Re: what is this plate on my 727 valve body [Re: JohnRR] #842386
11/01/10 02:31 PM
11/01/10 02:31 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
I drove this thing around with out the linkage and it shifted fine while in (D) drive but a little afraid of burning it up with out it. at least thats what i'm being told. is it ok for me to just leave it in drive and not shift it manually ?
Re: what is this plate on my 727 valve body [Re: AK_JH27] #842387
11/01/10 04:17 PM
11/01/10 04:17 PM
U.S.S.A.
U.S.S.A.
I don't know enough about the TF3 kit to answer the question, but you put it in drive and it shafted thru the gears ?
Re: what is this plate on my 727 valve body [Re: AK_JH27] #842388
11/01/10 04:55 PM
11/01/10 04:55 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If it shifts in Drive the TF-3 kit isn't active, on second look that plate might be the one included in the TF-3 kit to return the VB to fully automatic. In either case the plate needs to be installed if there are holes drilled in the VB transfer plate.
In the full manual mode the TF-3 kit allows the TP linkage to be used or blocked wide open, if the transmission shifts in Drive the TP linkage needs to be hooked up.
Re: what is this plate on my 727 valve body [Re: John_Kunkel] #842389
11/01/10 05:24 PM
11/01/10 05:24 PM
Anchorage,AK
AK_JH27 Offline OP
AK_JH27  Offline OP
Anchorage,AK
johnrr- yes- it shifted while in drive and the linkage was not hooked up, I know it needs to be.
working on that problem.
just is that plate is throwing me off.
John_K - i had the whole VB apart and compared it to some others that I had and they all looked the same. including the transfer plate.
I havent filled the tranny yet so its not really a problem pulling the pan again. i guess its better to just leave it on. it shifted fine.
I would hate to fill it now and found out that the plate really is needed.
thanks guys
Re: what is this plate on my 727 valve body [Re: John_Kunkel] #842390
11/02/10 10:20 PM
11/02/10 10:20 PM
Kissimmee Fl.
Kissimmee Fl.
well that's funny because I have 3 TF2 kits here and thy ALL have this plate in the kit and in the instructions.
Re: what is this plate on my 727 valve body [Re: dusturbd340W5] #842391
11/02/10 10:27 PM
11/02/10 10:27 PM
Kissimmee Fl.
Kissimmee Fl.
here you go
Re: what is this plate on my 727 valve body [Re: dusturbd340W5] #842392
11/02/10 10:27 PM
11/02/10 10:27 PM
Kissimmee Fl.
Kissimmee Fl.
and the instructions dealing with this plate
Re: what is this plate on my 727 valve body [Re: dusturbd340W5] #842393
11/03/10 06:47 AM
11/03/10 06:47 AM
U.S.S.A.
U.S.S.A.
Must be a change they made because the last TF-2 I did, maybe 6 years ago, didn't have that , I still have the left over pieces for it and the instructions , I'll have to dig them out .
Re: what is this plate on my 727 valve body [Re: dusturbd340W5] #842394
11/03/10 05:09 PM
11/03/10 05:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
News to me, I've got a couple of kits that aren't much more than a year old and they don't have that plate, grinding the valve is all that's needed for the downshift mod.
Good ol' Transgo, always changing.
