Re: what is this plate on my 727 valve body
[Re: sam64]
#842378
10/30/10 11:11 PM
10/30/10 11:11 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
yep part of a trans-go TF2 kit for low gear at any speed.
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: AK_JH27]
#842385
11/01/10 01:35 PM
11/01/10 01:35 PM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
crap I took the plate off, this tanny has the line prssure from the thottle hooked up, would this help. Dont really want to drop the pan again.
I don't know if having the linkage is going to make a difference wit ha TF-3 setup for manual mode , but I"ll let someone who knows better chime in .
[Re: AK_JH27]
#842387
11/01/10 04:17 PM
11/01/10 04:17 PM
JohnRR
U.S.S.A.
I drove this thing around with out the linkage and it shifted fine while in (D) drive but a little afraid of burning it up with out it. at least thats what i'm being told. is it ok for me to just leave it in drive and not shift it manually ?
I don't know enough about the TF3 kit to answer the question, but you put it in drive and it shafted thru the gears ?
[Re: AK_JH27]
#842388
11/01/10 04:55 PM
11/01/10 04:55 PM
Posts: 25,823 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If it shifts in Drive the TF-3 kit isn't active, on second look that plate might be the one included in the TF-3 kit to return the VB to fully automatic. In either case the plate needs to be installed if there are holes drilled in the VB transfer plate.
In the full manual mode the TF-3 kit allows the TP linkage to be used or blocked wide open, if the transmission shifts in Drive the TP linkage needs to be hooked up.
[Re: dusturbd340W5]
#842392
11/02/10 10:27 PM
11/02/10 10:27 PM
dusturbd340W5
Kissimmee Fl.
and the instructions dealing with this plate
[Re: dusturbd340W5]
#842393
11/03/10 06:47 AM
11/03/10 06:47 AM
JohnRR
U.S.S.A.
Nope. It's part of a TF-3 manual shift kit, the groove in the other side of the plate reroutes line pressure to the governor pressure channel. It must remain in place.
well that's funny because I have 3 TF2 kits here and thy ALL have this plate in the kit and in the instructions.
Must be a change they made because the last TF-2 I did, maybe 6 years ago, didn't have that , I still have the left over pieces for it and the instructions , I'll have to dig them out .
