How do you hook a Tach to MSD ignition? #841230
10/28/10 11:10 PM
10/28/10 11:10 PM
Tucson, AZ
Ramrod39 Offline OP
My New Title
Ramrod39  Offline OP
My New Title
Tucson, AZ
Firing a new engine, my first with MSD. I like to hook my old school mechanics tach up when I do this. Is it still just power leads and negative side of the coil sith an MSD?
Re: How do you hook a Tach to MSD ignition? [Re: Ramrod39] #841231
10/28/10 11:13 PM
10/28/10 11:13 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
MSD box has a Tach output terminal.. The tach won't read the Multi Spark output to the coil
Re: How do you hook a Tach to MSD ignition? [Re: Ramrod39] #841232
10/28/10 11:16 PM
10/28/10 11:16 PM
Newport, Mi
Evil Spirit Offline
Evil Spirit  Offline
Newport, Mi
Not if you want to keep that tach. There is a dedicated terminal on the side of the MSD box to drive the tach pulse. The coil pulse on an MSD is about 440volts and will fry a tach. And not all tachs will work with an MSD, especially older ones. There is usually a compatibility sheet in the manual.
Free advice and worth every penny...
Factory trained Slinky rewinder.........
Re: How do you hook a Tach to MSD ignition? [Re: Evil Spirit] #841233
10/28/10 11:38 PM
10/28/10 11:38 PM
Tucson, AZ
Ramrod39 Offline OP
My New Title
Ramrod39  Offline OP
My New Title
Tucson, AZ
Great. Cleverly, I lost the manual. Wish I had some way to watch the RPM at start up.....
Re: How do you hook a Tach to MSD ignition? [Re: Ramrod39] #841234
10/28/10 11:57 PM
10/28/10 11:57 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
you know, you can get a timing light with a built in tach, right? it will count the sparks, and display the number for you......
Re: How do you hook a Tach to MSD ignition? [Re: Ramrod39] #841235
10/29/10 12:12 AM
10/29/10 12:12 AM
NE
moparpoolman Offline
NE
Msd make an adapter that plugs into the tach port so you can use the older tachs
Re: How do you hook a Tach to MSD ignition? [Re: Golden-Arm] #841236
10/29/10 12:16 AM
10/29/10 12:16 AM
Tallmadge, Ohio
P
Paul_B Offline
Paul_B  Offline
P
Tallmadge, Ohio
As previously mentioned, the MSD will have a tach output. I had to add the msd tach adapter for my tach to work.
Re: How do you hook a Tach to MSD ignition? [Re: Ramrod39] #841237
10/29/10 12:30 AM
10/29/10 12:30 AM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
Manuals are all available online on their web site...
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: How do you hook a Tach to MSD ignition? [Re: Golden-Arm] #841238
10/29/10 02:09 PM
10/29/10 02:09 PM
Tucson, AZ
Ramrod39 Offline OP
My New Title
Ramrod39  Offline OP
My New Title
Tucson, AZ
Will that work with an MSD? Aren't there multiple sparks sent down the plug wire?
